Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 5th November 2000, 09:40 PM
hemant
Unregistered Guest
Posts: n/a
Question Stability of the gage to be determined first and then gage R&R?
in the survillance audit auditor has raised the issue that stability of the gage to be done first and then only R&R.
as per me this is hen & egg situation.
if R&R is not less than 10% how stability can be exibited?
[This message has been edited by hemant (edited 06 November 2000).]
Sponsored Links
Old 6th November 2000, 04:58 AM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
One has to determine the inherent "Statistical Stability or Control" of the measurement process over a period of time. The methodology used for this is the same as that for conducting an SPC study. ie.
1. Determine Sample size and frequency
2. Plot control charts
3. Analyse / separate "common cause" and "special cause" variation
4. Look for out-of-control and trend signals
An out-of-control Range chart indicates unstable repeatability (too much variation) and an out-of-control X-bar chart may mean that the instrument is due for calibration (bias).
A measurement process must be statistically under control (no special cause variations) for it to be used effectively to control the manufacturing process it measures. If there are no out-of-control signals, Standard Deviation can be estimated and compared with process standard deviation to determine suitability of the measurement process for the application.
Once the statistical stability is established, R&R study is then conducted to 'quantify various errors' in the measurement system. Based on these (r&r percentages), one can determine the suitability of the measurement system for a particular measurement application.
Quoting from MSA manual "...Without data-based knowledge of the state of control of a measurement process, figures of 'repeatability' , 'reproducibility', etc. are only descriptions of data obtained during the (r&r) study. They may have no meaning for future performance. Assessing the repeatability, reproducibility etc. of a measurement system for which the state of stability is unknown may cause more harm than good..."
- Atul
Sponsored Links
Old 6th November 2000, 08:58 PM
hemant
Unregistered Guest
Posts: n/a
BIG Smile
on reflecting further to my original post, i have gone through the MSAMEASUREMENT SYSTEM ANALYSIS (MSA) book ifeel that
STABILITY:
When considering the subject of stability in connection with measurement system, it becomes extremely important to differentiate between what is generally referred to as measurement system stability ----
a ) The amount of total variation in the system’s bias over time on a given part or master part : Known as "Stability over Time"
statistical stability, the more general term which is applied to not only stability ,but to repeatability, bias, process in general., etc.
to understand the difference between the two stability, let us consider that there can be 2-measurement systems, measuring exactly the same master part, both of which demonstrate statistical stability, yet one system may have significantly higher variation in its bias over time than the other. From a statistical standpoint, they are equally stable. From a traditional gage stability stand point, the system with greater bias variations over time is considered less “ STABLE “ than the one with lower bias variation. ----------------- (page-21,chapter-2-section-2 )
Statistical properties of measurement systems :
The measurement system must be in statistical control. This means that variation in the measurement system is due to common causes only and not due to special causes. This can be referred to as statistical stability. ---------- (page-5, chapter –1 , section-2 )
Quality of measurement data
The statistical properties most commonly used to characterize the quality of data are
Bias and Variance.
The property called bias refers to the location of the data relative to the master value and the property called variance refers to the spread of the data.
---------- ( page-3 , chapter-1,section-1)
specifically, the procedures assess the following statistical properties;
Repeatability, reproducibility, bias, stability, and linearity.
Collectively, the procedures are sometimes referred to as “gage R&R” procedures. ------------ (page-15,chapter-15,-section-1)
DOES THE GAGE R&R ASSESS THE SAID STATISTICAL PROPERTIES OTHER THAN REPEATABILITY & REPRODUCIBILITY. YES/NO.
If yes -------------- how
Analysis of results ---graphical analysis
Stability
From range chart stability is determined by: a point or points beyond the control limit ; within operator or within part patterns, ------- ( page-46 , chapter 2- section 4 )
linearity
the averages of the multiple readings by each appraiser on each part are plotted with the reference value or overall part average as the index. This plot can assist in determining :
linearity (if the reference value is used ) ------- (page-52, chapter 2-section4 )
CONCLUSION
GAGE R&R study is an apt exercise for statistical stability and if used, as said above all statistical properties are revealed. Like stability, linearity, repeatability & reproducibility. GRR should be done first and GRR values should be brought below 10% . This can be achieved by understanding the graphical representation and taking appropriate steps. By doing so we are achieving the "Statistical stability".
