Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Software Quality Assurance
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 4th April 2005, 05:49 AM
sujoy sujoy is offline
Registration Date: Apr 2005
Karma Power: 19
sujoy has less than 100 Karma points so far.
Question ISO 15504 - 'Embedded Systems' - Software Requirements vs. System Requirements
When describing the "system" requirements for an embedded system, the functionalities which are to be provided by software are also described. However, ISO 15504 asks for a separate software requirements also. How will the software requirements differ from those described in the system requirements?
Regards,
Sujoy
Sponsored Links
Old 23rd June 2005, 09:32 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
Anyone knowledgeable on this topic?
Sponsored Links
Old 18th August 2005, 06:04 PM
RobDavisPE RobDavisPE is offline
Registration Date: Aug 2005
Karma Power: 18
RobDavisPE has less than 100 Karma points so far.
Default
Originally Posted by sujoy
Hi, When describing the "system" requirements for an embedded system, the functionalities which are to be provided by software are also described. However, ISO 15504 asks for a separate software requirements also. How will the software requirements differ from those described in the system requirements?
Regards, Sujoy
ISO 15504 (also known as SPICE, i.e. Software Process Improvement and Capability Determination) is a framework for the assessment of software processes. It was developed by the International Organization for Standardization (ISO). ISO 15504 can be used in two contexts: process improvement, and supplier evaluation.
To answer your question, having a separate set of software requirements is usually not an issue at most companies. If it appears to be an issue, and especially if your company uses ISO 15504, then you want to ask management that under ISO 15504 allow you to spend time to develop a list of software requirements (in addition to system requirements).
"Separate" does not and should not mean any new conflict or any new contradiction. Just because ISO 15504 asks for separate software requirements, systems requirements are NOT going to and should not contradict any of your software requirements.
Additionally, because systems engineers usually take a high-level approach, it is unlikely that the (low-level) software requirements under ISO 15504 are going to contradict any (high level) system requirements.
In the unlikely event there's a conflict, it can be brought to a meeting and negotiated. Just because ISO 15504 asks for separate software requirements, (high-level) systems requirements should not contradict any of your (low-level) software requirements.
I hope this helps.
Regards,
Rob
Software QA Engineer
Old 21st November 2005, 11:57 AM
Paul Mc Paul Mc is offline
Involved - Posts
Registration Date: Aug 2000
Karma Power: 38
Paul Mc has less than 100 Karma points so far.
Default
I hope this helps.
Regards,
Rob
Hi Rob,
it's been "recommended" by am OEM that we should go for this accreditation, for process improvement, though we know very little about it! a couple of questions:
1. do you need to be a software guru to audit against it?
2. how long to implement? we're a Tier1 auto electonics co. ~420employees with ~ 50 R&D engineers
3. Main tangible benefits you have found?
4. any pitfalls to watch out for?
Old 12th December 2005, 08:31 AM
Involved - Posts
Karma Power: 38
Default anybody??
Has anybody any experience in implementing this software standard within the automotive supply industry??
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Is firmware or embedded software subject to the same standards as software? svijayc Qualification and Validation (including 21 CFR Part 11) 9 16th November 2009 09:46 AM
ISO 9001 Requirements for associated service - Design and develop software Mikhail Design and Development - Process and Product 7 26th August 2008 11:32 PM
Systems Requirements vs. Process Requirements for TS16949 chaosweary ISO/TS 16949 - International Automotive Quality Systems Standard 5 16th February 2006 09:06 PM
Looking for the Quality System Requirements for ISO / TS 16949 R.A.A. ISO/TS 16949 - International Automotive Quality Systems Standard 2 17th March 2005 01:20 PM
Automotive SPICE - Assessment to ISO/IEC 15504 Software Process Assessment dorling Customer and Company Specific Requirements 3 2nd December 2003 09:11 AM
The time now is 07:47 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
