Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 26th July 1999, 11:39 AM
dscumaci
Unregistered Guest
Posts: n/a
Red Face Calibration of Tape Measures used on our production floor - What are 'Best Practices'
We recently received a minor nonconformance during a surveillance audit. The finding concerned the calibration (or lack thereof) of tape measures used on our production floor. These tapes are used to confirm lengths after a cutting operation. I am looking for a logical, simple method for calibrating tape measures. Does anyone have any "best practices" to share? I appreciate the assistance.
Dom-
Sponsored Links
Old 27th July 1999, 07:30 AM
ALM
Unregistered Guest
Posts: n/a
Question
I think that you may need to provide more information on the subject.
Are the tapes used to "determine acceptance of the product" for movement to the next function area or for shipment?
If not, label them as "reference tools" (assuming that you have some other method of measuring/testing the product for conformance to specification.
If they are, I believe that you may be in a pinch. Tape measures are subject to so much regular abuse, malformation, and other circumstances that would impact their accuracy (to some tolerances) --> you might find yourself hard pressed to keep them calibrated (or spend a ton of time rechecking them).
Apologies for only being semi-helpful. Throw some more details out there so that those more knowledgeable than I on the subject can give you some better advice.
ALM
Sponsored Links
Old 27th July 1999, 09:44 PM
QC4U
Unregistered Guest
Posts: n/a
Question
dscumaci: I must agree with ALM, more info is needed to give a helpful reply.
What type of verification is used at your facility to determine calibration of tape measures as specified under your calibration procedures?
GSH
Quality Mgr.
QS9000 Coordinator
Old 10th August 1999, 08:07 AM
dscumaci
Unregistered Guest
Posts: n/a
Gentlemen,
Thank you for your response and I apologize for the vagueness of the question. To clarify the matter, the tape measures are used to make accept/reject decision after steel bar has been cut. Tolerances for length of bar and plate range from 1/4" and 1/16". However, my question is what my be a logical means of calibrating the tape measures? Does anyone have experience implementing a process for calibrating tape measures? What are some options we may have?
Thank you for your help;
Dom
Old 10th August 1999, 08:40 AM
Roger Eastin Roger Eastin is offline
An Original Cover!
Registration Date: Dec 1998
Karma Power: 54
Roger Eastin has less than 100 Karma points so far.
You can't calibrate a tape measure (because you can't adjust it to bring it back into conformance), but you can verify aspects of it. You can verify that it is still readable and you can compare it to a standard (if you suspect warpage, for instance). One option is to verify it at incoming inspection and then establish reasonable intervals for verification. Also, come up with rules of action, such as what to do if the tape measure has been dropped or been exposed to unusual wear conditions.
Old 10th August 1999, 12:01 PM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Remember to keep in mind that you are required to calibrate equipment through their usable range. Purchase the right Tape measure for the job. To add to Roger's post, consider the things that break or become loose (i.e. the end-hook on the tape measure). Is there any play?
Old 10th August 1999, 04:26 PM
Batman
Unregistered Guest
Posts: n/a
Do you need to consider the "readibility" factor, where the measurement device must read one more decimal than the stated tolerance? 1/16 is .0625. Your device should be readible to .006? (1/125?) This may be splitting hairs, but could this be an audit target, and more importantly an issuue for you? I guess it depends upon the criticality of the measurement.
Old 11th August 1999, 05:04 PM
barb butrym barb butrym is offline
Courtesy Access
Karma Power: 63
barb butrym is appreciated, and has over 100 Karma points.barb butrym is appreciated, and has over 100 Karma points.
keep a steel rule for verification when tape gets worn/abused ...discard (or tag) and replace with a new one when wear reaches an unacceptable level...the steel rule comes in calibrated/verified or what ever........and if not heavily used has an infinitye cal cycle....or tap on one of 15 years.....You set the rules, what makes sence for you
Reply
Bookmarks
Tags
calibration, steel ruler, steel tape measure
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Calibrating or Verifying Metal or Steel Tape Measures trainee ISO 17025 - Calibration, Measurement Gages and Test Laboratories 126 18th November 2009 06:03 PM
Sufficient measurement of length - 4:1 TUR - Basic 25ft tape measures NWrubberQA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4 25th June 2009 10:07 PM
Need Tape Spec for MSCH 62 Full Tape Wrap & MSDC 13-B Spot Tape pancho Various Other Specifications, Standards, and related Requirements 3 14th September 2004 12:26 PM
Verbage to cover tape measures JRKH ISO 17025 - Calibration, Measurement Gages and Test Laboratories 6 1st December 2003 03:24 PM
Calibration of Tape Measures used for reference RLBredeweg ISO 17025 - Calibration, Measurement Gages and Test Laboratories 13 28th October 2001 09:38 PM
The time now is 04:12 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
