Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Gage R&R (GR&R) and MSA (Measurement Systems Analysis)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 21st May 2001, 10:16 AM
RLBredeweg RLBredeweg is offline
E-Mails Invalid or Rejected
Registration Date: May 2001
Karma Power: 0
RLBredeweg has less than 100 Karma points so far.
Angry Gage R&R for a Destructive Test - Weld Breakout Test
Gage R&R for destructive Test
What the test is is called is a "weld breakout test" they use a hydraulic press with a gage(Pressure meter) that reads in psi the part is fixtured and a ball on the end of the press comes down and pushes on the weld seam - Minimum specification for fracture is 3,000 Lbs. - No Max spec (infinity) or weld fracture. What I was considering is to verify the accuracy of the gage with a certified strain gage for correlation to the psi meter and than to review the last 30 days of measurement recordings (which I found out were being recorded as pass/fail)
I have to respond back for a CAR written by our Registrar ASAP Can any body give a suggestion?
Sponsored Links
Old 21st May 2001, 05:43 PM
Dan Larsen
Unregistered Guest
Posts: n/a
My experience is with hardness measurements...may be similar, maybe not.
First, you should consider the gage R&R not in terms of the actual test as much as the unit being used for the test. Use (if available) a standard for your pressure machine. Use the same standard, across a variety of operators, and the classic GRR procedure to calculate operator and machine influence. (NOTE: This is NOT a true GRR, but it is a gage CAPABILIY.)
You can use the gage CAPABILITY in conjuntion with PROCESS CAPABILITY (your historical test values) to determine a true GRR.
This is too ornate to try to explain here...I suggest Concepts for R&R Studies by Larry Barrentine for a more thorough evaluation. Or send me private e-mail or give me a call...see my profile.
Sponsored Links
Old 21st May 2001, 06:27 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Covering Ass
From Spaceman Spiff a while back:
-> The best method I found for MSA on destructive testing is
-> through using the ISOPlot method developed by Dr. Dorian
-> Shainin (see www.shainin.com for information).
-> Basically, I would take 2 consecutive samples as a group
-> and collect a total of 30 groups. Next I would use sample
-> 1 of each group as Trial 1 and sample 2 of each group as
-> Trial 2. Then I would plot Trial 1 versus Trial 2 and
-> determine the discremination ratio. It is very similar to
-> correlation, but the method of calculating discrimination
-> ratio is the key to qualify the measurement system.
Old 14th June 2001, 01:27 AM
Brian Dowsett
Unregistered Guest
Posts: n/a
The way I got around this (albeit for a Q1 audit) was to build a rig that simulated the thing being tested. So if we're applying force to a weld to destruction, build a rig that "gives" at a typical range of values, maybe by lifting a set weight through a lever system.
Cheers
Brian
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How to do Destructive Test Gage R&R - Rupture Test Orlando Guillory Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 28 25th September 2009 08:29 PM
Destructive Tensile Pull Test Gage R&R HRinAZ Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8 4th October 2006 11:05 AM
Destructive test, gage R&R with one sided tolerance gavinqce Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 15th March 2006 10:39 AM
Gage R&R - Destructive Test - Tensile Tester Denise Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15 28th December 2005 05:00 AM
Gage R&R (Repeatability and Reproducibility) Destructive Test Method Benoit Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2 22nd October 2002 11:44 AM
The time now is 09:27 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
