Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 30th May 2000, 03:46 PM
narfeldt
Unregistered Guest
Posts: n/a
Spin! MSA - tools and equipment
I help a company with implementation of QS9000 and it´s MSA.
My question is wich tools and equipment should be analysed?
How often should I analys our tools and equipment?
Sponsored Links
Old 30th May 2000, 08:19 PM
chen
Unregistered Guest
Posts: n/a
#1 which tools and equipment should be analysed?
-> all of the measuremnet systems for inspection and testing under QS scope.
#2 How often should I analys our tools and equipment?
-> no standard. we follow our procedure for msa control and do it quarterly.
-> i think that is no problem if you define the frenquency and follow it.
gary chen
Sponsored Links
Old 31st May 2000, 04:00 AM
Martin
Unregistered Guest
Posts: n/a
Chen,
A question for you because we also do a MSA on all our equipment, but to my opinion you can only do a MSA on the equipment concerning special characteristics. What is your opinion on that? Because I heard an auditor say that this is enough!!
Hope to hear from you!
Greetings,
Martin
Old 31st May 2000, 09:06 AM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,892
Karma Power: 604
Yin Yang
"...#1 which tools and equipment should be analysed?..."
Only M&TE which is used for inspection / test (such as for measurement of 'special characteristics') must be calibrated and have an R&R or other uncertainty analysis.
"...#2 How often should I analys our tools and equipment?..."
Do a search here for "frequency" or "calibration frequency" (without the quotes). Calibration frequency depends upon the equipment and what it is used for. Many companies start off using the manufacturer's recommended frequency unless they have similar equipment and extrapolate from that.
As far as R&R, typically once a year.
Old 31st May 2000, 09:58 AM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Only those tools that are covered under 'Control Plan' (as Marc Smith has mentioned above) NEED to be taken under MSA, unless there are any customer specific requirements.
As for frequency, you again need to consult your customer. I have seen customers who insist on an R&R report with every consignment!
-Atul
Old 31st May 2000, 08:26 PM
chen
Unregistered Guest
Posts: n/a
Martin:
if you want to do a MSA only on the equipment concerning S.C,i think it is better to get a waiver from your customers(big3 or ...). we aslo got a waiver from Delphi-Delco for some M&TE we did not want to perform a Msa study on.
have a nice day!
gary chen
[This message has been edited by chen (edited 31 May 2000).]
Old 31st May 2000, 11:45 PM
Laura M's Avatar
Laura M Laura M is offline
Courtesy Access
Registration Date: Aug 1999
Thanks Given to Others: 3
Karma Power: 70
Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.Laura M is appreciated, and has over 500 Karma points.
Send a message via AIM to Laura M Send a message via Skype™ to Laura M
"did not want to " or didn't make sense too.
Personally, I think "waivers" take more time than the common sense approach. If common sense is used by the supplier and registrar, then less bother to the customer for "waivers"
I remember an auditor insisting that ALL inspections are on a Control plan, then MSA's are required for all measurements specified on a control plan. Hours spent doing attribute R&R's with no common sense on what the product needs really were.
Old 1st June 2000, 05:53 PM
mbruner
Unregistered Guest
Posts: n/a
RE: Quote
"..auditor insisting that ALL inspections are on a Control plan, then MSA's are required for all measurements specified on a control plan."
Chrysler requires GRR on all gages used in the process, regardless of whether they're in the control plan.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Attribute MSA of Automatic Inspection Equipment Bobbinz Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7 10th November 2009 07:46 PM
Control of Production Equipment, Tools and NC Programs: 7.5.1.3 Lorenzo36 AS9100 Aerospace Standard and Requirements 6 13th August 2008 06:21 PM
Guidelines to determine which equipment to do MSA on Urias Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10 13th August 2008 08:46 AM
How to perform MSA for PLC-interlocked torque tools BenL712 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 7th August 2007 09:59 PM
MSA on tensile strength equipment TL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7 2nd December 1999 04:02 AM
The time now is 04:53 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
