26th March 2005, 01:23 PM
Registration Date: Mar 2005
Karma Power: 19 Karma: 10
Quality program, where to begin? One man machine/mold shop
I'm close to retirement and have set up a one man machine/mold shop for extra income. I have the CNC machines, lots of inspection tools and a few small orders. However, checking with a few potential customers it has become clear that if I want to expand my customer base, I will need to have a Quality system in place and a manual. Where does one start? I see a number of manuals posted here but I'm not seeing any for a small machine shop specifically. This is all new to me even though I've worked in the machine and mold shop industries for the last 30 years.
26th March 2005, 08:46 PM
Involved - Posts
Registration Date: Jul 2003
Thanks Given to Others: 29
Karma Power: 50
Welcome to the Cove!
Rather than copy the manuals, I suggest you flowchart your process starting from quote/receive order stage till shipping.
There are six mandatory procedures which are generic to almost any company and you probably can find examples here.
Download the manual that seems to fit your application and ask questions in this forum.
A manual does not have to be complicated. It must however reflect what you do.
I would recommend that you read through most of the ISO 9000 posts.
Good luck,
Danny
26th March 2005, 08:50 PM
Registration Date: Jan 2004
Thanks Given to Others: 964
Karma Power: 360
Hi Moldcore, welcome to the Cove!
I did a Google search (key words "quality manual job shop" and found a site with samples for you to look at. http://www.link1.com/mod_documentation.html
Some people buy "canned" manuals, which I don't recommend because they are often laid aside as irrelevant. It's better to make your own manual, describing what you do, based on ISO 9001 (or equivalent) as a template of sorts.
Manuals don't have to be complex, and tons of documents aren't needed. A work instruction can be a flow chart, and even a job order that has handling, material and fabrication instructions, specifications and dimensions on it. A Google search of your own (use three to five key words in your searches) can reveal several examples that you can use to decide upon the manual style you prefer. But manuals can be a lot of work and confusing for those without much experience with such things. Technical writing can be very tedious!
Some outfiits, like this one, help you make the manual by customizing documents according to your needs and practices. http://www.eq-usa.com/Documentation%...etails.htm#DD1
If you are to be satisfying clients with your QMS, you'll probably want to hire a consultant to do the periodic internal audit because you can't audit what you personally do. You might consider asking some, and discover they have some manuals in their own tool boxes; they could perhaps assist you with your formatted QA manual.
I want to stress that you should have as large a part in this process as you are comfortable with, because it's your system and the manual should say what you do, not try to do what's in some foreign-looking book thing.
I hope this helps!
Jennifer
Stealth quality versus no quality
27th March 2005, 10:21 AM
Registration Date: Jun 1999
Thanks Given to Others: 33
Karma Power: 397
Welcome to the Cove
You have the opportunity to validate quite a bit of what I've told folks that a small single person operation can do to meet QMS requirements. You'll not need to generate a ton of documentation or any of the garbage that clutters up other organizatuions. Keep it simple as Jen said and flowchart your basic process. There is a ton of stuff here. There are also a couple of small QMS manuals that folks here have provided you could most readily adapt to suit your needs.
Don't, don't, don't get some consultant to "help". You can get pretty much all the help you need here. If you can find someone, lets say from a local ASQ group or from an organization that has a QMS in place that will volunteer to help you if you get stuck, use 'em as a sounding board. If a customer requires some kind of 3rd party validation of your QMS get someone with verifiable competency, who won't charge an arm and a leg (we can help you with that I'm sure).
In this site we have literally a ton of attachments, that you can freely use at no cost, that can be used as excellant templates for developing what you need.
Remember, you can keep it simple.
None of us is as smart as all of us...Ken Blanchard
27th March 2005, 10:48 AM
Karma Power: 360
Originally Posted by Randy
Welcome to the Cove
...Don't, don't, don't get some consultant to "help". You can get pretty much all the help you need here. If you can find someone, lets say from a local ASQ group or from an organization that has a QMS in place that will volunteer to help you if you get stuck, use 'em as a sounding board. If a customer requires some kind of 3rd party validation of your QMS get someone with verifiable competency, who won't charge an arm and a leg (we can help you with that I'm sure).
Randy is correct and I should either withdraw my consultant blurb or add: the problem with consultants is that it is so hard to find one who will work hard to keep it simple for you, not work hard to make a fee. One can't always be sure the consultant is really good before paying the fee. It is too easy to think of the manual like a product you buy.
I once scared off a client by quoting a large price to write his quality manual for him. His old manual was clearly not being used, or else he simply had no idea regarding the system he was soon to be audited on as a Department of Defense contractor.
I didn't get that client, but I believe he was better off for it. The man ended up going to his local university for help, and received it--I hope he had a lot of hands-on involvement in the manual's creation.
You might also check out your local university if the Cove doesn't have all the information you need--but like Randy said, there's an awful lot of good stuff available here!
27th March 2005, 12:01 PM
Karma Power: 360
In another thread I just gave a poster direction to a book I have in my own library. Perry L. Johnson did a pretty good job of describing the who-what-when-where-why's of ISO 9000 in "ISO 9000: The Year 2000 And Beyond". I have the 3rd Edition.
The book includes a sample self-assessment and simple generic quality manual.
While information on this forum is bountiful and free, I mention this book because some people like to have something tangible to learn from, and ISO is pretty much the default structure for quality manuals. The book, or one like it, is bound to be available in a good book store like Borders et.al.
27th March 2005, 09:47 PM
Courtesy Access
Registration Date: Nov 2000
Thanks Given to Others: 1
Karma Power: 67
[QUOTE=moldcore]checking with a few potential customers it has become clear that if I want to expand my customer base, I will need to have a Quality system in place and a manual./QUOTE]
Danny K gives good advice.
You obviously have your own particular techniques and methods of obtaining a contract, procuring parts/materials and, processing and checking your working pieces from design requirements to completion and delivery.
This being said moldcore, your current techniques and methods are what shall constitute the genesis of a so called "Business Manual".
The techniques and methods you currently use, are your processes and procedures, write these down and you have the beginnings of your business Manual.
Of course this is the simplified approach, however it's clear as a one man business: you may be potentially asked by your clients, to merely conform to the intents of a stipulated business or technical standard requirement.
It is best (and advised) practice though to, consider adopting the overall intents of a business model such as ISO 9001.
It really depends on your client base of course. Being near retirement, you may wish to stay under the proverbial radar of stipulated requirements by clients. The job pieces you process may merely have specified tolerances as a stipulation to a standard.
It's a judgment call you have to make based on time and business commitment constraints that say, in reality you are a one man business offering a niche service.
good luck.
Wallace.
Ask, Seek, Knock.
28th March 2005, 01:13 PM
Involved in Discussions
Registration Date: Jul 2004
Thanks Given to Others: 12
Karma Power: 42
This stuff was all new at some point to each of us. You may not have found a manual that was specific to a machine shop, but some of the manuals posted will help you determine what needs to be in your own manual. You really can keep it simple. Others have already said it -- start with a flow diagram of your process. You can probably get all the details on a few pages. Then you really just need a few other documents and you are all set with a defined quality system. The old adage -- "say what you do, and do what you say" fits here. Let us know if you want more details!
Another nice little book about the ISO 9001 quality system is by Herbert Monnich, and is called ISO 9001 for Small and Medium Sized Businesses.
If at first you don't succeed, go shopping.........
