31st January 2005, 08:13 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Michelin Tweel could dramatically change tyre technology
I missed this one. What do you think?
Detroit January 10, 2005
Today at the North American International Auto Show, Michelin showcased a potentially disruptive technology with significant ramifications for the future for mobility: an airless, integrated tyre and wheel combination dubbed the TWEEL (i.e. Tyre/WhEEL) . The Tweel promises performance levels beyond those possible with conventional pneumatic technology. The first commercial applications of the Tweel will be in lower-speed, lower-weight vehicles such as the iBOT mobility device and Segway's Concept Centaur
Designed by Segway-inventor Dean Kamen, the iBOT mobility device has the ability to climb stairs and navigate uneven terrain, offering mobility freedom impossible with traditional wheelchairs.
Additionally, Segway's Concept Centaur, a prototype that applies self-balancing technology to a four-wheel device, has also been equipped with Tweel to increase its performance potential.
Beyond these first real-world applications, Michelin has additional projects for Tweel on construction skidsteers and a variety of military vehicles. Historically Significant
"Major revolutions in mobility may come along only once in a hundred years," said Terry Gettys, president of Michelin Americas Research and Development Center in Greenville, S.C. "But a new century has dawned and Tweel has proven its potential to transform mobility. Tweel enables us to reach levels of performance that quite simply aren't possible with today's conventional pneumatic technology."
The most intriguing application may be Michelin's early prototype Tweel fitment for passenger cars. The mobility company released video of promising Tweel performance on an Audi A4.
"The Tweel automotive application, as demonstrated on the Audi, is definitely a concept, a stretch application with strong future potential," said Gettys.
"Our concentration is to enter the market with lower-speed, lower-weight Tweel applications. What we learn from our early successes will be applied to Tweel fitments for passenger cars and beyond." Benefits of the Tweel
The heart of Tweel innovation is its deceptively simple looking hub and spoke design that replaces the need for air pressure while delivering performance previously only available from pneumatic tires.
The flexible spokes are fused with a flexible wheel that deforms to absorb shock and rebound with ease. Without the air needed by conventional tires, Tweel still delivers pneumatic-like performance in weight-carrying capacity, ride comfort, and the ability to "envelope" road hazards.
Michelin has also found that it can tune Tweel performances independently of each other, which is a significant change from conventional tires. This means that vertical stiffness (which primarily affects ride comfort) and lateral stiffness (which affects handling and cornering) can both be optimised, pushing the performance envelope in these applications and enabling new performances not possible for current inflated tires.
The Tweel prototype, demonstrated on the Audi A4, is within five percent of the rolling resistance and mass levels of current pneumatic tires. That translates to within one percent of the fuel economy of the OE fitment.
Additionally, Michelin has increased the lateral stiffness by a factor of five, making the prototype unusually responsive in its handling. Future of Tweel Technology
For Michelin, Tweel is a long-term vision that represents the next step in a long path of industry-changing innovations. Fifty years ago, Michelin invented the radial tyre and there is no question that radial tyre technology will continue as the standard for a long time to come. Michelin continues to advance the performance of the radial tyre in areas such as rolling resistance, wear life and grip.
In the short-term, the lessons learned from Tweel research are being applied to improve those conventional tyre performances. In the future, Tweel may reinvent the way that vehicles move. Checking tyre pressure, fixing flats, highway blow-outs and balancing between traction and comfort could all fade into memory.
The History of automotive tyre development
1844 - Charles Goodyear invents vulcanised rubber
1845 - Robert William Thomson patents vulcanised rubber pneumatic tyre but was too costly and doesn't catch on
1888 - John Dunlop invents pneumatic tyres for bicycles.
1889 - A Belfast Cycle Race was won on pneumatic rubber tyres beginning public awareness. Unfortunately the original tyre was glued to the wheel, making it difficult to access the inner tube
1890 - CK Welsh patents the design of a wheel rim and outer cover with inextensible lip.
1895 - André Michelin uses pneumatic tyres on an automobile (unsuccessfully). '
1903 - Paul Weeks Litchfield patents tubeless tyre. He rose to become the chairman of Goodyear in the year 1940.
1904 - mountable rims were introduced that allowed drivers to fix their own flats.
1908 - Frank Seiberling invented grooved tires with improved road traction.
1910 - B.F. Goodrich invents longer life tires by adding carbon to the rubber.
1911 - Philip Strauss invents the first successful automobile tyre, which was a combination tyre and air filled inner tube. Strauss' company the Hardman Tyre & Rubber Company marketed the tires.
1937 - B.F. Goodrich invents the first synthetic rubber tires and patents a substance called "Chemigum"
1948 - Michelin patents the radial tyre
1954 - first original equipment tubeless tyre fitted to the now defunct Packard.
31st January 2005, 10:00 AM
Been around a while
Registration Date: Jan 2002
Thanks Given to Others: 281
Karma Power: 171
I knew it would happen...someone reinvented the wheel.
Actually it is interesting that the Ford/Firestone thread has been bumped at the same time this appears. The best way to avoid a blowout would be to remove the air from the start, right? I wonder how heat impacts the characteristics of the materials, though. Even without the air, an unintentional rapid disassembly would still be hard to deal with at speed.
31st January 2005, 10:35 AM
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Just as an aside - several communities in the Chicago area have outlawed mini-powered motorbike and scooters from streets and sidewalks (mainly ridden by children) AND have also banned Segways from streets and sidewalks - curious behavior when some police departments in neighboring communities are adopting Segways for beat patrolmen. I was impressed at seeing multiple Segways at Atlanta airport being used by security folk.
31st January 2005, 10:59 AM
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
I think this is a very creative idea, with great potential. I have in fact seen a similar application many years ago: It relied not on spokes, but on leaf springs protruding from a hub and then bending 90 deg parallel to the wheel axle, thereby creating the contact surface. I believe it was scrapped due to instability at anything over crawling speed. This looks a lot more usable.
It will be interesting though, to see how hot the spokes get at high speed...
/Claes
