Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Measurement Uncertainty (MU)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 26th September 2000, 02:00 PM
ralutz
Unregistered Guest
Posts: n/a
Question Differences between Test Accuracy Ratio (TAR) and Test Uncertainty Ratio (TUR)
Can anybody explain the differences between Test Accuracy Ratio (TAR) and Test Uncertainty Ratio (TUR)?
Sponsored Links
Old 26th September 2000, 11:31 PM
awk
Unregistered Guest
Posts: n/a
ralutz:
I am under the impression they are the same, used to evaluate and express measurement uncertainty, however I am not positive about this.
The website for the National Institute of Standards and Technology, NIST, might provide you with a more informative answer.
awk
Sponsored Links
Old 27th September 2000, 12:50 PM
Jerry Eldred's Avatar
Jerry Eldred Jerry Eldred is offline
Registration Date: Dec 1999
Karma Power: 89
Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.
BIG Smile
They are pretty close, but I think there is a little difference between them.
Uncertainty is the combined inaccuracy of a measurement. In a calibration context, if there are multiple instruments used to make a calibration measurement, if you used the Roo Sum Squares (RSS) method to calculate a total uncertainty, that would fall under the 'uncertainty' umbrella. The total uncertainty of a measurement may simply be the accuracy tolerance of a measurement standard. Or in the case of multiple instruments, and perhaps if environmental variation is a contributing factor, that amount of variation would also be factored in. Uncertainty refers to making a measurement.
Accuracy on the other hand refers to the plus and minus tolerance of an instrument.
TAR is a simpler quantity, referring to the ratios of the accuracies of two pieces of equipment. In calibration, uncertainty is prabably a more correct term. Where as in some other simpler applications, accuracy may be applicable. If you are using a hand held multimeter with a stated accuracy of +/- x% DC volts to adjust a power supply that has a stated accuracy of +/-y%, TAR would be appropriate. A complicated temperature calibration system with multiple instruments and opportunities for error would need to all be calculated together and a measurement uncertainty calculated.
Old 29th September 2000, 10:40 AM
Graeme C. Payne
Unregistered Guest
Posts: n/a
Quid Pro Quo
Another way to approach this is to remember the subtle difference between accuracy and uncertainty.
Accuracy is usually a design specification of a product feature. Uncertainty is always a performance characteristic of a measurement process.
I usually explain the TAR/TUR difference like this:
When you are using an instrument to measure a product, the specified accuracy (uncertainty) of the measuring instrument must be X times better than the accuracy tolerance of the feature being measured. That is a Test Accuracy Ratio.
When you are calibrating a measuring instrument, the uncertainty performance of your calibration measurement process must be X times better than the measurement uncertainty (accuracy) of the instrument being calibrated. That is the Test Uncertainty Ratio.
The difference is subtle, real, and usually does not make much difference.
Graeme C. Payne
ASQ Certified Quality Engineer
Graeme@asqnet.org
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
TUR (test uncertainty ratio) based on Standard or Expanded Measurement Uncertainty? ScottBP Measurement Uncertainty (MU) 2 25th March 2009 11:04 AM
Test Uncertainty Ratio TUR (UUT Tolerance / STD Uncertainty) Question jfgunn ISO 17025 - Calibration, Measurement Gages and Test Laboratories 2 13th November 2007 04:40 PM
TAR (test accuracy ratio) vs. TUR (test uncertainty ratio) - The difference is..? Charles Wathen Measurement Uncertainty (MU) 2 20th March 2004 06:25 PM
How to calculate TUR (Test Uncertainity Ratio)? prasanna_9975 ISO 17025 - Calibration, Measurement Gages and Test Laboratories 1 17th April 2001 01:21 PM
Measurement Risk Management - 4:1 Test Accuracy Ratio Guardband Mike Czech ISO 17025 - Calibration, Measurement Gages and Test Laboratories 1 20th December 1999 12:39 PM
The time now is 12:40 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
