21st February 2005, 05:46 PM
Involved - Posts
Registration Date: Dec 2004
Karma Power: 23 Karma: 54
ANSI and ISO documents and certification exams
I'm working the QCI test questions disk in preparation for the CQT exam. I'm finding lots of questions that reference these types of standards. Is there some sort of concise resource that outlines these? I can get the questions about 50% correct using what I know and some sort of applied logic. Others I have no idea what the standard states or even where to find the information.
Any suggestions would be helpful. I'm pretty weak in the statistics portions of the exam so am trying to make sure that I can correctly answer as many non-stats questions correctly to increase my chances of passing.
Passing this exam is a requirement of my job and I'm starting to feel absolutely ill with stress and apprehension.
21st February 2005, 06:30 PM
Registration Date: Jun 2002
Thanks Given to Others: 48
Karma Power: 192
There are literally thousands of ISO standards. You mayn only need to be familiar with a dozen. Try www.iso.org and search in the international standards. They some times have an abstract. This was the result for iso 9001:2000.
Al
21st February 2005, 06:33 PM
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Odd. the sample CQT test on the ASQ site doesn't have any questions like that in its 50 sample questions.
I'm finding lots of questions that reference these types of standards. [ANSI and ISO Standards]
Give us a couple of samples of what you mean.
22nd February 2005, 08:24 AM
Involved - Posts
Here are the examples from one of the CQI practice test disks simulated exams. There was another question in addition to these, but it was similar to one below so I didn't add it. Also, I didn't put the multiple choice answers down.
Calibration intervals of "Measuring & Test Equipment" must be based upon (per MIL-STD-45662):
According to ANSI/NCSL Z540-1, an adjustment of calibration intervals for laboratory assets must be based on: (could probably answer using a process of elimination and logic)
Using ANSI/ASQCZ1.4 for a lot of 1000 parts, a general inspection level II the codeletter J, and an AQL of 1.0%, with a sample size of 80, what is the accept number? (This is obviously an AQL problem, but I don't know if the standard changes anything about solving the problem).
A small manufacturing operation is certified to ISO 9001:2000. After they acquired a CMM, they plan to move their surface plate to storage. They are required to do all of the following except: (This is one I an answer using logic)
Which of the following stanards apply to geometric dimensioning and tolerancing? (choices are ANSI/ISO/ASQ 10011, QS-9000, ANSI/ISO/ASQ 9001, ASME Y14.5M-1994) I got this question right, but I just guessed that it was the ASME standard.... I guessed this because I use to be a member of ASME!
22nd February 2005, 09:54 AM
Karma Power: 192
Holly, there is no way to commit to memory all the standards that might be included in the exam. These questions require experience in Quality.
Al
22nd February 2005, 11:56 AM
Quality Manager
Karma Power: 397
Al is correct in that for most people it is impossible to "memorize the Standards." It is, however, important to be familiar in a "broad brush" way with what Standards [the ones used in a particular branch of Quality] cover.
Hence, in the last question
Which of the following standards apply to geometric dimensioning and tolerancing? (choices are ANSI/ISO/ASQ 10011, QS-9000, ANSI/ISO/ASQ 9001, ASME Y14.5M-1994) I got this question right, but I just guessed that it was the ASME standard.... I guessed this because I use to be a member of ASME!
you might have guessed the ANSI/ISO/ASQ Standards applied to systems and that would have left the ASME. The point was you needed to know "something" about GD&T in order to guess, even if you were not a GD&T maven, dealing with technical drawings every day.
Heck! After dealing with technical drawings for 20 years, I still keep my handbook close by for when I come across a drawing with a GD&T notation I don't recognize.
What I mean is "you don't need to drag these various Standards along to the exam as references, but you are expected to know in a general way what they contain." Perhaps a "reminder sheet" of each of the Standards with a short description will help you answer this part of the Body of Knowledge:
3. Quality standards, requirements, and specifications
Define and distinguish between quality standards, requirements, and specifications.(Comprehension)
Make sure you familiarize yourself with what the BOK says is "testworthy"
If you don't have the CQT BOK, download it now at
http://www.asq.org/cert/pdf/cqt_bok.pdf
22nd February 2005, 12:06 PM
Registration Date: Apr 2004
Thanks Given to Others: 13
Karma Power: 50
Holly,
All your questions are very typical to the first time exam takers. I had all those questions myself when I wrote the first one. and second one and third one..and later understood myself the answer for those questions and was able to do further 3 with better confidence.
ASQ Questions will test your understanding and not memory.
Unless if a reference Quality Standard is included in the BOK, you donot need to carry that standard.Typically CQT handbook OR QCI Primer will have those reference tables if covered in BOK.
Ability to interpret the Z1.4 table and pick the sample size or Acceptance , Rejection number , yes.
Regards,
Govind..
