F
farasm5
It will be greatly helpful if anybody responds to my question.
When I decided a resolution III factorial design, 2(5-2) for a screening experiment, a 8 run fractional factorial design by Minitab was generated and alias structure is given to me like below.
Design Generators: D = AB, E = AC
Alias Structure
I + ABD +ACE+BCDE
A + BD + CE + ABCDE
B + AD + CDE + ABCE
C + AE + BDE + ABCD
D + AB + BCE + ACDE
E + AC + BCD + ABDE
BC + DE + ABE + ACD
BE + CD + ABC + ADE
What I understand is main effect and two factor interactions should not be aliased if two factor interactions may affect the response during Resolution III design.
My concern is D+AB. For example, this screening experiment is associated with mold validation and if I assign A as temperature and B as time, I think that two factor interactions AB will possibly affect the response. Then we don?t know the effect will be the result of D, AB or both because main effects A and B are expected to affect the response most.
My questions is that it is an acceptable or right way to reassign main effects sequence (ex. assign temperature to main effect ?D? and time to main effect ?C?) to avoid for main effects to be confounded with two factor interactions which could affect the response.
Thank you very much for your help in advance.
Peter
Alias Structure
I + ABD +ACE+BCDE
A + BD + CE + ABCDE
B + AD + CDE + ABCE
C + AE + BDE + ABCD
D + AB + BCE + ACDE
E + AC + BCD + ABDE
BC + DE + ABE + ACD
BE + CD + ABC + ADE
Peter
