1st March 2005, 04:58 PM
Registered Visitor
Registration Date: Jun 2003
Thanks Given to Others: 4
Karma Power: 30 Karma: 178
MiniTab vs. Excel: Difference in Degrees of Freedom
The question below came to me from a chemist. I did not have an answer for him but before researching would like to see if any of you do.
"I was performing regression analysis in excel and minitab for x & y variables. I had 24 trials and under Data Analysis/Regression in excel the reported degrees of freedom was 21 in the summary table. In minitab the same regression analysis reported 22 degrees of freedom which makes sense to account for the two variables. Why the difference? In reality it doesn’t make much difference with 24 trials, but if the trial number was low then the difference would be greater."
1st March 2005, 05:12 PM
Mod...
Registration Date: Mar 2003
Karma Power: 46
Possibly rounding differences in the programs???? I would trust Mini-Tab over Excel on general purposes ans excel was not specifically designed for statistical use.
And as we all know, it was designed by microsoft.
Al...
"Para ... Bellum"
1st March 2005, 05:56 PM
Deming Disciple
Registration Date: Feb 2004
Thanks Given to Others: 60
Karma Power: 190
Do you have a copy of the Excel file that you could post here?
Steve Prevette
"A Passionate Statistician", ASQ CQE, Fluor Government Group
The opinion stated above does not necessarily reflect that of my employer.
2nd March 2005, 09:56 AM
Registered Visitor
Never mind
Steve,
I asked for the data and received the reply below. Thanks anyway. I appreciate your willingness to help.
Susan
"I did not save all of my regression data only the summary table. I went in to regenerate the entire regression analysis for the data, and guess what? Each time I do it now I get the correct degrees of freedom. I do not understand. I did this multiple times before and it was reporting the same number of observations as now “24”, but only 21 df. Now its reporting 22 df??? Sorry for bothering you, I don’t know what has changed but everything is fine now."
2nd March 2005, 10:53 AM
Deming Disciple
Karma Power: 190
It is possible that they had inadvertently done a non-linear regression (a parabola) or otherwise got excel to believe there was a second variable which would have used up the 3rd degree of freedom.
Steve Prevette
2nd March 2005, 01:50 PM
Involved in Discussions
Registration Date: Aug 2004
Karma Power: 23 Karma: 65
I have had similar experiences with MS Excel. It is possible to write a few lines of VBA Code to make the numbers (correctly) match MiniTab, however, it is a pain in the keester. The root cause of the discrepancy usually lies in the number of significant digits allowed in the calculation and the rounding of same.
MiniTab is the undisputed champion and de-facto standard in todays business world with a price tag of $1,000+ depending on licensing.
Mike H.
Quality Jedi
Sales...Quality
