Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
30th December 2004, 02:49 PM
Email Activation Not Completed
Registration Date: Mar 2002
Karma Power: 0 Karma: 107
Digital Caliper Calibration vs. Verification - Full Scale vs. Used Range
I have a question regarding the calibration / verification of Digital Calipers.
If my company uses calipers to measure parts up to 1 1/2 " only, would it be acceptable for me to verify the 6" calipers from 1 - 2 " with my gage blocks over that range and not send them out for calibration to an outside company?
Jen
Reason: fix typo in headline for better use by search spiders
30th December 2004, 03:06 PM
Metrologist-Auditor
Registration Date: Mar 2004
Thanks Given to Others: 1
Karma Power: 265
Only thing to consider here is: What is the likelihood that the calipers will ever be used outside the 2" range?
If none (or almost none), then calibrating to only the needed range is advisable. Caliper calibration is cheap so ou may not save any mone, but ask.
Of course, I always recommend using an calibration lab accredited to SO/IEC 17025.
Hershal
30th December 2004, 03:18 PM
Lab Manager
Registration Date: Jun 2004
Thanks Given to Others: 19
Karma Power: 87
Hi Jen, ,my experience is a little dated, as I left when the Mechanical Testing lab I ran was transitioning from ISO Guide 25 to ISO Guide 17025 about 4 years ago. That said, in our case the supervisor (me) was responsible for quarterly calibration of the digital electronic calipers we used. The calipers were used to measure elongation from tensile testing of flat rolled stainless steel. The primary measurement area was between 2" and 3", 2" being the initial measurement before beginning tensile testing and 3" being reached or exceeded only on rare occasions. I used gage blocks to check over the ranges we'd typically use, beginning with verifying the zero location, then checking at 1/2", 1", 2", 3" and 4". If they were off, I had some adjustments I could do to bring them into calibration, or could send them out for work & recalibration by an external source. On a daily basis, they were verified by each turn by checking the zero value and then verifying against a 2" gauge block. At that time the program satisfied our Guide 25 registrar - A2LA.
Of course, we also did round robin testing of tensile specimens that was reported to both us and our registrar. That testing included comparing all results from specimens prepared and tested by the lab including elongation.
Hope the information helps in making your decision.
3rd January 2005, 11:20 AM
Thank you for your replies!
Jennifer
6th January 2005, 12:46 PM
E-Mails Invalid or Rejected by Recipient System
Registration Date: Jul 2004
Karma Power: 0 Karma: 48
Hi Jen,
Yes, perfectly acceptable. I am wondering if you do any calibrations in house or do you send them all out? Seems like a waste to send out a 6" digital caliper for calibration if you have your own gauge blocks and a few basic tools.
If you have gauge blocks you can do your own calibrations; you would just need to record the results and the procedure you used.
Roger
In Reply to Parent Post by JSmith
Jen
7th January 2005, 08:46 AM
Hi Roger,
I have gage blocks to calibrate the od side. Will I need to calibrate (verify) the ID side as well? If so do I have to use a set of ring gages or could I use certified micrometers to calibrate the ID?
Thanks for your help,
Jennifer
7th January 2005, 09:04 AM
Lab Manager
Karma Power: 87
Jen, If you're using both ID & OD sides of the calipers you need to calibrate both. You can end up with a minor, visually undetectable flaw that will invalidate the measurement. I've used micrometers to verify the ID jaws of a digital caliper by first using a gage block to set the micrometer, locking the micrometer, then calibrating the ID jaws of the caliper, then double checking the locked micrometer with the gauge block. This was acceptable to our A2LA auditors for an ISO Guide 25 mechanical testing lab at a steel mill.
7th January 2005, 12:13 PM
Hi again,
I agree totally with what Kevin said. You can also use master rings if you have them.
Roger
Forum Posting Settings
