Go Back   The Elsmar Cove Forum > National and International Business Standards > Various Other Specifications, Standards, and related Requirements
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 17th November 2004, 09:48 AM
Mike Smith Mike Smith is offline
Courtesy Access
Registration Date: Feb 2003
Thanks Given to Others: 1
Karma Power: 36
Mike Smith is appreciated, and has over 300 Karma points.Mike Smith is appreciated, and has over 300 Karma points.Mike Smith is appreciated, and has over 300 Karma points.Mike Smith is appreciated, and has over 300 Karma points.
Please Help! Does anyone have a copy of a generic Safety Manual?
Does anyone have a copy of a generic safety manual? I am not looking for something that quotes CFR`s or OSHA standards. I would like to see something written in laymans terms that is easy for all personnel to understand.
If no safety manual, how do other companies let their team members know about all safety requirements?
Sponsored Links
Old 17th November 2004, 11:15 AM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Registration Date: Mar 2004
Karma Power: 186
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Default
For a few months I did double duty as the Safety guy for a previous company. I went to the applicable gov websites and pulled down the regulations. http://www.osha.gov is the correct website I believe.
The Feds have OSHA, but if the state you are in is at least as tough, then the Feds will let the state do the job. CalOSHA is a prime example of that. I do not know about PA.
That would be a good starting point, but perhaps not the best one. It has the benefit of knowing all the requirements you may have to meet......the down side is there may be things that you need to meet that you do not currently know about. The research will tell you that.
Then write your own manual. Use the KISS (Keep It Short and Simple) rule, put in digital pics if possible. You will have to train everyone on the manual and keep records of the training. You will have to train everyone on RTK (Right To Know) information. RTK includes items like MSDS, which you must have and make available to all employees for any chemical.......from white-out to soap to floor cleaner to production chemicals. If you have a wood shop you must have the MSDS for the lumber and yes, wood does have MSDS.
Make sure HR is involved, they are a valuable resource in this kind of effort.
You will have to keep records of any and all injuries because that goes on the Form 100. I recommend installing an easy-to-use system where employees can let you know about unsafe conditions. You would then also need a follow-up, enforcement, and escalation capability built in. At the employer I mentioned, I installed the enforcement/escalation part. I actually shut down one entire process (quenching of hot freshly turned metal) for several days until the issue was solved.
Hope this helps.
Hershal
Sponsored Links
Old 17th November 2004, 12:01 PM
Al Rosen's Avatar
Al Rosen Al Rosen is offline
Registration Date: Jun 2002
Thanks Given to Others: 48
Karma Power: 192
Al Rosen is appreciated, and has over 1700 Karma points.
Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.
Send a message via AIM to Al Rosen
Default
If you do use google, you can find all you will need.
Al
Old 17th November 2004, 12:34 PM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,892
Karma Power: 604
Default
If anyone has a generic one it would be good to have one or more attached to a post here.
Old 17th November 2004, 12:53 PM
little__cee's Avatar
little__cee little__cee is offline
Part-Timer
Registration Date: Oct 2003
Thanks Given to Others: 13
Karma Power: 38
little__cee is appreciated, and has over 400 Karma points.little__cee is appreciated, and has over 400 Karma points.little__cee is appreciated, and has over 400 Karma points.little__cee is appreciated, and has over 400 Karma points.little__cee is appreciated, and has over 400 Karma points.
Default Two things
Excellent manual for download at http://www.dli.state.pa.us/landi/cwp...0#publications
and this Rules & Regulations page (if I can attach it) should help you in a general way, as far as what should be included (hopefully highlighting is able to be seen in the document for you)
***file too large*** will try to email it to you!
Old 17th November 2004, 01:38 PM
Marc's Avatar
Karma Power: 604
Default
Here's some food for thought.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Old 18th November 2004, 08:22 AM
gpainter gpainter is offline
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.
Default
Good info.
Old 18th November 2004, 09:59 AM
tarheels4's Avatar
tarheels4 tarheels4 is offline
E-Mails Invalid or Rejected
Registration Date: Sep 2004
Thanks Given to Others: 18
Karma Power: 0
tarheels4 is appreciated, and has over 100 Karma points.tarheels4 is appreciated, and has over 100 Karma points.
Default Lots of Powerpoint files and other stuff
http://siri.uvm.edu/
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
OHSAS 18001 Safety Manual example Backfromthefuture Occupational Health & Safety Management Standards 14 13th November 2009 02:44 AM
Generic Statement for Measurement Uncertainty for a Quality Manual D_Wood ISO 10013 - Quality Management System (QMS) Manuals 6 27th January 2007 02:59 PM
I want a copy of the AIAG PPAP Manual 4th edition Taurus80 APQP and PPAP 4 26th May 2006 06:21 PM
Daimler Chrysler SQM (Supplier Quality Manual) - Where to obtain a copy Mike1245 ISO 10013 - Quality Management System (QMS) Manuals 9 18th August 2004 09:56 AM
Seeking a copy of a quality manual geared towards ISO 17025 mph 407 ISO 10013 - Quality Management System (QMS) Manuals 15 9th July 2001 11:15 PM
The time now is 05:04 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
