U
ugpugp
i hv doubts with the below MCQ problems;
looking for the answers from the community.
1. if an expected result is not specified then
a. we cannot run the test
b. it may difficult to repeat the test
c. it may be difficult t determine if the test has passed or faild
d. we cannot automate the user inputs
2.which of the following could be a reason for a failure
1. Testing fault
2. Software fault
3. Design Fault
4. Environment fault
5. Document fault
a. 2 is a valid reason. 1,3,4,5 are NOT
b. 1,2,3,4 are valid reasons. 5 is NOT
c. 1,2,3 are valid reasons; 4,5 are NOT
d. All of them are valid reasons for a failure
3. Thsts are prioitized so that,
a. You shorten the time required for testing
b. You do the best testing in the time available
c. You do more effective testing
d. You find more faults
4. During which test activity could faults be found most cost effectively?
a. Execution
b. Design
c. Planning
d. Check Exit criteria completion
5. The inputs for developing a test plan are taken from
a. Project Plan
b. Business Plan
c. Support Plan
d. None of the above
6. Function/Test matrix is a type of
a. Interim Test report
b. Final test report
c. Project status report
d. Management report
7. Which of these can be successfully tested using Loop Testing methodology
a. Simple Loops
b. Nested Loops
c. Concatenated Loops
d. All of the above
In to my mind these are the answers that i thinlkk;
how about this!
1. c
2. d
3. b
4. c
5. d
6. c
7. d
what is the correctness of the answers!
1. Testing fault
2. Software fault
3. Design Fault
5. Document fault
a. Execution
b. Design
c. Planning
a. Project Plan
b. Business Plan
c. Support Plan
a. Simple Loops
b. Nested Loops
d. All of the above
how about this!
1. c
2. d
3. b
4. c
5. d
6. c
7. d
