7th January 2005, 05:02 AM
Registered Visitor
Registration Date: Nov 2003
Karma Power: 25
Evaluating Process Stability - Unstable Processes - Cpk/Ppk?
Is there any ideas how to see if our processes are stabel or instabel?
Evaluating Cpk/Ppk is one way?
You can evaluate on a Xbar R diagram over the time the process runs?
Is there any other ways/hints to evaluate the stability of a process?
Thanks!
/Niotusen
7th January 2005, 07:57 PM
Involved - Posts
Registration Date: Jun 2002
Karma Power: 31 Karma: 10
Control methods
Hi
Search for pre control in this forum.
Instead of Xbar and R you can use other "XY charts" as Individuals with moving average.
Depending on your process (administration or manufacturing) you can use charts over defects/not good ie PPM, dpmo.
7th January 2005, 09:59 PM
Deming Disciple
Registration Date: Feb 2004
Thanks Given to Others: 60
Karma Power: 190
Thanks!
/Niotusen
Cpk and Ppk will NOT tell you if a process is stable. In fact, in order for Cpk or Ppk to be meaningful at all, the process must be stable prior to making those calculations.
One way (and probably the most common way) to tell if the process is stable is to use Statistical Process Control (control charts). SPC includes using rules that will tell you if the data (and by inference the process) are stable. It is best if you have at least 25 data points, but you can tell if the process is not stable well before 25 points many times.
You may find one way to do SPC at my company's website at http://www.hanford.gov/safety/vpp/trend.htm. This is the procedure we use. There are variations out there.
Steve Prevette
"A Passionate Statistician", ASQ CQE, Fluor Government Group
The opinion stated above does not necessarily reflect that of my employer.
10th January 2005, 10:48 AM
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
It's not a common way to put stability but...
Cpk/Ppk or Cp/pp is known as inestability index and is nothing else but Total_variation / Variation_within, and altho it it self doesn't show a process stability, it's true that the nearer to 1 the total_variation and within_variation estimates are more or less equal and if variation is equal ( and you take for granted that the mean of the process hasn't change) desto the process is stable.
beware of the taken something for granted, but for variability is a nice measure (altho no magical number for stability in such index exist, as far as I know).
Vits er thorf, theim vitha ratar; daelt er heima hvat; at augabragthi verthr, sá er ekki kann ok med snotrom sitr.
10th January 2005, 12:24 PM
Courtesy Access
Thanks Given to Others: 1
Karma Power: 46
Steve,
You are right on the money! Where is Shewhart when you need him! I think that the old Western Electric rules would help here. . .at least as a staring point.
If something is over engineered. . . it will probably be under manufactured! (Jim Eustace 1993)
14th January 2005, 09:35 AM
Registration Date: Sep 2002
Karma Power: 31 Karma: 71
Niotusen,
May I recommend that you do some studying on process control and capability. There are many books and websites that can be of immediate help. I personaly like the approach to process control taken by Donald Wheeler.
Keep asking questions here at the Cove; there are some very talented and experienced individuals here who will help with great patience.
You are starting a fastinating journey; I wish you well.
Ben
31st January 2005, 03:58 PM
Registered Visitor
Karma Power: 25
Thanks a lot"
I ´ve started my journey!
I´ll be back!
Thanks a lot!
/Niotusen
Similar Discussion Threads
| Discussion Thread Title |
Thread Starter |
Forum |
Replies |
Last Post or Poll Vote |
Calculation of Cpk and Ppk for an unstable process
morteza |
SPC Monitoring and Statistical Analysis Techniques |
7 |
29th December 2008 10:15 AM |
Cpk vs. Ppk - Long Term vs. Short Term - Capability vs. Stability
DJN |
Capability, Accuracy and Stability - Process, Machine, etc. |
25 |
15th March 2006 01:26 AM |
Validation of Cpk and Ppk calculations - Sheet to check Cpk and Ppk values
Howard Atkins |
0 |
20th February 2006 03:41 AM |
Ppk - Seeking short-term study examples - Chronically unstable processes
Joe_winter |
8 |
27th November 2004 03:14 AM |
Evaluating software that measures Ppk, Cmk, Cpk, PPI, etc.
Cemm Mex |
5 |
21st June 2004 09:28 PM |
