Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 14th August 2000, 03:45 PM
dhillsburg
Unregistered Guest
Posts: n/a
Default Previous Inspections - Gages used to calibrate other gages
We are a just in time manufacturer. We satisfy 4.11.2 (f) by accessing current production with a known good gage and infering past production OK. My question is how does this requirement apply to gages used to calibrate gages,etc.? For example, if I have a shadow graph that is calibrated by an outside service, found to be out of calibration, how do I perform an assessment of the validity of previous inspections when I could have used that gage to check many other gages used in production, incoming inspection parts, fixtures etc...how do I handle nonconforming specialized gages like this in terms of requirement 4.11.2 (f)?
Sponsored Links
Old 14th August 2000, 05:03 PM
Jerry Eldred's Avatar
Jerry Eldred Jerry Eldred is offline
Registration Date: Dec 1999
Karma Power: 89
Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.
I Say...
You note the amount of the out of tolerance reading on the gage you sent to the outside vendor. You then use that to determine the amount of induced error in the gages it was used to calibrate. Determine from that if there were any erroneous in-tolerance or erroneous out-of-tolerance readings on those gages. If the accuracy of your standard gage was enough better than those gages it was used to calibrate, you MAY find that there was no implication. But you must determine if there was or was not erroneous results as described above. Hopefully the standard gage was much higher accuracy than those gages it was used to calibrate (at least 4:1 ratio of uncertainty). Final step is to evaluate those gages that were erroneously found in-tolerance or erroneously found out-of-tolerance. Compare the amount of this error with your process or product specifications (hopefully in this case, you had a suitable ratio between the accuracy and stability of the gages that were calibrated by your standard, and the specification limits of your process.
If the erroneous findings on the gages caused erroneous measurement results on your product, you then need to make a formal determination as to if any containment or other corrective actions need to be taken to assure no defective product reaches the customer. And, of course, it all needs to be well documented.
I have tried to walk through the stages of an out-of-tolerance evaluation. This situation underscores the importance of using adequate standards (I don't know whether yours are or not). But the point is to make sure that a standard is of adequate test uncertainty ratio between the standard and the units to be calibrated. This gives you breathing room, so that when a standard is out of tolerance, quite often there will be no impact to product due to the guard band. And the same is the case with measurement tools used for product. It is always wise on any measurement tool that measures an important or critical parameter on your product or process, to assure it is preferrably a little too accurate for the process (using good MSA methodologies as a determinant, and whatever other statistical techniques are appropriate). With these two guard bands in place you minimize the possibilities of things (for example) like having to do a tire recall. I won't throw any stones at that one. But when ever these things happen, they remind those of us in metrology that we have a responsibility that can sometimes effect peoples lives. Sorry... got on my soapbox.
Anyway, hope this is of some help.
Sponsored Links
Old 16th August 2000, 09:53 AM
dhillsburg
Unregistered Guest
Posts: n/a
BIG Smile
Thank you for your answer. I will implement as you descibe. I appreciate your response and it was most helpful.
Diane
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Calibration Of Plug gages (G0-No Go Tri lock gages) mr500 ISO 17025 - Calibration, Measurement Gages and Test Laboratories 11 14th October 2009 06:25 PM
The Best Way to Calibrate Radius Gages kat.k. ISO 17025 - Calibration, Measurement Gages and Test Laboratories 22 15th July 2009 06:05 PM
How to Calibrate or Verify Screw Pitch Gages ScottBP ISO 17025 - Calibration, Measurement Gages and Test Laboratories 14 1st May 2008 11:39 PM
Calibration of Home Made Gages - Simple go/no-go gages to true position gages beaser3 ISO 17025 - Calibration, Measurement Gages and Test Laboratories 8 3rd April 2008 04:55 PM
For Reference Only gages to appear on Master List of Gages? noboost4you ISO 17025 - Calibration, Measurement Gages and Test Laboratories 10 2nd May 2007 05:03 PM
The time now is 04:41 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
