Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Lean - Lean in Manufacturing and Services
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 15th March 2005, 10:06 AM
encd3 encd3 is offline
Registration Date: Mar 2005
Karma Power: 20
encd3 has less than 100 Karma points so far.
Default Development of Lean Supply in a Free-Issue Environment
In my role as a research associate in a partnership between Warwick University and bodybuilding company JC Payne (UK),I've begun work towards and MSc in the subject area of distribution and supply networks.
Within this company, the manufacture of truck bodies is carried out in a relatively lean fashion; however significant disruptions are caused by the nature of the free-issue supply of key components such as chassis and tail lifts. Free-issuing of components by the customer restricts the ability of JCP to control production with frequent problems occurring when true product demand is not reflected in the pattern of free-issue supply. This results in periods of feast and famine.
Attached is a copy of my research proposal, any comments or advice would be greatly appreciated. I believe that the tools and techniques exist in lean theory to overcome this problem.
Regards,
Craig Davies
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Sponsored Links
Old 15th March 2005, 02:14 PM
Wes Bucey's Avatar
Wes Bucey Wes Bucey is offline
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Default
Regards,
Craig Davies
I'm still a bit confused by your use of the term "free issue" - which I interpret to mean "customer-supplied product" upon which the supplier performs a value-added process.
In my experience with this sort of activity
  • sending machined parts to heat treater or electroplater
    or
  • sending raw castings to a machinist for finishing to print
there were two primary factors which played into our choice of supplier to perform the activity:
  1. capability (the ability of the supplier to perform the activity to our specifications)
  2. capacity (the ability of the supplier to perform the activity within our time window of expectation)
In a Lean environment, there is always a process (sometimes more than one) which has a process time which is fixed and unchangeable. The only way to increase throughput of units per time period through this "bottleneck" process is to increase the number of persons or machines performing the activity.
Part of the planning for a finished product or assembly is to take the two factors (capability and capacity) into account for each component of the finished product. If one supplier does not have the capacity (for any number of reasons, including a corporate decision not to tie up a large portion of capacity into production for any single customer), then the buyer must increase the capacity by changing suppliers or adding more suppliers. Adding multiple suppliers brings another set of factors into play (uniformity and traceabililty of product - especially for critical components which can affect life, health, safety.)
Lean manufacturing environments aren't easy, but they are pretty to behold once they are operating effectively.
From the supplier's viewpoint:
When a customer does not have a steady flow of "customer-supplied" product to operate machinery at prime efficiency to perform the value added process, a supplier has two choices (with the connivance and acquiescence of the customer):
  1. Customer enters into a "take or pay" agreement to buy a fixed amount of production capacity from the supplier each month at two different prices: one price for actual use of the machines including labor and wear and tear on the machines and a second price equal to the lost profit for holding the machines and personnel idle for priority use on the customer's products (see comment below)
    or
  2. Customer agrees to buy a minimum amount of finished product per time period and agrees to pay a slight premium for peak flows exceeding that minimum in any given time period. The premium pays for getting priority use of the machines over any other customer of the supplier to meet the subject customer's demand. (see comment below)
Comments: In actual use, the supplier is willing to grant customer a concession to perform work on customer's product with priority over any other customer for two reasons: first, he is assured of a minimum income each time period which he can use to budget his operation and second, because he is compensated for delaying work for other customers to perform priority work on the subject customer's peak demand.
This does not violate the principle of Lean and may, in fact, enhance it, because the customer is justified in paying more to have a guaranteed supply per time period and increased demand in a given time period (resulting in higher payment to supplier per unit) can be offset by corresponding lower costs of overhead per item when more pieces are sold in that time period.
Last edited by Wes Bucey; 15th March 2005 at 02:35 PM. Reason: add supplier viewpoint
Sponsored Links
Old 16th March 2005, 04:26 AM
Karma Power: 20
Default
    or
    or
Thanks Wes,
'Free-Issue' is a common term used in the UK (I think with a military history) used, as you suggested, to mean 'Customer Supplied Product'.
I'm experiencing a variation on the 'Free-Issue' situations you mention, where the truck chassis itself is Customer supplied to JCP, JCP's value is added (the truck body) and is then dispatched to the customer. The choices you suggest are ver interesting and I will give them further thought.
Regards,
Craig Davies
Old 31st March 2005, 04:47 PM
Ruis72 Ruis72 is offline
E-Mails Invalid or Rejected
Karma Power: 0
Ruis72 has less than 100 Karma points so far.
Default
Hi Craig,
Our directors introduced lean to our company about a year ago and we've had similar problems. We manufacture flexible printed circuit boards and it's quite common for some of our customers to supply us with free issue components ( resistors, transistors etc supplied free of charge ) for us to assemble to the printed circuit we have manufactured for them. We can neither change the supplier or add suppliers as the customer has specified we can only receive the components from them. However they can be frequently late, wrong or not supplied at all - there are times when we've part assembled a circuit, shipped to them and then had the circuit and remaining components shipped back to us for completion. Our stores people are unwilling to chase up the parts as they don't want to be hounding the customer. It's been like this for the 11 years I've been here so I'd be interested to see what you come up with!
Old 1st April 2005, 08:09 AM
Karma Power: 20
Default
Thanks for your reply,
It seems the Electronics and Bodybuilding industries are united by a common problem.
I'll let you know what I come up with then. This is definitely a situation that is an accepted inefficiency... odd, when it is the customer who pays ultimately with the late delivery of their goods.
Craig
Old 4th April 2005, 04:17 AM
Karma Power: 0
Default
Hi Craig,
I'm pretty new to quality but if there's any way i can help just get in touch
Elly
p.s good luck!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How to make a lean supply chain peacewong Lean - Lean in Manufacturing and Services 8 23rd December 2008 08:26 AM
Service Company Work Environment Issue - Nonconformance or not? MarilynJ6354 Service Industry Specific Topics 21 28th July 2008 04:02 AM
Lean Product Development Material - Basics of Lean ekonom Lean - Lean in Manufacturing and Services 5 16th October 2007 08:52 PM
Lean and Six Sigma in supply chain operations. m2n3b4 Lean - Lean in Manufacturing and Services 1 29th August 2007 01:11 AM
Integration of lean principles in supply chain regis_gustave Lean - Lean in Manufacturing and Services 4 19th August 2005 12:53 PM
The time now is 09:57 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
