Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 10013 - Quality Management System (QMS) Manuals
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 13th January 2005, 04:33 AM
najwa najwa is offline
Registration Date: Dec 2004
Karma Power: 20
najwa has less than 100 Karma points so far.
Please Help! If we have a complete procedure in our Quality Manual do we need another one?
Hello...
I need some explanation about quality manual and documented manual (procedure). What we practice in our organisation now, we have our own quality manual, which describe all department procedures. But, we also have another file, which include all kind of forms and procedure that we use in our system.
My question is, if we have a complete procedure in Quality Manual, is it a must we need another procedure (flow chart) in the documented file (all the form and procedure) ? It look like 'double entry'.
Another question is, what would happen if, there is no procedure for Department A (as example) in Quality Manual, but it have in the documented file, which clearly expain about the procedures, person in-charge and form/record be used?
Hope to hear a respon from the member. Thank you
Sponsored Links
Old 13th January 2005, 10:46 AM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Registration Date: Mar 2004
Thanks Given to Others: 1
Karma Power: 186
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Default
What standard are you working with?
Accreditation: ISO/IEC 17025, 17020, or 17024
Registration: ISO 9001, TS 16949, or similar
Hershal
Sponsored Links
Old 14th January 2005, 01:29 AM
bpritts bpritts is offline
Involved - Posts
Registration Date: Aug 2003
Thanks Given to Others: 2
Karma Power: 38
bpritts is appreciated, and has over 400 Karma points.bpritts is appreciated, and has over 400 Karma points.bpritts is appreciated, and has over 400 Karma points.bpritts is appreciated, and has over 400 Karma points.
Default
Najwa --
When you say that there are documented procedures "separate" from the quality manual, that leads to a question.
Do the procedures and forms get the same (or similar) control as the quality manual? Are they reviewed and approved, and kept up to date?
Are people doing the process according to the documented procedures?
Have they been trained consistently?
If so, then it shouldn't matter a great deal. As long as you have "work instructions, if applicable (ISO 9001:2000, 7.5.1 (b), you are covered
whether these documents are in the quality manual or not.
If one of these conditions is not met, then you may have a concern -- at least, if you are trying to follow ISO 9001 or a similar standard.
On the other hand, if you have 2 different procedures for doing the same
thing, I would be concerned. Sooner or later the 2 procedures may
come in conflict. Then what?
Regards,
Brad
Old 14th January 2005, 03:07 AM
Karma Power: 20
Default
Hershal
we are working with ISO 9001:2000
Old 14th January 2005, 03:20 AM
Karma Power: 20
Default
Originally Posted by bpritts
Najwa --
Regards,
Brad
Yes, all the form and procedure are follow the Quality Manual, and be reviewed and verified, and up to date. The person who use the form will also be trained to fill in.
That mean, it's ok we have one complete procedure in Quality Manual and another one in the documented file. Yes, we have work instruction which we filing in the documented file.
So, it doesn't matter we have a procedure in documented file but not in the Quality Manual, or we have both. And it should not have any conflict between it. Is it right?...
Old 14th January 2005, 02:54 PM
RCBeyette's Avatar
RCBeyette RCBeyette is offline
When in doubt - THINK!
Registration Date: Jan 2002
Thanks Given to Others: 113
Karma Power: 217
RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.
RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.RCBeyette is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to RCBeyette
Default
My take is that if the complete (and adequate) process is documented within your Quality Manual, you have technically met the requirements of ISO 9001:2000.
Here is my concern....processes change...thus documentation changes. And frequently, too. By putting all of this detail within your Quality Manual, you run the risk of having to update your Quality Manual frequently and for many of us, that is a rather heavy task to do. I do not know if your organization is the same, Najwa.
Personally, I try to leave the details out of the Quality Manual. If someone wants to know how to do something, like an Internal Audit, she or he can go and find the separate document on it.
For what it's worth, our Quality Manual is at Revision 5....since 1998. Our WI on audits is at revision 10, since 1998.
~ Roxane ~
"There's a fine line between genius and insanity. I have erased this line." - Oscar Levant
Old 14th January 2005, 10:30 PM
Karma Power: 20
Default
Ok, i've got the idea. That means the WI must tally with Quality Manual. And it should be revised if any changes in WI.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Complete ISO idiot on a steep learning curve - Quality Manual Review appreciated Ciaran ISO 9001 - Quality Management Systems Standard 9 23rd June 2009 06:45 AM
Advice on a Procedure that is contained in our Quality Manual avy100 ISO 9001 - Quality Management Systems Standard 22 25th February 2008 01:03 PM
Documented Procedure in Quality Manual Alan Au ISO 13485 - Medical Devices - Quality Management Systems 3 24th February 2008 05:43 AM
Is it true that the Quality Manual cannot be a Procedure? jerzki ISO 10013 - Quality Management System (QMS) Manuals 13 13th November 2007 09:01 AM
The time now is 11:01 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
