Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 19011 and ALL Auditing Discussions > Process Audits and Layered Process Audits
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th November 2004, 08:43 PM
qualitytrec's Avatar
qualitytrec qualitytrec is offline
Father of 8!!
Registration Date: Jan 2003
Thanks Given to Others: 26
Karma Power: 44
qualitytrec is appreciated, and has over 400 Karma points.qualitytrec is appreciated, and has over 400 Karma points.qualitytrec is appreciated, and has over 400 Karma points.qualitytrec is appreciated, and has over 400 Karma points.qualitytrec is appreciated, and has over 400 Karma points.
Default The Checklist to ISO/TS16949-Is it a process audit or elemental?
My new replacement is here now and we are having a bit of a debate. He says the Checklist is a process based audit format. I say that it is identical in application to the old QS-9000 elemental audit. What do you all say?
Mark
Last edited by qualitytrec; 18th November 2004 at 08:45 PM. Reason: punctuation/title
Sponsored Links
Old 19th November 2004, 12:11 AM
Manoj Mathur Manoj Mathur is offline
Registration Date: Jun 2002
Thanks Given to Others: 5
Karma Power: 50
Manoj Mathur is appreciated, and has over 500 Karma points.Manoj Mathur is appreciated, and has over 500 Karma points.Manoj Mathur is appreciated, and has over 500 Karma points.Manoj Mathur is appreciated, and has over 500 Karma points.Manoj Mathur is appreciated, and has over 500 Karma points.Manoj Mathur is appreciated, and has over 500 Karma points.
Default
I think there is no point of debate. In ISO/TS 16949, Both type of Audit Checklists are required. One checklist which we are using is based on Elements of TS2. I consider this is a generic checklist and if require, I can either mail it to you or post on this Forum. Another checklist is Process Audit checklist and Product Audit Checklist. Both checklists are based on Our Specific Process as well as Products. We have two seperate TS Certifications, one for Aluminum Alloy Wheel Rims and another one for Aluminum Foil. Since both pprocesses and products are different, we use four different checklists.
Manoj
Sponsored Links
Old 19th November 2004, 09:41 AM
db's Avatar
db db is offline
Where's the shall?
Registration Date: Jul 2001
Thanks Given to Others: 208
Karma Power: 129
db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.
Default
The IAOB checklist was very similar to the QSA, so much so, that it is no longer used. If you have a copy, there is one thing that is very interesting. A graphic that outlines what parts of TS are process driven, and what parts are driven by documentation of information. For example, document control (4.2.3) is a process, but the quality manual (4.2.2) is document drivern.
As we develop/implement/audit our systems, we must be able to audit both the process-driven parts, and those parts that are not process oriented.
Dave B (the other Dave)
Old 19th November 2004, 07:25 PM
Father of 8!!
Karma Power: 44
Default
Ok I can see that there is need of more info. My replacement is saying that the TS checklist is a process audit therefore we just need to go through it. By the way we are only going for ISO 9001 so there is a fair amount of overlooking that we would do.
I do have a checklist already made out that has only ISO elements in it. I do tend to agree that both elemental and process audits are necessary but some other threads have left me wondering. My lazy side hopes that they are right but my self-protective side is not willing to stick my neck out that far yet.
Mark
Old 23rd November 2004, 10:06 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Thanks Given to Others: 1
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
IMO, if you are not pursuing TS2, do not use a TS2 checklist. If you have your own ISO checklist, use it.
A checklist is a checklist is a checklist and should not be confused with the "art" of process auditing. The checklist that AIAG suggests is still an elemental checklist, regardless of how they try to color it.
Sam Goody
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
ISO 13485 Practical Internal Audit Checklist - Standard vs. Process Based ISO MAN Internal Auditing 17 6th November 2008 09:41 AM
Process Audit Checklist to document Internal Process Audit results jim543 Process Audits and Layered Process Audits 19 16th September 2008 06:55 PM
Process audit in compliance with ISO/TS16949 dalydouna Process Audits and Layered Process Audits 3 10th May 2007 03:31 AM
TS/ISO 16949 Process Audit Checklist required S.Chaichana Process Audits and Layered Process Audits 3 14th April 2007 08:23 AM
How to create an Process Oriented ISO 14001:2004 Audit Plan & Checklist deva_rhs ISO 19011 and ALL Auditing Discussions 20 10th February 2006 09:37 PM
The time now is 03:57 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
