Go Back   The Elsmar Cove Forum > National and International Business Standards > CE Marking (Conformité Européene) / CB Scheme
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 7th February 2005, 09:40 PM
vpanchal vpanchal is offline
Registration Date: Dec 2004
Karma Power: 21
vpanchal has less than 100 Karma points so far.
Question CE Marking for Power Supply for Medical Device - Class IIb device per MDD, Rule 11
Hello ,
I am new to the Forum,, I find it very useful. Thanks for very useful information.
I have a Question regarding Power Supply. We manufacture infusion
pumps Classifed as Class IIb device per MDD, Rule 12. We use a Switch Mode
Power Supply ( AC Input and DC Output) from a Supplier who evaluates to
IEC 60601-1 Safety Standard and Marks it with CE Mark.
Since this Power Supply is used with a Medical Device, Does this Power Supply become an accessory with the Medical Device.?
Since Power SUpply is not non invasive device, Is it Classified as Class I device or Class IIb based on its usage with pump?
What type of Declaration of Conformity does the Power Supply
Manufacturer has to provide to us? Is it DOC to MDD or Low Voltage Device?
If its MDD, then Does the Power Supply Manufacturer has to prepare a
Technical File as well as the End Product User (Pump)?
VP
Sponsored Links
Old 7th February 2005, 11:23 PM
Al Rosen's Avatar
Al Rosen Al Rosen is offline
Registration Date: Jun 2002
Thanks Given to Others: 48
Karma Power: 192
Al Rosen is appreciated, and has over 1700 Karma points.
Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.Al Rosen is appreciated, and has over 1700 Karma points.
Send a message via AIM to Al Rosen
Default
Your device cannot be in class IIb according to Rule 12, since Rule 12 establishes Class I.
Originally Posted by MDD
3.3. Rule 12
All other active devices are in Class I.
Please clarify.
Al
Sponsored Links
Old 8th February 2005, 12:07 PM
Karma Power: 21
Default
I apologize.. Rule 11.. All active devices intended to admnister and/or remove medicines. body liquids or other substances to or from body are in Class IIa, unless this is done in a manner:
-that is potentially hazardous, taking account of the nature of the substances involved, of the part of the body concerned and of the mode of application in which they are in Class IIb.
once again, I apologize for stating Rule 12..
Thanks.
Old 8th February 2005, 02:57 PM
Al Rosen's Avatar
Karma Power: 192
Default
If the PS mfr Has declared that the PS complies with IEC-60601-1 and is in compliance with the LVD it is sufficient since your device will comply with the MDD and this PS will be a component of it, not an accessory, and classification is not an issue. You will have a description of the PS and a DoC in your device's TF. I don't think you will or could have a TF for the PS since you do not have the details required.
I'm not sure I understand:
But in any case, read the attached MEDDEVs, 2.1/1, Definitions of "medical devices", "accessory" and "manufacturer" and 2.4/1, Classification of MD.
Discuss it with your NB for verification since I am basing this on my experience and application.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Al
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Multisite CE certificate - Class IIB medical devices per MDD Annex 2 somashekar CE Marking (Conformité Européene) / CB Scheme 4 28th July 2009 02:20 PM
Containment Device Classification - Class I Medical Device via Rule 1 MDD Annex IX leroybrown CE Marking (Conformité Européene) / CB Scheme 1 17th July 2009 10:23 PM
Independent authorized CE Marking representative in UK or EU - Class 1 Medical Device Karee CE Marking (Conformité Européene) / CB Scheme 11 10th March 2009 08:39 PM
Class I Medical Device - What is in a CE Marking Self-Declaration Carisa CE Marking (Conformité Européene) / CB Scheme 18 10th March 2009 06:46 PM
Medical Device Directive, Conversion from class IIb to class III ISO MAN CE Marking (Conformité Européene) / CB Scheme 4 17th November 2008 10:50 AM
The time now is 04:57 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
