8th March 2005, 12:09 PM
E-Mails Invalid or Rejected
Registration Date: Jul 2004
Karma Power: 0 Karma: 63
Assembly Work Surface Cleanliness - Plastic Table Tops and Embedded Metal Chips
Heres one for you. We have decided to go through our assembly dept. and focus on cleanliness. One area I see as a problem are our table topsurfaces. they are made of a plastic. This will get scratched making it hard to clean. Metal chips also embed in the top which than could get picked up by a seal and tear the seal.
Any suggestions,
Pete
8th March 2005, 12:23 PM
Been around a while
Registration Date: Jan 2002
Thanks Given to Others: 281
Karma Power: 171
Pete, if you do not want to replace the tables, and the metal has iron in it, could you clean the tabletops every now and then with a magnet?
8th March 2005, 12:28 PM
That could work however the tops on the tables are so old that the chips are imbedded in the surface of the table. I would like to have them replaced and start fresh. Planning on mapping out cleaning procedures for that dept. Would prefer to go to a better top than the plastic type we use now. No sense heading down the same path again.
Pete
8th March 2005, 01:38 PM
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
Hullo Pete,
When you mention metal chips embedded in the table top in the same sentence as easily ripped seals I shudder at the thought  . That is a big nono as far as I'm concerned, and I think you are right on target when you see that as a problem area.
Good call imo. If you do that you also send a message about a fresh start. What surface to use will of course depend on what you use them for, but unless it damages your product: How about a stainless tabletop? I suppose you want something that is easy to keep clean, and it doesn't come any easier than that...
/Claes
8th March 2005, 03:01 PM
Involved - Posts
Registration Date: Feb 2005
Thanks Given to Others: 8
Karma Power: 27
other materials
am sure there are many others but here are few i like
- glass (my fav)
- different type of plastics....eg lexan type - durable and scratch resistant
if you have more than one table...try all different types then go with the one that works best..
8th March 2005, 04:16 PM
Got off the phone with a company near us in Harrisburg, PA that manufactures plastic product. they will be sending me samples of Phenolics and Polycarbonate sheets
Stainless Steel would not work as our cylinder heads are cast and rotary valve/input assembies are steel. Afraid any aggressive contact could produce a chip.
8th March 2005, 04:30 PM
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
What did I miss? Where do the metal chips come from? I would expect the assemblies to be scrupulously clean prior to installing any kind of seal which could be ripped, offset by debris, or otherwise compromised in their function as a result of "unplanned" contamination.
To avoid the situation recurring, regardless of tabletop material, a cleaning step ought to be included before seal installation.
9th March 2005, 07:20 AM
True Wes. We are looking for the source of this. My main reason for changing the tops is because they are contaminated with chips imbedded in them. I am going to a better surface to prevent that problem again.
Pete
