2nd May 2005, 03:30 PM
Involved - Posts
Registration Date: Aug 2004
Karma Power: 22 Karma: 10
Can an assembly process produce 2PPM?
I heart a middle size company (Tier 1) which have several assembly processes said it's PPM is 2.0. I want to know is it truth.
As I know one or two assembly process probably get very low PPM, but whether the PPM of a finished parts(have 5 assembly processes)can reach 2PPM? Becuase if only 2PPM, how is it's six sigma level?
thanks
Michael
2nd May 2005, 04:27 PM
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Right this minute? Who knows? It's possible, but it's also probable that A) the number will change, and B) it most likely bears no real-world relationship to what would happen after actually making 1,000,000 things.
3rd May 2005, 03:14 AM
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
Originally Posted by JSW05
Right this minute? Who knows? It's possible, but ..
Agreed, it is not impossible, merely improbable. An exceedingly simple assembly process would help too.
/Claes
3rd May 2005, 08:46 AM
Registration Date: Feb 2001
Thanks Given to Others: 80
Karma Power: 149
Another consideration is the way the PPM is determined. If, for example it is the number of actual rejects per million parts as JSW05 says, that's one thing, but consider this:
If the number is based on Cpk values determined from a standard "fall-out chart", 2.0 PPM represents a Cpk of 1.6 assuming the process is centered, stable and never shifts. If, however, the 1.6 Cpk is viewed assuming a normal 1 1/2 sigma shift over a given time period the expected fall-out will jump to 460,000 PPM (illustrating the "B" scenario in JSW05's post). This is why a six sigma program is so critical to a process. With a 6 sigma process, even counting the normally expected swing of +/- 1 1/2 sigma, there would only be an expected fall-out of 3.4 PPM.
Dave
"Time you enjoyed wasting is not wasted time"
3rd May 2005, 10:57 PM
An Early Cover
Registration Date: Jul 2003
Thanks Given to Others: 193
Karma Power: 104 Karma: 3066
Poka Yoke
Michael
One can imagine zero defects even in a complex assembly process <BIG IF> a serious product and process design effort was done and serious poka yokes were put in place. And no, I have never seen it done.
We came close in a simple operation for one characteristic with an effective poka yoke. Zero defects for that charactersitic for 18 months followed by 100% defective. Turns out the poka yoke was re assembled wrong after maintenance. So we poka yoked the poka yoke and went back to zero defects. However this was one characteristic on a simple operation.
Surely someone, somewhere has done well on more complex processes?
I sure hope NASA has complex assemblies under control for the sake of the next team to fly the shuttle.
4th May 2005, 03:08 AM
Forum Administrator
Karma Power: 213
Whups  .Well, there we go. Nothing is ever 100% foolproof, but nigh on everything can be improved... Good tale, Caster. Something to remember.
/Claes
4th May 2005, 12:12 PM
E-Mails Invalid or Rejected
Karma Power: 0
98.5% of all our produced parts are hand built. We have enjoyed the status of being able to claim a PPM of 18 or less for the past 3 years from our OEM customers.
While the processes are not perfect and we do make mistakes, being a hand built operation we have the luxury of correcting prior to final assembly and shipment to the customer. One true measure of our quality system at this time is our level of produced parts vs. labor hours. We know that one team member can make .92 parts per hour. If on any given day we have a team member that only made 7 parts or less we know there was an issue that needs investigation.
Just some thoughts.....
4th May 2005, 01:13 PM
Courtesy Access
Karma Power: 611
This highlights another of my objections to the whole PPM concept. If I'm the customer and I ask for PPM data (and feel free to shoot me if I do), I want to know about the output of the process, not outgoing quality level. I know that if a supplier has to make 10 units in order to yield 9 good ones, I'm going to wind up paying for the tenth one anyway, one way or another.
