The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > General Measurement Device and Calibration Topics
Forum Username
Wooden Line
How to Calibrate a Vernier Caliper - Detailed Procedure
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Related Topic Tags
calibration (general topics), procedures (general), vernier calipers
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
  Post Number #1
Old 25th January 2005, 10:58 AM
abdallah - 2005
Please Help! How to Calibrate a Vernier Caliper - Detailed Procedure
Hi
can someone please supply me with a detailed procedure of how to calibrate a vernier caliper.
I need to know how many points to measure and how many points to use to obtain the uncertainty.
How should the results be illustrated in the certificate?
tabular or graphical form and what are the results that should be included in the certificate?
Thank you for the help
Sponsored Links
  Post Number #2
Old 25th January 2005, 11:19 AM
Claes Gefvenberg's Avatar
Claes Gefvenberg
Quid Pro Quo
Hello Abdallah,
I'll leave it to others to answer your question, but in the mean time: Welcome to the Cove
/Claes
Sponsored Links
  Post Number #3
Old 25th January 2005, 12:07 PM
cncmarine's Avatar
cncmarine
http://www.uofaweb.ualberta.ca/mece/...asurements.pdf
The above link will get you started
  Post Number #4
Old 28th January 2005, 12:33 PM
TownDawg's Avatar
TownDawg
Clean jaws and track of dirt, grease and foreign matter. Verify that gear moves across tracks freely. Bring jaws together and note reading (dial should be reading zero, also if dial is not reading zero, move the dial face to zero set and continue with checks).
On the #1 check (OD jaws) insert a .500-inch (12.7 mm) gauge block between the jaws of the caliper and close so both jaws are touching the gauge block. Record reading.
Repeat steps with a 1-inch (25.4 mm) gauge block and 4-inch (101.6 mm) gauge block. Record reading.
Repeat using appropriate size micrometer standard (150, 200 or 300).
On the #2 check (ID Jaws) set the calipers on 12.7mm and lock into place and measure the jaw width with another pair of calipers that have been calibrated (caliper number must be recorded for traceability). Record reading.
Repeat step for 25.4 mm and 101.6 mm and appropriate length of caliper (150, 200 or 300). Record readings.
On the #3 check (height check) set 12.7 mm gauge block on surface plate, extend the caliper above the block and bring down to touch the block. Record reading.
Repeat step for 25.4 and 101.6mm gauge blocks. Place appropriate size micrometer standard on surface plate and extend the caliper above it and bring the caliper down to touch. Record readings.
Maintain readings on file in the Quality Department.
Thanks to TownDawg for your informative Post and/or Attachment!
  Post Number #5
Old 29th January 2005, 03:43 PM
abdallah - 2005
Thank you TownDawg
Thank you TownDawg for the post. This is quite helpfull.
1. Can you tell me how many readings are necessary to obtain the imprecission?
2. Is the uncertainty that is recorded in a calibration certificate that of the block gauges used? if so how do i obtain this?
Thank you again
  Post Number #6
Old 31st January 2005, 10:28 AM
Hershal's Avatar
Hershal
You will likely need at least three readings to calculate the uncertainty for the calipers. More readings are perferred, but typically three is minimum. That is your Type A uncertainty.
The uncertainty for the calibration of the calipers does include the uncertainty of the gage blocks.....but that is only one part. Gage block uncertainty will be a Type B in your calculations, and should be provided in the calibration certificate for the gage blocks.
Other influences include temperature, the coefficient of thermal expansion for both the calipers and for the gage blocks, and the resolution of the calipers. These are all Type B uncertainties.
Hope this helps.
Hershal
  Post Number #7
Old 12th July 2010, 01:12 PM
apatil101
Re: How to Calibrate a Vernier Caliper - Seeking Detailed procedure
Hello Everyone ,
This is Amol Patil , I was working on the calibration procedure for Vernier Caliper I found the above information very useful. I just had few questions regarding the procedure specified by 'TownDawg' in his post.
1) Do I have to use same gauge block size as specified above only ? Or I can use the combination that is available. For example I have a gauge block set of 516-931 which doesn't have a 4 inch gauge block.
2) How do we capture the inaccuracies on the entire range of the caliper. Does this sample procedure apply for a caliper on 0-6" and 0-24" ?
These question arise from the fact the we only use higher range of the caliper for our measurements , my concern here is how will certify the entire range of caliper ?
Any guidance and suggestions most welcome ..........as its great learning opportinuity for me
Thanks,
Amol
  Post Number #8
Old 12th July 2010, 04:35 PM
Wes Bucey's Avatar
Wes Bucey
FWIW:
There is a device called by many manufacturers a "caliper checker"
Using one is a lot quicker than the method I learned using individual gage blocks.
Here's a picture of one in this post
http://elsmar.com/Forums/showpost.ph...35&postcount=6
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Please review my Vernier Caliper Gauge R&R benzkumar Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8 19th March 2013 04:28 AM
Vernier Caliper Accuracy Issue - Inside measurements were slightly off tekno9000 General Measurement Device and Calibration Topics 7 27th October 2010 12:33 PM
Usage of Calibrated Equipment - Vernier Caliper anil123 Misc. Quality Assurance and Business Systems Related Topics 10 23rd February 2010 05:33 AM
Must a vernier caliper and a rule be calibrated according to ISO 9001? blue moon General Measurement Device and Calibration Topics 50 13th July 2009 07:52 PM
Best Caliper for Shop Use? Digital vs. Dial Caliper vs. Vernier-type Lundberg General Measurement Device and Calibration Topics 53 29th September 2008 02:39 PM
The time now is 09:00 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
