Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 5th December 2004, 01:20 PM
Dominic
Unregistered Guest
Posts: n/a
Question Questions about Taguchi style Designed Experiments (DOE)
Have some question I have to answer for uni so any help greatly appreciated.
1. In a taguchi style designed experiment a confirmation run is necessary to,
a) identify secondary control factors
b) confound the control factors
c) disaggregate any interactions present
d) check the accuracy of the prediction
2. Taguchi style designed experiments are called
a) full factorials
b) fractional factorials
c) EVOP
d) response surfaces
thanks in advance to anyone who can help.
Dom
Last edited by Claes Gefvenberg; 5th December 2004 at 03:23 PM. Reason: Title expanded
Sponsored Links
Old 5th December 2004, 03:28 PM
Claes Gefvenberg's Avatar
Claes Gefvenberg Claes Gefvenberg is offline
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Quid Pro Quo
Hello Dom,
I am not very good at Taguchi, but while we wait for someone who is, I wish you welcome to the Cove
/Claes
Hanlon's Razor.
Never attribute to malice that which can be adequately explained by stupidity.
User Groups: Elsmar Cove Cycling Enthusiasts Formula 1 fanatics Photo freaks Readers Corner
Sponsored Links
Old 5th December 2004, 05:12 PM
Wes Bucey's Avatar
Wes Bucey Wes Bucey is offline
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Default
Originally Posted by Claes Gefvenberg
Hello Dom,
/Claes
s
Nutek, Inc. Quality Engineering Seminar, Software, and Consulting ( Since 1987) offers this description (found at http://www.rkroy.com/wp-sps.html):
Standardized Application Steps for Taguchi Experiments
PLAN – Experiment planning is the necessary first step in conducting experimental investigation. The problem solving team spends a day with experienced facilitator (consultant) to determine parameters and scopes of the study.
PRESCRIBE – Based on the discussions in the planning session, an experiment is designed. The prescription also includes individual test recipes and the data collection schemes.
PERFORM – Experiments are carried out as per the recipes and the results recorded.
PREDICT – Results of the experiments are analyzed and the condition for best solution is identified. Improvement expected from the new solution is also estimated.
PROVE - The predicted solution is tested with additional tests and prediction confirmed before changes are incorporated.
Nutek uses the term "full factorial" but I doubt they use it, since Taguchi's innovation had to do with fractional factorials - actually VERY fascinating to know and to use.
my advice:
Google the following search terms:
taguchi +experiments
taguchi +factorials
Comment:
Personally, I dislike this type of test or homework question from a professor because having the answer does not imply you have a clue what the answer means. If I were a student, I would want the professor to help me learn the difference between full and fractional factorials. I would want to know "why" I should go into proving or confirming my experimental results before committing resources to full production.
I know the answers on Taguchi, but I firmly believe in the philosophy
"Give a man a fish, you feed him for a day;
Teach a man to fish, you feed him for a lifetime."
(When you pay for schooling, you pay for knowledge, not the grade.)
Oh, yes. Welcome to the Cove, a place where we help you learn, but rarely just give simple answers you can get from an encyclopedia.
Old 5th December 2004, 07:52 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
Dominic,
Following up on what Wes said, simply getting an answer to a multiple choice question won't really help you understand. I think you'll find that most people here are happy to discuss topics, but unwilling to simply do your homework .
As a compromise, why don't you tell us what you think? Explain what you understand about the question and the different possible answers. Then we will know where you are coming from and perhaps someone can provide you with some real knowledge.
Oh, and welcome to the Cove. If you stick around and get involved, you will discover that there are a lot a people here with a lot of first-rate knowledge covering just about every facet of quality.
Tim F
Old 5th December 2004, 08:31 PM
Dominic
Unregistered Guest
Posts: n/a
Default
For the second question I think the answer is fractional because one has no effect on the other.
But for question one i really dont have the faintest idea. I understand everyones comments but I have notes from all his lessons and half the questinos he did not even talk about.
So im finding it a challenge.
I know I should go and talk to him, but he is never around.
Please confirm if my answer to question 2 is correct or not.
thankyou
Old 5th December 2004, 11:40 PM
Wes Bucey's Avatar
Quality Manager
Karma Power: 397
Default
thankyou
If you are still guessing for Question #2, you need to read some more outside material about Taguchi and his "shortcuts" for design of experiments (DOE) - do the Google thing as I suggested. Especially make sure you get a feel for what is meant by a "Latin Square." It may take some time, but ultimately it will be more valuable to you than us giving you the answer.
Even with the minimum information contained in my first post, you should be able to get the answer to Question 1.
Old 14th December 2004, 09:06 PM
alfawei alfawei is offline
Registered Visitor
Registration Date: Aug 2004
Karma Power: 22
alfawei has less than 100 Karma points so far.
Default
I like this words:
these questions were found in China's Sixsigma Book
Originally Posted by Wes Bucey
s
my advice:
taguchi +factorials
Comment:
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
DOE Integrated Methodology - Traditional DOE vs. Taguchi Methods vs. Shainin Techniqu Luis Serrano Quality Tools, Improvement and Analysis 7 26th October 2009 12:35 PM
What if DOE (Design of Experiments) is not possible? pagnonig Six Sigma 16 29th September 2007 04:17 PM
DOE - Design of Experiments? What does that mean? amanbhai Quality Tools, Improvement and Analysis 5 16th May 2006 10:37 AM
DOE - Design of Experiments - Shainin Andrews Design and Development - Process and Product 7 10th October 2003 11:44 AM
Shainin vs. Fisher vs. Taguchi DOE Andrews Quality Tools, Improvement and Analysis 9 26th August 2003 12:10 PM
The time now is 03:16 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
