Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics > AQL - Acceptable Quality Level
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 21st March 2005, 04:51 AM
Libie Libie is offline
Registration Date: Mar 2005
Karma Power: 19
Libie has less than 100 Karma points so far.
Please Help! Incoming (Receiving) Inspection - Is it really necessary that we follow the AQL?
> Sir,
> i would like to know if we can use 5 pieces per lot during inspection instead
> of using AQL? what would be the possible advantages and the disadvantages of
> using the "5 piece-inspection"?
> is it really necessary that we follow the AQL in the inspection process? or
> can we define the sampling size depending on our company's decision?
> thank you.
> libie
Sponsored Links
Old 21st March 2005, 01:54 PM
Scott Catron's Avatar
Scott Catron Scott Catron is offline
True Artisan
Registration Date: Aug 2003
Thanks Given to Others: 34
Karma Power: 52
Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.Scott Catron is appreciated, and has over 700 Karma points.
Question
The first question I have is: Whose AQL are we talking about?
The supplier's? You don't have to use a supplier's AQL, but it helps to know how they inspect their products.
A customer's? Is the customer requiring a certain level of inspection? If so, this is a question for them.
Your own? Why have an inspection process if you don't want to follow it? Change it to what you want to do, but I'd have ample justification in case a customer or regulator asks why it was changed.
I don't have a solution, but I admire your problem. -- Steven Wright
I'm a moderator here, so if you need help with something, feel free to ask.
Sponsored Links
Old 21st March 2005, 08:48 PM
Karma Power: 19
Default Incoming (Receiving) Inspection
thank you for the reply...
it is the AQL stated in the JIS (Japanese International Standard).
sir, if we would be having our own sample size for inspection, what would be the possible justifications? i have here some ideas wherein i can get some justifications: 1. history of nonconformanaces, 2. documented procedures (we can change it to 5 pcs/lot), 3. process capability, 4. costs, 5. we have existing supplier audits. sir, what would be the other items to be be considered so that we would have objective evidence during the surveillance audit.
Old 21st March 2005, 09:08 PM
JRKH's Avatar
JRKH JRKH is offline
Involved - Posts
Registration Date: Apr 2001
Thanks Given to Others: 56
Karma Power: 95
JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.
Default
sir, if we would be having our own sample size for inspection, what would be the possible justifications? i have here some ideas wherein i can get some justifications: 1. history of nonconformanaces, 2. documented procedures (we can change it to 5 pcs/lot), 3. process capability, 4. costs. sir, what would be the other items to be be considered so that we would have objective evidence during the surveillance audit.
The points you stated should be ample justification for the change. If the history of the incoming product is good enough, your wasting your time inspecting more.
Just make sure you address what happens if there is a drop in the quality of the incoming product. i.e. sampling goes up, and suspect product rechecked etc.
James
Low tech is better than no tech.
The only constant is those who declare, "Things around here will never change!!"
Old 22nd March 2005, 12:39 PM
cncmarine's Avatar
cncmarine cncmarine is offline
Registration Date: Feb 2004
Thanks Given to Others: 1
Karma Power: 31
cncmarine is appreciated, and has over 100 Karma points.cncmarine is appreciated, and has over 100 Karma points.
Default
sounds like you have enough controls in place to not take out rec. inspection completely.
Old 22nd March 2005, 01:10 PM
howste's Avatar
howste howste is offline
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 377
Karma Power: 206
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
Default
If you are going to do sampling inspection, you need to understand what sampling plans are all about. A blanket 5 piece per lot inspection is probably not going to achieve anything of real value. Here's a link to a fairly good article about sampling that may answer a few questions:
http://www.variation.com/techlib/as-7.html
Thanks to howste for your informative Post and/or Attachment!
Old 22nd March 2005, 02:13 PM
Bev D's Avatar
Bev D Bev D is offline
Registration Date: Jan 2003
Thanks Given to Others: 265
Karma Power: 137
Bev D is appreciated, and has over 1700 Karma points.
Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.
Default
If you are only concerned with a sampling plan that is 'acceptable' to an ISO9000 auditor - you can use anything you want. as long as you can rationalize it and (in the case of incoming inspection) that you satisfy the requirements for supplier controls. (I've worked at companies where there was virtually no incoming inspection and it can work if you are controlling your suppliers.)
On the other hand - if your customer has specific requirements - you need to satisfy them.
from a technical perspective, a blanket sampel size of n=5 is not effective. When dealign with categorical data (pass fail) 5 is no where near enough - you might as well do none. If dealign with continous data and you have performed the appropriate capability studies, 5 may well be enough to detect a shift or trend in the data - as long as you continue to use continous data.
Old 23rd August 2007, 09:23 AM
sushant_kulkarni sushant_kulkarni is offline
Involved in Discussions
Registration Date: Jul 2006
Karma Power: 15
sushant_kulkarni has less than 100 Karma points so far.
Default Re: Incoming (Receiving) Inspection - Is it really necessary that we follow the AQL?
First of all, 5 pic. per lot ........
1) Its totally depand upon lot size. U canot only inspect 5 pic from 20,0000 pic its 00025% of inward
2) As from u will find 5 pic inspection just as an case find out allpha & beta error. Its too risky for buyer as well as supplier.
When u use AQL or AOQ their is Logic behind that that u must understand.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Critical Characteristics in Incoming (Receiving) Inspection - Inspection Levels luciano Inspection and Test, Sampling and Related Topics 14 20th October 2009 01:54 AM
Incoming Receiving Inspection from Sister Plant spalomino ISO/TS 16949 - International Automotive Quality Systems Standard 7 22nd July 2009 03:49 AM
Incoming (Receiving) Inspection of SMT components MANATEC Inspection and Test, Sampling and Related Topics 4 30th April 2009 12:18 AM
Is AQL necessary for ISO 9001 receiving inspection? luciano AQL - Acceptable Quality Level 24 23rd August 2007 09:14 AM
Incoming Receiving Inspection Form KidPaddy Documentation Control Systems, Procedures, Forms and Templates 6 8th February 2007 01:14 AM
The time now is 02:58 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
