16th March 2005, 10:46 AM
Registration Date: May 2003
Thanks Given to Others: 389
Karma Power: 128
Raw Material Storage - AS9100 Requirements for 'Securing' Bar Stock Steel
I've heard that we need to "secure" our raw material - which for us is bar stock, steel. I don't see that requirement in AS9100. Is it a common customer specific requirement in the aerospace industry?
First thing each morning, I try on my bathing suit. Then, nothing worse can happen the rest of the day.
Thanks to Cari Spears for your informative Post and/or Attachment!
16th March 2005, 12:25 PM
An Early 'Cover'
Registration Date: Mar 2002
Thanks Given to Others: 24
Karma Power: 103
Sounds like you need to get some more info. from whomever told you that you needed to do it. Was it a customer? If so, can they supply their requirement in writing? I'd be curious to see what it is they're after and why.
Mike S. ("Gun Nut")
And they ask me why I drink....
Thanks to Mike S. for your informative Post and/or Attachment!
16th March 2005, 01:46 PM
Karma Power: 128
Hi Mike,
Nah - it wasn't a customer. We are doing a "clean sweep" and a little rearranging back in the saw department where we store our raw bar stock. We want to designate some racks for aircraft quality steel and others for other stuff. Anyway - someone piped up that the certified AQ material had to be totally segregated and "secured".
I didn't think this was true, but I wanted to check it out because I don't have prior aerospace experience and he does. Perhaps that was just the practice wherever he worked before.
I also emailed a customer SQA that I deal with regularly (and he is a pleasure to deal with - no kidding) - he said they don't require this, nor does he know of anyone who does.
16th March 2005, 02:08 PM
Post responsibly
Registration Date: Oct 2001
Thanks Given to Others: 688
Karma Power: 467
Flash back
This is probably a throw back to the old mind set. Remember the old ISO 9001 required (under 4.15.3) "... The supplier shall use designated storage areas or stock rooms.... Appropriate methods for authorizing receipt and dispatch to and from such areas shall be stipulated...."
Many people in Aerospace still think that you have to have a LOCKED MRB crib/room.
Old habits are hard to die. I am not aware of any Aerospace Customer or FAR or other regulatory requirement that requires you to "secure" raw material.
Fighting organizational dysfunction, one post at a time.
Thanks to Sidney Vianna for your informative Post and/or Attachment!
16th March 2005, 02:22 PM
Karma Power: 128
Thank you, Sidney. That clinches it for me.
I think you are correct about the old mind set. I was soooo hoping this was the case. What a PITA that would have been were it required.
16th March 2005, 02:23 PM
Registration Date: Jan 2001
Thanks Given to Others: 318
Karma Power: 255
As long as you can show that you use the appropriate "raw material" for the job, and that you do this by plan, not accident  , all should be good. When dealing with something like steel, it is not always easy to set up warehousing to totally segregate material physically. Most of the systems I've seen, or worked with, did this by allocating raw material to appropriate "jobs" or orders when it was received.
"It's fun to have fun, but you have to know how", Dr. Seuss
Man may have invented fire, it took a woman to learn how to play with it.
Thanks to SteelMaiden for your informative Post and/or Attachment!
16th March 2005, 02:33 PM
Karma Power: 128
Originally Posted by Sidney Vianna
This is probably a throw back to the old mind set...
...Many people in Aerospace still think that you have to have a LOCKED MRB crib/room...
...Old habits are hard to die...
 The FAA Inspector that will be handling our certification said he is really looking forward to seeing how we novices will approach a lot of things compared to some of the organizations that have "always done it this way".
16th March 2005, 05:25 PM
Karma Power: 128
Yep - this is what we do right now - when I order the steel, I use our internal job number for the PO number. That way the saw operator knows I ordered that bar for that job. We also have a minimum inventory of commonly used sizes and types that we always keep on the rack - so we keep the bronzes together on one rack, the Thomson Shafting has it's own rack, etc - however, we've always been pretty lax about what's on what rack because it is all identified by color code or tag and you could still see everything.
We're doing the reorganizing because we are starting to buy steel in larger quantities than just what the job requires - so we need to enforce the rack designations now that there is so much more steel back there.
