Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
16th March 2005, 03:53 PM
Email Address Invalid or Rejected by Recipient System
Registration Date: Jul 2004
Thanks Given to Others: 19
Karma Power: 0
Question About RoHS Components Database - Circuit boards
I read some posts about an automotive makers database for suppliers of electronics that have to comply with RoHS. Can I get some more information? Right now, I am looking for a tool that I can use to convert bills of materials for circuit boards to lead free components and circuit boards that have the right kind of flame retardant. I thought we could just go to the contract house and ask their engineers to go through the BOM and convert it. It won't be that easy.
Thoughts, help, are appreciated!
21st March 2005, 08:56 AM
E-Mails Invalid or Rejected by Recipient System
Registration Date: Jun 2004
Karma Power: 0 Karma: 26
RoHS Assistance and Info
Are you looking to actually change your product or just investigate its makeup? I might be able to help you with some options out there as my organization MDSMap helps company's in complying with legislation such as RoHS, WEEE, ELV and REACH.
Can you describe in a little more detail what you want to do? Also are you supplying the automotive market or the electronics market? The reason I ask is that if your products full under the ELV Directive they are exept from WEEE and RoHS. ELV requires the elimination of Lead Mercury Cadmium and Hexavalent Chromium but it does not touch the Brominated Flame Retardants.
Feel free to contact me if I can be of help.
Chris Harden
MDSMap
23rd March 2005, 03:04 PM
Karma Power: 0
In Reply to Parent Post by Chris Harden
Chris:
We supply a controller board that is integrated into medical or industrial machines that use a touch screen for communicating between the machine and the human user. So, we're in electronics, and about 1/2 of the business is medical. I read about some of the exemptions, but don't think I know the acronym ELV. Can you point me in the right direction to read more?
Thanks.
4th August 2005, 03:09 PM
Registration Date: Aug 2005
Karma Power: 32 Karma: 26
4th August 2005, 03:22 PM
Enginerd
Registration Date: Jan 2004
Karma Power: 63
In Reply to Parent Post by qualitygoddess
Chris:
Thanks.
I'm not Chris - but I can help...ELV stands for "End-of-Life Vehicles" - it was a European Union directive. The IMDS database (International Material Data Systems) database was put into place in order to keep track of each and every component that is used in a vehicle - so that when the vehicle dies and goes to car heaven, we have a record of what materials were used to make it (and what materials could potentially be harmful to the environment, the community, etc. etc. etc.). Basically, say I provide you with a circuit board for the car's computer. My IMDS record for the circuit board would list all the components that I use to make said board, and their relative weights; I am required to disclose all contents of the product, within certain limits. I MUST disclose hazardous ingredients (i.e., lead solder, maybe?). Then, for the circuit board itself - well, we buy that from a supplier - so he may be asked to submit a report to explain what his circuit board is made of. It's all a big convoluted web. In the end, you publish your record - and you can make it public, or viewable to only certain recipients at certain companies.
If you're not in automotive, I don't see why you would need to deal with the ELV - or the IMDS.
Cheers - hope this helps,
-R.
-Rachel
"Why should I be the one to change my name? He's the one who sucks!"
-Michael Bolton, Office Space
5th August 2005, 04:39 PM
Courtesy Access
Registration Date: Jun 2002
Thanks Given to Others: 66
Karma Power: 112
hi Q-G,
Everyone in the electronics world is going through this right now. Every component manufacturer is working on lead-free components. Don't forget lead-free solder, which in many cases requires a whole new soldering process, that also has to be validated.
Does your contract manufacturer buy the components for you? Or do you supply them?
If they provide them, I would pass this requirement on to them. You won't be the only one asking, believe me. They also should tell you where they are with leadless solder. There are multiple options, your engineers should decide if what the sub-contractor is doing meets your needs.
If you're supplying the components, I would take your BOM and go to each of your suppliers and ask them if the components on the board are available in a lead-free version. most of these folks have been working on ROHS and WEEE for years now and should be pretty far along.
You should qualify all these new parts at the board level, at a minimum. Don't know how deep your Engineering group is, but being a medical device manufacturer, you probably should go right down to the component level.
Do you have customer requirements driving this? If so, they may require you to validate that the components are lead free. This is where a database of tested product by manufacturer would be real helpful, as I mentioned in a post on ROHS about two years ago. http://elsmar.com/Forums/showthread....highlight=ROHS
Rosie A
Warrior Goddess of Quality
9th August 2005, 12:10 PM
Karma Power: 0
Thanks for the various links and information. I sloughing through all this stuff. I think I am at a point where it all makes sense. Now just one more question for those of you experts out there. Tell me if this makes sense. For the un-initiated, we sell circuit boards or IC's with our firmware to various OEM's. These boards or chips control specific computer peripherals.
1. I have data from the manufacturer of each component to show the RoHS compliance (test reports,TCLP's, or conformance statements).
2. I have converted our Bills of materials so our contract house can supply RoHS compliant products to us for sale.
3. I created a conformance document that states to our customers that our manufacturer's have told us they are RoHS compliant. Our company does not alter the product in any way that would compromise this compliance.
With that conformance document, have I prepared our company properly to state that our products are RoHS compliant?
As an aside, I am starting to get requests for Product Spec sheets (basically results of ingredient testing). I will take these from the manufacturer's websites and provide them to our customers.
9th August 2005, 12:16 PM
Enginerd
Karma Power: 63
...have I prepared our company properly to state that our products are RoHS compliant?
Jodi,
All I've been doing is writing letters (of certification, I suppose) that state that "Product XXX is/is not RoHS compliant". That's been fine for our customers - that's been all they need. Some customers had specific forms or packages for us to complete - so we did.
One thing to note, though, is that the legislation is changing. Right now the legislation still legally states a tolerance limit of 0%. The proposed limits are currently before the European Commission, but have not been made official yet...acceptance of the changes to the tolerances will increase most of them to 0.1% (not all of them, but i can't remember which ones are different).
Cheers,
-R.
-Rachel
Forum Posting Settings
