Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
20th April 2005, 11:16 AM
Involved - Posts
Registration Date: Jan 2004
Thanks Given to Others: 13
Karma Power: 49 Karma: 120
List of NCR (NonConformance Report) Defect Cause & Corrective Action Codes
We are developing an on-line non-conformance reporting (NCR) system to capture all defects found, their root cause and corrective action. We need to assign and insert codes for defects, causes and corrective actions to make the data usable to spot trends and systemic problems.
Our industry is automotive.
Our company does CNC machining, injection molding, blow molding, painting and some low volume assembly.
REQUEST
The first NCR system implementation is in the machining area. Does anybody have a reasonably sized list of defect, cause & corrective action codes they could post here? I need to populate the database / library of each section of the NCR system.
20th April 2005, 01:10 PM
Registration Date: Jun 2000
Thanks Given to Others: 472
Karma Power: 280
I moved your thread to the this board where you may get a better response.
CarolX
Theater is life, film is art, and television is furniture.
20th April 2005, 01:46 PM
Involved - Posts
In Reply to Parent Post by CarolX
I did think I might have posted in the wrong place. I was trying to avoid all the NCR threads on audit NC's. This system is for part defects from making widgets.
25th April 2005, 07:53 PM
An Early Cover
Registration Date: Jul 2003
Thanks Given to Others: 204
Karma Power: 139
In Reply to Parent Post by wslabey
Wslabey
Here is all I could quickly find ( about 15 slides in)
***DEAD LINK REMOVED*** Quest Design Structure
This is bugging me - somewhere I recall seeing a massive list...but I can't think where..perhaps Jurans Handbook?
At my last job (fiber optics) they had build a huge NCR system in Lotus Notes. There were hundreds of defect codes, and hundreds of root causes.
The defect codes were useful for Pareto analyis, but the root cause codes were useless, there were too many, most of them were symptoms.
One idea would be to set up your system to allow new codes to be defined on the fly. This would let you start with a very few codes and let users define/propose new ones on the fly.
Then every so often, you could look at the data and either accept the code or change it to an existing code.
We are presently working on corrective actions and they are hardest of all, a subject matter expert is needed. Most of ours tend to be so vague as to be useless e.g. "adjust and recheck".
Good luck with this, if I find anything else I'll post it.
26th April 2005, 02:22 PM
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 213
I have also operated a system with fault codes and cause codes, and also found the cause codes to be wooly and of little use for analysis.
I would suggest brainstorming a cause and effect diagram, and that should give you all your potential failure modes.
28th November 2005, 06:27 PM
Involved in Discussions
Registration Date: Sep 2005
Thanks Given to Others: 42
Karma Power: 42 Karma: 155
NCR data bank
Iīve been trying to resume all the NCR of 2005 in my job in an Excel file. The root causes and the NC have already codes, but unfortunately all of these information, added to some other that we need to registar in this file are increasing so much that Iīm afraid that Excel wonīt be enough for what I wanted...
Maybe only in Access or in an spencial software...
28th November 2005, 08:29 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,443
Karma Power: 400
Beware of too many defect codes. You may end up with people having problems classifying many defects.
I can't remember off hand whether there is an Access nonconformance database posted here in the forums or not.
One Test is Worth 1000 Expert Opinions - The plural of anecdote is not data - Correlation does not imply Causation
28th November 2005, 08:50 PM
The Access File
Iīve saved the access files that Iīve seen once in the cove, but I couldnīt attached them (maybe they are too big). One is for customer complaint and the other for internal audit. My question is: what would be the ideal way to see the whole NCRs without encoding them? I use an Excel file, and I use codes because each description of cause or NC is different. So, if we want to use Excel filter or dinamic functions, the fewer words is the easier way, isnīt it?
Forum Posting Settings
