Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 12th November 2004, 06:03 PM
Joshua Sale Joshua Sale is offline
Registration Date: Nov 2004
Karma Power: 21
Joshua Sale has less than 100 Karma points so far.
Default Cpk analysis for +.000/-.004 problem
I have an problem with a couple of people understanding if a Cpk value can be determined off of the following specifications:
Spec for hole: .165 +.000/-.004.
One person is telling me no Cpk value can be determined b/c there is no nominal spec and that this is a 1-sided specification limit.
My statistical engineer states that for Cpk analysis there is no nominal needed and the USL is .165 and the LSL is .161.
I tend to agree with the stats engineer.
Please point me in the right direction of a article or book that will state one or the other view point correctly. I need to clearly give a direction so that the arguement may end.
Thanks for your help.
Sponsored Links
Old 13th November 2004, 04:00 AM
Al Rosen's Avatar
Al Rosen Al Rosen is offline
Registration Date: Jun 2002
Thanks Given to Others: 48
Karma Power: 192
Al Rosen is appreciated, and has over 1700 Karma points.
Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.
Send a message via AIM to Al Rosen
Default
This may help.
Calculating capability indices with one specification
Al
Sponsored Links
Old 13th November 2004, 10:39 AM
Arvind Arvind is offline
E-Mails Invalid or Rejected
Registration Date: Oct 2004
Karma Power: 0
Arvind has less than 100 Karma points so far.
Default Design unilateral tolerances need to be converted to bilateral tolerance for process
Unilateral tolerances are very common in engineering however these need to be converted to bilateral tolerance from process point of view.
In your case, even though design nominal is 0.165 +0/-0.04, you cannot take 0.165 as process nominal. If you do, then you run into risk bigger fraction or tail portion of population beyond specification.
For process people, the process specification needs to be 0.163+/- 0.02 which is conforming to randomly normally distributed output around the mean which coincides with target.
Arvind
Old 13th November 2004, 10:48 AM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
Joshua,
I would agree with your engineer.
This is not a one-side spec. A true one-sided spec would include the idea of "at least" or "at most". For example "the resistance should be at least 10,000 Ohms," or " the moisture content should be no more that 0.5%". Al Rosen gave a nice link to a webpage discussing one-sided specs where one of the limits is zero.
That is my interpretation, too, although I don't have a handy reference to appeal to. However, the equations themselves support this interpretation. Since the equations make no mention of a nominal or target value, all you need are the two spec limits from the customer, and the mean and st.dev. from the data.
Tim F
P.S. This points out one weakness of the whole idea of cpk. cpk measures the capability of staying within the spec limits, but in no way measures the capability of matching the desired nominal value.
Intuitively, a spec of .165 +0/-0.004 means you want the part as close to 0.165 as possible without going over, while 0.163 +0.002/-0.002 says you want the part as close to the middle as possible. If you can make parts with a tolerance of 3 sigma = 0.001, then in the first case you would want to set the nominal value somewhere near 0.164 to match the customers desire. However, making the parts closer to what the customer actually wanted would LOWER cpk from 2 to 1!
Old 15th November 2004, 11:11 AM
Darius's Avatar
Darius Darius is offline
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.
Default
I am not agree with the calculation of Cpk for one sided specs
http://elsmar.com/Forums/showthread.php?t=7047
or at least the statistic can obtain confusing conclusions, for example if
Quote: (Originally Posted by Joshua Sale) My statistical engineer states that for Cpk analysis there is no nominal needed and the USL is .165 and the LSL is .161.
If you use Cpk and the process is centered on 0.163, you would obtain the best results and it's typical that nearer the target (0.165) the better.
Vits er thorf, theim vitha ratar; daelt er heima hvat; at augabragthi verthr, sá er ekki kann ok med snotrom sitr.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Congratulations Cove and Marc - 100,000 posts in 10,000 Threads AllanJ Old Forum News and Issues Threads Archive 7 8th July 2009 12:15 PM
Root Cause Analysis - Mindset Problem patkim Problem Solving, Root Cause and Failure Analysis 35 30th June 2008 07:20 AM
Problem Analysis / Problem Solving - Toyota A3 Method Forms Qmarcello Nonconformance and Corrective Action 1 10th October 2007 08:59 PM
Ford to cut between 25,000 and 30,000 jobs in North America Marc Automotive News 8 27th January 2006 09:01 AM
Short Run Capability - Batch quantity is 15,000 to 20,000 Andrews SPC Monitoring and Statistical Analysis Techniques 5 11th March 2003 11:38 AM
The time now is 02:44 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
