Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 15th July 1998, 05:38 AM
Ram narayan
Unregistered Guest
Posts: n/a
Question Gauge Repeatability and Reproducibility (Gage R&R) on all shop floor gages?
I want to know whether GR&R studies had to be conducted on all gauges used in the shop floor or only for a family of gauges. (Like 0-25mm Mics, 0-150mm Verniers etc..) ie.. one instrument from that family. I think that it make sense to conduct GR&R for one instrument from one family because what we are trying to conclude is whether that instrument is suitable for measuring a product characteristic.
Sponsored Links
Old 15th July 1998, 09:13 AM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,892
Karma Power: 604
Default
You don't have to *do* gage R&R on anything. You can use other studies.
The point is MSA as a high level system has to be considered. Basically you address all gages, etc., which you take measurements with which 'affect quality'. In the case of inspection and test gages, typically Gage R&R is part of the standard studies.
You start hitting touchy ground when you want to do an R&R on one gage as evidence of family 'compliance'. If you want to get down to the nitty gritty it can be, and often is, argued that a study has to be done on each gage used for inspection and test on the actual parts and with the actual operators - this is quite often the case.
And you have to look at the family of which you speak. Are they all the same brand from the same manufacturer and are they the same model (etc.)? I saw one situation where a 'qualification by similarity' failed.Same gage and model but one was 5 years older than the first. From that there were/are a lot of reasons why they may *not* be alike.
We come back to common sense and an implied understanding of MSA. As you go through design (APQP) youi have to look at the situation as a whole - What precision is necessary, etc. This is where you decide what you have to do to 'prove' your measurement and test equipment as well as the environment it is used in and such.
You have to be ready to explain to the auditor what you're doing and why. Proof (studies) may or may not be in order, but it appears auditors are wanting more and more evidence - so specific, extended studies will probably be more important in the future.
Can you 'qualify by similarity or family'? Yes - if you have good evidence that your hypothesis is true.
Sponsored Links
Old 15th July 1998, 09:21 AM
Christian Lupo
Unregistered Guest
Posts: n/a
Default
If you are a QS-9000 certified company or you have plans to be the answer is simple. All equipment defined in the control plan must have MSA, which includes GRR. Calipers and mics will need GRR. It is not acceptable to perform MSA on one gage, and have it represent a family of gages of the same type. Remember GRR measures the total variation in a specific gage not a family of gages. No two gages are the same, therefore they will have different levels of variation.
Old 23rd July 1998, 04:02 AM
Marc's Avatar
Karma Power: 604
Default
Christian - I disagree with you here. Some common sense is involved. You do not have to do a gage R&R on every instrument on the control plan. It was not long ago that all the big 3 wanted was a gage R&R - it was a defacto standard. Now it came to pass that the big 3 found out about Measurement Systems Analysis. Well, they knew it was there (sorta) 'cause there was this great AIAG manual.
When auditors came and checked out the requirement of QS9000, they really (early on) just looked for common sense, a base understanding of MSA (is the rightr equipment chosen, and such), a strong calibration system and gage R&R. Over the last year most of the registrars are stressing MSA more. I'm not sure why. I know the first report to come to me was that UL was acting an ass again (I get lots of 'complaints' about UL).
I just went thru this with LRQA at Motorola in May. We did not graph studies of bias and such. I'd go into detail but I've typed responses to these MSA issues several times already that I refuse to do it again.
If you take a cruise to <a href="http://qs9000.com/old_forum.html" target=blank>The Old Message Base Threads Listing</a> you will find this discussed a number of places.
In the 'new' QS9000 MSA is addressed in 4.11.4 where it states: "Appropriate statistical studies shall be performed..." Keyword = APPROPRIATE
This leaves it to you to do what you can justify as 'appropriate'. If an R&R is not approprite, then it's not appropriate.
We come back to this: Can you explain what you are doing and why?
Hell - most of the auditors I've come up against are MSA stupid anyway. At best most understand one part of MSA as a high level system - they understand Calibration Systems Requirements - NOT MSA. One of the most important parts of the whole thing is upfront - determination of appropriate M&TE - how many autitors have you heard ask to be taken thru the selection process?
My 10 cents....
Old 23rd July 1998, 05:30 PM
Steven Sulkin
Unregistered Guest
Posts: n/a
Default
The question was asked, do all gages have to be studied? My question is, do all products have to be studied? We have gages that are used for a bazillion products, many having different specs. Our data collection is also unusually expensive.
Is there a simple approach to this? Going back to Marc's comments, "what percision is necessary," we need a percision that is enough to prevent significant type I and type II errors. I define this as, "RR cant be more than 30% of tolerance." If my definition holds, I should only have to do studies for the products with the tightest specs. As long as they meet my rule (<30%), I should be ok right?
Also, if I find that many gages are above 30%, but I have action plans in place and work being done to get to the below 30% mark, can I still be certified?
Old 24th July 1998, 09:27 AM
Christian Lupo
Unregistered Guest
Posts: n/a
Default
Marc-
Actually you do agree with me; I guess I didn't make the distinction between MSA and GRR. What I meant to say is that a compny must use MSA on all IM&TE in the control plan. MSA not necessarily means GRR. As an example of what I mean, the last QS-9000 registration audit I performed I wrote the company up for not following the MSA manual eventhough they had done GRR studies. Their equipment was mostly calipers. Upon further investigation this particular company did not evaluate linearity, bias, stability, resoultion, range of use etc... How could they evaluate total variation (GRR) if they did not even know the variation inherent in their equipment?
Old 7th August 1998, 05:46 AM
Howard Atkins's Avatar
Howard Atkins Howard Atkins is offline
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
Howard Atkins is appreciated, and has over 1700 Karma points.
Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Howard Atkins
Default
When it says in QS 4.11.4 that "this requirement shall apply to the measurement system referenced in the Control Plan" can I submit results of a system that I have used in another submission or does it have to be specific to the part I am submitting?
Old 7th August 1998, 04:36 PM
Marc's Avatar
Karma Power: 604
Default
Typically R&R is done (or other validation of the system or instrument) on the item as is on the control plan. But - you have to look at frequency and such as to what studies you have to do at all.
And - depends upon the measurement being taken and the system as a whole with consideration to the techniques you are using to validate. For example, R&R is on a specific dimension of a specific part (or multiple dimensions in cases such as a with a CMM - which is really an R since there's only one operator) per the control plan line item number.
I think, Howard, we're back to some common sense. As an auditor I typically expect to see a match with the control plan, though.
Why don't you start a new thread with some details and we can bandy it about.
Reply
Bookmarks
Tags
gage r&r studies, measurement system analysis, msa, repeatability, reproducibility
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Gage Reproducibility & Repeatability for POKA-YOKE (pass/fail) gage? ario80 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5 23rd September 2009 02:05 PM
Gage R&R (Reproducibility and Repeatability) using Minitab 14 mani110 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3 29th December 2008 11:44 PM
Gage R&R (Repeatability and Reproducibility) for Dummies D Flannery Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19 5th September 2008 08:05 AM
Determining Gauge R&R (Repeatability and Reproducibility) Interval DJN Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 3rd March 2004 07:30 AM
Gage R&R (Repeatability and Reproducibility) Study with one appraiser MSAFAI Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 10th September 2003 05:12 PM
The time now is 04:01 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