Without data –based knowledge of the state of control of a measuring process, R&R figures are only descriptions of the data obtained during study. They have no meaning for future performance. Assessing the repeatability ,reproducibility, etc, of a measurement system for which the state of stability is unknown may cause more harm than good. When talking of measurement system statistical stability, the length of time a system is stable is often a major point of discussion. However by means of TIME STABILITY, the length of time a system is stable can be found by using x-bar r-bar control chart. This time stability is to be done after statistical stability in other words called gage R&R. Incase if time stability is performed prior to gage R&R the bias readings will not be exact as readings are contaminated with repeatability and, reproducibility errors.
Above all, any manufacturing process is supposed to be statistically stable if CP & CPK are controlled as they are representing spread & bias (centrality. ).The normal practice to control SPREAD first then to CPK the bias or centering OPN.
Similarly, we have to look at measurement system.
First control repeatability and reproducibility errors of SPREAD by doing gage R&R STUDY and then go to TIME STABILITY to know the extent of DRIFT OR BIAS the CPK.
the book reference r indicated in the brackets.
invite views on this
Old 7th November 2000, 10:37 AM
Lyndon
Unregistered Guest
Posts: n/a
i do not agree that gage r&r ensures statistical stability....in my opinion,stability studies have to be done simultaneously with r&r studies,so that special causes occuring in between 2 r&r studies can be noticed.if such a stability study is not carried out simultaneously,then any special cause occuring wil not be noticed,which can give u a lower value of %r&r inthe second study,thus masking the improvement u have made in reducing the variation.
e.g i have done msa studies where by cleaning a comtor gage(forchecking bore diameter),i have got better %r&r,in reality what i have done is improved stabiliy by reducing a special cause(that of dust,dirt etc),and not improved either the gage repeatibilty or the appraiser reproducibility
but i agree with hemant that..a time stability has to be ALSO carried out later once u have got 10%r&f.....but i repeat my point that stability studies should be carried out simultanouesly with any r&r studies,in order to be aware of the occurence of any special cause
Old 11th June 2008, 03:28 PM
ABS ABS is offline
Involved in Discussions
Registration Date: May 2008
Thanks Given to Others: 1
Karma Power: 7
ABS has less than 100 Karma points so far.
Default Re: Stability of the gage to be determined first and then gage R&R?
I know its an old thread,... but anyone still there.....Can someone tell me if I get %GRR under 10%, then how long do I need to do stability tests to make sure that my gage works for e.g. an year without giving me an error. How is the time period for a stability test decided????
Thanks guys!
Old 12th June 2008, 02:29 PM
Miner's Avatar
Miner Miner is offline
Registration Date: Apr 2002
Thanks Given to Others: 166
Karma Power: 251
Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.Miner is appreciated, and has over 1700 Karma points.
The stability test should have a duration that exposes the gage to the extremes of environmental variation that might be expected while in use. This could be a day or a week.
"A fool can learn from his own experiences; the wise learn from the experience of others." - Democritus, 460-370 B.C.
Old 13th June 2008, 04:44 AM
ABS ABS is offline
Karma Power: 7
Under what conditions these statistical stability requirements discussed in above posts can be waived????
Old 13th June 2008, 08:43 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 612
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
That would be up to your customer(s). If you can provide sensible rationale for not doing stability studies, present it to the customer and see what happens.
Reply
Bookmarks
Tags
gage, stability
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Product Stability (Machine Capability) vs. Equipment Repeatability (Gage R&R) Yew Jin Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7 3rd October 2006 08:48 PM
Scales - Gage R&R, Bias, Linearity, Stability Benoit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1 2nd July 2003 12:12 PM
Auditor wants our Gage R&R Procedures to address Linearity, Accuracy and Stability Greg Fote Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22 23rd December 2002 02:18 PM
Gage Stability Study Requirements - Gage R&R Study Data HANK Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1 23rd January 2002 01:04 PM
Gage R&R - Acceptance Criteria for Linearity, Bias, and Stability dewie Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4 1st February 2000 04:26 AM
The time now is 01:46 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
