16th December 2004, 01:34 PM
Email Activation Not Completed
Registration Date: Apr 2004
Karma Power: 0 Karma: 10
Capability study - What Values do I have to input to calculate Cp and Cpk
Hello all,
I’m doing a capacity study and I have a doubt concerning the value that I will input in the system to calculate de Cp & Cpk The specification is 30.00-0.70mm (Spec. 29.30-30.00mm) and the values measured are 29.60-29.94mm in the same dimension. As you can see, for the same dimension I have 2 different values. Now you are thinking “Simple, correct the dimension in order to obtain an equal value”  Not so simple, the piece is functional and this is more an injection problem very difficult to correct concerning the piece geometry.
My question is:
- Should I input minimum values and I have a good Cp and Cpk?
- Should I input maximum values and I have a good Cp and a bad Cpk?
- Should I input an average values?
- None of above suggested?
In advance, thanks for your opinion.
16th December 2004, 01:45 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Capacity or capability?
16th December 2004, 06:15 PM
Involved - Posts
Registration Date: Oct 2004
Thanks Given to Others: 5
Karma Power: 46
IMHO, you need to understand the functional dimension. As an example, for a hole diameter, I would use the diameter of the largest pin which could pass through the hole. Although you could get (with sufficient resolution on your instruments) an infinite number of values for the 'diameter', depending on the number of points taken, etc, there is only ONE value for the maximum size pin which will pass through. This is the 'Functional Diameter', is the the actual characteristic which will (most often) be of importance to the customer.
If you can provide more information, I'd be happy to take another stab at it.
Ron S Rompen
Goju Ryu
Kitchener, Ontario
Do other dogs think that poodles are members of some strange religious cult?
17th December 2004, 05:08 AM
Hello Marc... I mean capability. Only a translation problem
17th December 2004, 05:18 AM
Karma Power: 605
Did Ron's reply help out? He asked for more info for a more detailed response.
17th December 2004, 05:22 AM
Hello Ron,
Yes... my opinion is the same. I think I must use the functional value, although I must analyse the other value to see if don’t interfere in piece functionality. Well in this case, one of both is good, because the piece is a roll to be applied in refrigerators. Thank you for your help.
17th December 2004, 01:48 PM
Registration Date: Jan 2003
Thanks Given to Others: 265
Karma Power: 137
are the two values dependent or independent of each other? (in other words, is oen always larger than the other? this woudl be dependent. If the 2 values are randomly distributed within a piece they are independent...)
18th December 2004, 06:04 AM
Hello Bev,
Both values are measured in the same dimension. The minimum value, in my opinion is the real value and is always constant (good for a good Cp  ), the maximum value is caused by a little burr in the split line and is randomly (sometimes high... sometimes low). This burr don’t interfere in piece functionality and is accepted by our customer.
