Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 28th April 2005, 11:35 AM
DJN DJN is offline
E-Mails Invalid or Rejected
Registration Date: Jul 2002
Karma Power: 0
DJN has less than 100 Karma points so far.
Question Is it possible to have a process that is too good? Cpk is 14.63
Is it possible to have a process that is too good. The reason I ask, is that I have conducted a stability study on a gauge. The Xbar chart shows points out of control. The mean is 36.007. The UCL is 36.014 and the LCL is 36.001 The rbar is .011 and the specification limits are 36.000±.2 I also get a CPk figure of 14.63!! Which I know is invalid if the process is not in control. The range chart is in control. I am mystified as to why the chart would indicate that the process is not stable. Perhaps someone can enlighten me.
Sponsored Links
Old 28th April 2005, 12:06 PM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Default
We have no way of knowing why you have points beyond the control limits. What are you measuring? Do you see similar problems in the process data?
Sponsored Links
Old 28th April 2005, 12:34 PM
QChas QChas is offline
Involved - Posts
Registration Date: Mar 2005
Karma Power: 27
QChas has disabled his/her Karma.
Default
Yes - We cut wire to length using an automatic machine. The machine was very repeatable and having a product spec of +/- 1/2" didn't hurt either. We had CPK's in the 70 - 80 range. After a few years we backed off on our frequncy of measurements. Never had a problem with this number from the customer or the auditor (once they understood the process)
:cool:
Old 28th April 2005, 12:38 PM
martin elliott martin elliott is offline
Involved - Posts
Registration Date: Jul 2003
Thanks Given to Others: 8
Karma Power: 30
martin elliott is appreciated, and has over 100 Karma points.martin elliott is appreciated, and has over 100 Karma points.
Default It does effect GR&Rpv
I don't know about effecting stability but it does effect GR&Rpv.
For example I recently improved a process very significantly 1.8 to 6+. GR&Rpv on new process failed because I cant improve the gauge enough for the drop in the process range value, needless to say I applied common sense MSA Page 23, and told my customer regarding cost effectiveness of improvements MSA Page 46
Martin
Older not wiser
Old 28th April 2005, 12:45 PM
qualeety's Avatar
qualeety qualeety is offline
Involved - Posts
Registration Date: Feb 2005
Karma Power: 27
qualeety is appreciated, and has over 200 Karma points.qualeety is appreciated, and has over 200 Karma points.qualeety is appreciated, and has over 200 Karma points.
Send a message via MSN to qualeety
Default
The problem i see is in your measurement system. Instead of measuring to 1/1000th of an inch, try to round off to 1/100th of an inch. Your chart will be more stable and in-control.
Remember, out of control condition includes other unusual patterns (runs, cycles, etc), not just points beyond the control limits.
Old 28th April 2005, 01:27 PM
Bev D's Avatar
Bev D Bev D is offline
Registration Date: Jan 2003
Thanks Given to Others: 265
Karma Power: 137
Bev D is appreciated, and has over 1700 Karma points.
Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.
Default
Did you do a gauge R&R study and plot the numbers on the control chart? Such that the range data is the range of the repeated measures of the same unit and the average values are the averages of the repeated measurements of each part?
If so - this would give you in control range values and a lot of 'out of control' averages...because you are calcualting the control limits from the average range which would be very tight if your gauge is reasonable. Then the averages are from PARTS wich vary greatly from each other - in comparison to the difference between repeated measures of the same parts...
Also, depending on your software or formula choice - if you calculated the traditional Cpk value (as opposed to the Ppk value) you would have used the within subgroup standard deviation which comes from the range of the repeated measures...again this woulg give you a very small standard deviation compared to your spec limits...
Old 28th April 2005, 03:46 PM
Randy Stewart's Avatar
Randy Stewart Randy Stewart is offline
VINI, VIDI, DORMIVI
Registration Date: Feb 2002
Thanks Given to Others: 20
Karma Power: 84
Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.
Default
I have to agree, it's like you are trying to measure a klick using a meter stick while gauging errors in centimeters. Reduce the accuracy of the gage or tighten up the UCL & LCL.
"What this country needs is more unemployed politicians." Edward Langley
Old 29th April 2005, 03:15 AM
Claes Gefvenberg's Avatar
Claes Gefvenberg Claes Gefvenberg is offline
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Lightbulb Considering the original question...
Is it possible to have a process that is too good? Cpk is over 14
I suppose it is possible: Let's assume you buy top end CNC equipment, and then use it for producing a low spec product you could easily make with an old lathe from 1870 (An extreme case, I know, but just to make an example)?
/Claes
Hanlon's Razor.
Never attribute to malice that which can be adequately explained by stupidity.
User Groups: Elsmar Cove Cycling Enthusiasts Formula 1 fanatics Photo freaks Readers Corner
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Is Cpk a good measure of capability? There are several shortcomings of Cpk Tim Folkerts Capability, Accuracy and Stability - Process, Machine, etc. 31 12th February 2009 07:39 PM
Quality Control Index - We thought that Cpk or Ppk would be good choices vskiller Capability, Accuracy and Stability - Process, Machine, etc. 6 28th June 2007 12:57 PM
Can CPK be a good manufacturing processor’s quality objective? darkafar Capability, Accuracy and Stability - Process, Machine, etc. 14 22nd March 2007 12:58 PM
How much does Cpk > 1.33 represent in precentage of good pieces? tattva Capability, Accuracy and Stability - Process, Machine, etc. 17 14th November 2003 11:09 AM
Cp and Cpk - Cpk is an index that should be applied to a stable process Don Winton Capability, Accuracy and Stability - Process, Machine, etc. 16 13th August 2001 06:50 PM
The time now is 10:59 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
