Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Excel .xls Spreadsheet Templates and Tools
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 14th April 2005, 09:46 AM
Winner Winner is offline
Involved - Posts
Registration Date: Jan 2005
Karma Power: 20
Winner has less than 100 Karma points so far.
Send a message via AIM to Winner Send a message via Yahoo to Winner
Let Me Help You Sorting in Microsoft Excel .xls - I want to create a Pareto Chart
Howdy,
This is a Microsoft Excel Problem. I want to create a Pareto Chart and I have data in this form
Cause: Frequency
Cause 1: 10
Cause 2: 30
Cause 3: 5
Cause 4: 40
I want to create a sort on that and get the data in this form
Cause: Frequency
Cause 4: 40
Cause 2: 30
Cause 1: 10
Cause 3: 5
I am sure there must be some way in excel to do that, just using sort doesnt work because it sorts only the frequency and the other column remains the same.
Thanks a lot,
Harsh
Sponsored Links
Old 14th April 2005, 10:15 AM
CHESHIRE STEVE CHESHIRE STEVE is offline
Getting Involved (6 to 9 Posts)
Registration Date: Feb 2003
Karma Power: 28
CHESHIRE STEVE has less than 100 Karma points so far.
Default
Have you tried highlighting both columns cause and frequency, and all of the data.
Then go to Data>Sort>Sort by and sort your frequency column in descending order.
This should also sort the cause column at the same time.
Steve
Sponsored Links
Old 14th April 2005, 10:21 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is online now
Courtesy Access
Thanks Given to Others: 755
Karma Power: 612
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Default
I'm using Excel 2003, but the method should be at least approximately the same for earlier versions:
1) Select both columns
2) Click on Data (on the "standard" tool bar), then Sort
3) In the resulting dialog box, choose the option at the top (Sort By...) and select the column where the frequency data appears in the drop-down box (let's say it's B in this example), then select Descending and click "OK."
The data should be sorted as you want it. Post back if you still have trouble.
Old 14th April 2005, 10:40 AM
Claes Gefvenberg's Avatar
Claes Gefvenberg Claes Gefvenberg is offline
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Lightbulb
Yep that's what I do as well. Works for me... See enclosed example.
Claes
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Hanlon's Razor.
Never attribute to malice that which can be adequately explained by stupidity.
User Groups: Elsmar Cove Cycling Enthusiasts Formula 1 fanatics Photo freaks Readers Corner
Old 14th April 2005, 11:02 AM
Involved - Posts
Karma Power: 20
Default Thanks
Thanks a lot guys for your time! It works for my data!
regards,
Harsh
Old 14th April 2005, 04:04 PM
James Oldham James Oldham is offline
E-Mails Invalid or Rejected
Registration Date: Feb 2005
Karma Power: 0
James Oldham has less than 100 Karma points so far.
Default
For those using Excel 2003 or >, there is a histogram maker inside the "Data Analysis" add-in. A little goofy until you get used to it, but is pretty handy, especially since it lets you specify your own custom bins.
Old 27th February 2009, 01:00 PM
cconway cconway is offline
Shy Poster (1 to 5 Posts)
Registration Date: Feb 2009
Karma Power: 3
cconway has less than 100 Karma points so far.
Default Re: Sorting in Microsoft Excel .xls - I want to create a Pareto Chart
Hello
The chart was great, however I am having trouble getting my % line to be elevated, mine is flat. What could I be doing wrong?
Old 27th February 2009, 01:54 PM
Jennifer Kirley's Avatar
Jennifer Kirley Jennifer Kirley is offline
Registration Date: Jan 2004
Thanks Given to Others: 964
Karma Power: 360
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Welcome cconway!
Can you attach an example of what you mean? I am having a hard time visualizing it.
Stealth quality versus no quality
Reply
Bookmarks
Tags
.xls, excel, excel spreadsheet, pareto charts
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Pareto question Microsoft Excel little__cee Excel .xls Spreadsheet Templates and Tools 6 24th November 2008 04:05 PM
SPC p Chart form in .xls Excel hgallego98 Excel .xls Spreadsheet Templates and Tools 3 2nd May 2007 12:02 PM
U chart and X & s chart - Seeking Excel .xls templates / forms KidPaddy Excel .xls Spreadsheet Templates and Tools 3 4th October 2006 12:42 AM
X-R chart - I need a Microsoft Excel .xls Programmed X-R chart spreadsheet! cokyat Excel .xls Spreadsheet Templates and Tools 40 24th August 2006 05:07 AM
X bar s chart template / form for Excel .xls randymhl Excel .xls Spreadsheet Templates and Tools 2 14th March 2006 11:19 PM
The time now is 10:11 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
