Go Back   The Elsmar Cove Forum > Information Resources - Papers - Articles - Etc. > Students and Educational Institutions > Student Research Questions - Any Educational Institution
Elsmar Cove Forum Visitor Notices
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 6th November 2004, 02:44 PM
anc1984 anc1984 is offline
Registration Date: Nov 2004
Karma Power: 21
anc1984 has less than 100 Karma points so far.
Truce Gage R&R concept - Nearly 50% of the QC engineers rejected the part
A component manufactured with finish process like surface grinding was handed over to a team of QC engineers. Each one made an as accurate measurement of dimension as possible, but it turned out after comparing notes, that nearly 50% of the QC engineers indicated the part to be out-of-tolerance range and hence classified it as 'Reject', while another set of QC engineers sweared that their measurements are correct and the part confirmed to dimensions and is a 'Pass'. How can I solve this problem in a technical manner that can be convincing to both the team of QC engineers. Assuming that a measuring instrument has defined measurement capability and the equipment is a standard measuring tool, explain how you would address and resolve this problem
Sponsored Links
Old 6th November 2004, 05:05 PM
Wes Bucey's Avatar
Wes Bucey Wes Bucey is offline
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Default Wow!
I have never before witnessed a situation where two separate camps of equally talented people have taken a completely polar view on whether a characteristic was in spec when both have access to the same instrumentation (which is how I interpret the situation you posit.)
I will follow this thread with interest. Is there anything more you can add so we might have a clue where the discrepancy between the two groups comes from?
Sponsored Links
Old 7th November 2004, 12:22 PM
Arvind Arvind is offline
E-Mails Invalid or Rejected
Registration Date: Oct 2004
Karma Power: 0
Arvind has less than 100 Karma points so far.
Default Make sure that resolution of gage is adequate for the purpose
Your question is general hence let me answer in a general way. If you have specifics, we will discuss these as well.
1) Imagine a precision engine component which has a very tight tolerance range of few microns on a nominal dimension.
In such cases, stabilizing of temperatures of part is very essential, otherwise the component dimension will change from morning to afternoon to evening.
Make sure that all measurement conditions are identical.
2) In above case where tolerance band is very narrow, selection of measuring equipment becomes very important. Generally CMM machines have a resolution of 1 micron. A general rule of thumb is that resolution of the gage should be atleast 1/10 the tolerance band.
Sometimes tolerance specification may not exist for a process output. Then, resolution of the gage should be 0.6 times standard deviation of the process or better.
Arvind
Old 10th November 2004, 03:22 PM
qualitytrec's Avatar
qualitytrec qualitytrec is offline
Father of 8!!
Registration Date: Jan 2003
Thanks Given to Others: 26
Karma Power: 44
qualitytrec is appreciated, and has over 400 Karma points.qualitytrec is appreciated, and has over 400 Karma points.qualitytrec is appreciated, and has over 400 Karma points.qualitytrec is appreciated, and has over 400 Karma points.qualitytrec is appreciated, and has over 400 Karma points.
Default
Are these QEs using an inspection instruction or procedure to help insure that they are all measuring the same way. For example is one group checking it while holding it, thus transfering body heat to it, whlie the other has it held by some sort of restraint that will not transfer the heat? Or is one checking it when the sun is shining through the window on it and another at a different time when the window is shaded? Something must be different. is one applying more presure to the instrument? Is the insrument shielded from body heat? What type of measurement is it and what tool are you using?
Also, how many QEs are we talking about here? And did they in fact use the same instrument?
I would be and am asking lots of questions.
I am interested in what might be found. Please keep us in the loop.
Mark
Old 10th November 2004, 05:09 PM
wmarhel wmarhel is offline
Courtesy Access
Thanks Given to Others: 109
Karma Power: 94
wmarhel is appreciated, and has over 1700 Karma points.
Default Need More Information
I'm with Wes on this, and my curiousity is peaked.
The original post was vague and I hope some additional information can be provided.
Wayne
Old 10th November 2004, 07:04 PM
howste's Avatar
howste howste is offline
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 377
Karma Power: 206
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
Default
Welcome to the Cove!
I'm guessing from the forum that this is posted in and the information in the poster's profile that this is a purely hypothetical question.
That being said, I would complete a gage R&R study (which should have been done before measuring to begin with). It may well show that the variation in the measurement system exceeds the tolerance on the part.
Old 10th November 2004, 08:03 PM
Vicman Vicman is offline
Involved - Posts
Karma Power: 24
Vicman is appreciated, and has over 100 Karma points.Vicman is appreciated, and has over 100 Karma points.
Default Look into length and direction
You may want to verify the setup of the length.
Normally the reading of the surface testers is an average of certain stroke length. You may want to check if is the same all the time.
Is the direction of grinding perpendicular or parallel to the gage sensor? This will affect the reading.
With so general information that my guessing considering there is an R & R already on this gage.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Gage R&R Study has Revealed No "Part to Part Variation" - My mistake? sinclasc Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6 28th November 2007 12:59 PM
Gage R&R - Using Tolerance method, or part to part variation? Ned-Sa Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1 27th March 2007 09:21 AM
How to select the part for Gage R&R Stevenli Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5 7th June 2005 09:01 AM
Tape Measures & Scales - Part Tolerance - Gage R&R Linda Miller Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 24 7th January 2004 12:03 PM
The time now is 08:45 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
