Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Measurement Uncertainty (MU)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th January 2001, 04:25 PM
David Drue Stauffer
Unregistered Guest
Posts: n/a
Question How to simply calculate Measurement Uncertainty
I have the GUM Works Manual, I have excerpts from the Engineering Statistics Handbook, but I would like a step by step (simple)method for calculating and reporting the measurement uncertainty for M&TE calibration.
QS9000 says our calibration results should include this information, but provide no clear method of doing so. Does this stuff really have to be rocket science. I'm a big proponent of the kiss principle, "Keep it simple stupid".
Dave S.
Sponsored Links
Old 22nd January 2001, 02:43 PM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
I have been reading about measurement uncertainty for some time. I have even set up a special sub-directory within the pdf_files directory. I know of no 'easy' answer. I suggest you read through some of the threads in that directory.
I did a forum search and found numerous 'hits' including http://Elsmar.com/ubb/Forum4/HTML/000072.html -- You might want to check out the thread.
That said, if ANYONE feels they can explain uncertainty easily and / or simply, I sure would like them to help us all out.
Sponsored Links
Old 31st January 2001, 10:49 AM
Ryan Wilde's Avatar
Ryan Wilde Ryan Wilde is offline
Registration Date: Feb 2001
Karma Power: 41
Ryan Wilde is appreciated, and has over 100 Karma points.Ryan Wilde is appreciated, and has over 100 Karma points.
David,
There is no clear cut method of calculating measurement uncertainty. I highly suggest taking a course to become familiar with the concept. Once you understand the concept, and the statistics behind it, it actually becomes fairly easy. I say easy, as opposed to simple. After you take the classes, it is easiest to come up with a general list of contributing factors to calibration uncertainty, such as temperature growth of UUT and standard/M&TE, deformation, repeatability, master uncertainty, resolution error, etc.
I've been where you are, take the class. The books make great sense to me now, but before it was put into plain english, they were well above my head. To save yourself, and your company, some money I suggest you start with the simple one day "Intro" course. Quite often that is all that you will need.
Ryan
Old 1st March 2001, 03:14 PM
Benjamin
Unregistered Guest
Posts: n/a
Could someone please suggest source(s) for the training Mr. Wilde suggests?
Thank you.
Old 3rd March 2001, 01:42 AM
TorqueGuy
Unregistered Guest
Posts: n/a
Thumbs up
There is no easy way to calculate uncertainty as each type of measurement has it's own uncertainty contributors.
The easiest way I have found to calculate my uncertainty is to follow an example. You can find a very good example at *** DEAD LINK REMOVED *** click on the orange document.
You can also ask an expert. I called my local registration authority in Canada and talked with a metrologist for about an hour. He laid out what factors may contribute to uncertainty of my specific tests.
Now all I have to do is calculate it. That should be easy right? ;-/
Old 6th March 2001, 12:50 PM
DICKIE
Unregistered Guest
Posts: n/a
I had great luck with the training provided by Quamtec Corporation. 810-775-5495 ask for James Jenkins. Jenkins@quamtec.com
Old 3rd April 2001, 06:46 PM
BADKINS
Unregistered Guest
Posts: n/a
Thank you.
Mitutoyo Technical Seminars may be a good source: One coming up May 17 in Charlotte, NC - "Estimating Measuring Uncertainty" - 1 day for $325/person. Touted as an entry level course covering ANSI/NCSL Z540-2, PUMA method based on ISO/TR14253-2. Check out thier web site: www.mitutoyo.com
Old 5th April 2001, 08:04 PM
Al Dyer
Unregistered Guest
Posts: n/a
Lightbulb
Try:
www.a2la.org
Look under "recent postings". There are $$$ and free documents and findings.
ASD...
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How to Calculate Sensitivity Coefficients in Measurement Uncertainty ABEGA Measurement Uncertainty (MU) 2 5th October 2009 05:00 AM
How to calculate and apply Measurement Uncertainty in Chemical Analysis - HPLC, GC raghu_1968 Measurement Uncertainty (MU) 8 11th May 2009 05:27 PM
TUR (test uncertainty ratio) based on Standard or Expanded Measurement Uncertainty? ScottBP Measurement Uncertainty (MU) 2 25th March 2009 11:04 AM
How to calculate Relative Uncertainty - Measurements are in different units amanbhai Measurement Uncertainty (MU) 3 1st June 2006 10:33 AM
Measurement Uncertainty - Measurement Uncertainty in Measurement Results Marc Definitions, Acronyms, Abbreviations and Interpretations 0 17th April 2006 08:13 AM
The time now is 11:57 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
