The DMR at our company is a formally controlled quality system document. Technical files are more Regulatory at our company, and are not accessible to everyone. DMRs are. We are a contract manufacturer. There is one for each product, and we use it as a document index. There are no references to the document revision levels as those are on the documents themselves, as well as the document history, including ECO number. If you need a template I have one.
The principle behind using the DMR as an index all documents, drawings, etc. that are used to build a device is that it makes auditing easier, and is a great resource for new people who are not familiar with the device.
It is structured like this:
DEVICE MASTER RECORD
Product Number:
Revision:
Product Description: (Noun name, modifier, value)
Customer name:
Design history file: (This could be your project file with design xfer.)
Raw materials spec: (doc number, no revision. Go to document
itself for the current revision number and
history.)
Bill of Material: (doc number) BOM has component numbers of
course
Drawing number: (Drawing number(s))
Manufacturing procedures: List doc numbers
Quality assurance procedures: List doc numbers
Fixtures: See individual manufacturing and quality assurance specs. (We do not list fixtures on DMR and in specs. Only at point of use.)
Software: Name software packages
Packaging procedure:
Packaging info: Shelf life in days
Number of units in this configuration that is shipped
(eaches, 10 to a carton, what. A DMR for each
configuration.)
Labeling: Labeling procedure
Label printing spec: Doc number
Post Packaging testing: Doc number
Sterilization: Doc number
Post sterilization inspection and testing: Doc number
Inspection and release procedures: Doc number
Shipping: Doc number
At the end of the document is the revision history including rev. number, effective date, ECO number, and short description of change.
Hope this helps. Also useful for you would be this link:
http://www.fda.gov/cdrh/dsma/gmpman.html
Included in this manual is what the FDA says a DMR should be. Along with a lot of other info. That should help you a lot.
