Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Lean - Lean in Manufacturing and Services
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 13th May 2005, 04:24 PM
gibu2 gibu2 is offline
Registration Date: May 2005
Karma Power: 19
gibu2 has less than 100 Karma points so far.
Question Low Hanging Fruit - Lean Manufacturing Ideas for a Job Shop
I was reading through some of the discusions about lean and the sugestion of starting with low hanging fruit kept comming up. Now I know everyone has different fruit, but does anyone have some general ideas or principles to share when it comes to low volume job shops? We do low volume CNC work on mostly small parts. I have looked enough to know there is a variety of lean known as job shop lean but I have no idea what the principles of it are since I didn't want to pay for a guy to fly in and visit us or anything.
Sponsored Links
Old 13th May 2005, 05:50 PM
Jennifer Kirley's Avatar
Jennifer Kirley Jennifer Kirley is offline
Registration Date: Jan 2004
Thanks Given to Others: 964
Karma Power: 360
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Default
This is a good question. I will use my experience in a family owned machine shop to help you identify successes or opportunities as I found them.
1. Material identification. If you have different materials that look alike, label them so you only have to make parts once. You can use color coding with spray paint, or etch codes on the ends with a vibration marker. You can also use paint markers. Discipline is required to not cut off the marked end and replace the now-anonymous stock; either cut from the unmarked end, or re-mark it before replacing.
2. Do you mark lots of stock? We once got a shipment of bad stock that looked okay until final machining and micropolishing was done. Then they could see internal cracks running down the center of each length, but the shipment of round stock wasn't marked or segregated--it was piled along with everything else so machining was a costly Russian Roulette game until that steel was gone. Material marking should include lot numbers for traceability. If you don't look for cracks or inclusions with ultrasound upon receiving, you can mark and then reject a lot or batch of stock after the first such defects appear and thus save a portion of failures.
3. Identification after machining. Can you look at a little pile of parts and know, for example, their work order number? Segregate them or physically mark them.
4. Tool calibration needn't be a nightmare. We used 12 colors of nail polish to place a dot on each machine's set of calipers for each month. Computer records were kept on instruments, but it isn't necessary to place a label on each one--especially in a machine shop, where the lubricants break down label adhesives and there are hundreds of those little hand tools. Most nail polish comes off easily with acetone.
5. Do you environmentally control your shop? Does increased temperature/humidity increase your parts' tolerance failure rate? Use a P chart to track types of failures, and note the day--perhaps even the day's high temperature--to draw connections between environmental conditions and failures. If there are significant failures, compare those parts' prices to the costs of closing off and air conditioning spaces where those critical processes are run. You may be surprised how fast you will recoup the environmental costs even if you save half of those failed parts.
6. Don't underestimate the power of a procedure. Do your employees work on craftsmanship, or is there a method to what you do? Is their method consistent, and if not, have you traced failure rates to certain processes where better definition could have saved a part? The more complex the parts, the more helpful it could be to define the processes.
7. Tell them what you want, precisely, before they press the green button. Tell your inspector(s) what you want, and do not shift from that position. This means, if you want to deviate from what you already described as tolerance, call it what it is: a management review. This may sound simplistic, but I have a reason for bringing it up...sigh.
I know you asked for "Lean" but that concept varies per an organization's level and detail of development. Please tell me if I am being too simple, or if you want different information.
Best to you!
Stealth quality versus no quality
Sponsored Links
Old 13th May 2005, 08:47 PM
Wes Bucey's Avatar
Wes Bucey Wes Bucey is offline
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Default
You might want to read this post
Post 18
and this one:
Post 20
in this thread
Quality Information Point - Quality information for operators and technicians
Old 16th May 2005, 09:13 AM
qaspain qaspain is offline
Registration Date: Apr 2005
Karma Power: 19
qaspain has less than 100 Karma points so far.
Default
Thanks Jennifer and Wes. Lots of great ideas there, lots of great reading to do. It's very much appreciated.
Old 18th May 2005, 02:25 PM
michelle8075's Avatar
michelle8075 michelle8075 is offline
Trying to learn!
Registration Date: Apr 2002
Karma Power: 38
michelle8075 is appreciated, and has over 200 Karma points.michelle8075 is appreciated, and has over 200 Karma points.michelle8075 is appreciated, and has over 200 Karma points.
Default
Gibu2,
I was reading Jennifer's comment above about part marking and thought I would share some info.
I know of a company that has some great paint makers, like bingo daubers and some smaller that you can use in your processes if needed for part marking identification. The ink they have is water based or solvent based, so you can determine which type is best for your application.
We use their paint markers, and we really like them. If you want their name / number / contact info, let me know.
Be like "Nike" and JUST DO IT!
Michelle
Old 18th May 2005, 05:35 PM
Caster's Avatar
Caster Caster is offline
An Early Cover
Registration Date: Jul 2003
Thanks Given to Others: 193
Karma Power: 104
Caster is appreciated, and has over 1700 Karma points.
Default Money
...does anyone have some general ideas or principles to share when it comes to low volume job shops? We do low volume CNC work on mostly small parts.....
Low volume job shops – my idea of low low hanging fruit.
My suggestion is go to the money. Run a costing on every job the minute you complete it.
Do serious root cause analysis on any jobs that don’t make the profit you hoped for.
Cost of Poor Quality could become your tool of choice here.
Use this information to improve your Sales, Quoting, Design (setup?), and Manufacturing process in that order.
Job shops lose orders of magnitude more money from bad quotes than from people mistakes on the shop floor.
Good luck – you can much more easily make a big splash in a small pond.
Old 24th May 2005, 03:08 PM
Backbolt Backbolt is offline
Karma Power: 19
Backbolt has less than 100 Karma points so far.
Thumbs up
"We do low volume CNC work on mostly small parts....."
Here are some lean principles you can apply: Eliminate setups. Reduce setup time. Eliminate dedicated fixtures. Eliminate clamp changes and stops on the machine. Now you're talking about some serious cost savings!
Old 24th May 2005, 03:32 PM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
Links and claims edited out of the above post. We really prefer no advertisements here unless the person has been a very active participant for some time., and since the above is a 'first post' it doesn't meet the criteria.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
SPC on the shop floor - We are a job shop CMfgT SPC Monitoring and Statistical Analysis Techniques 5 1st October 2008 02:28 PM
Any folks have article, insight about Lean / Lean manufacturing to share? amanbhai Book, Video, Blog and Web Site Reviews and Recommendations 12 15th October 2007 02:43 AM
Record retention ideas for a sheet metal job shop supplying to a medical device mfg. CarolX ISO 13485 - Medical Devices - Quality Management Systems 11 14th June 2007 04:39 PM
Lean in the Tool and Die Industry (Job Shop) - Applying Lean in "one-off" production imanewbie Lean - Lean in Manufacturing and Services 6 6th February 2006 01:04 AM
SPC in job shop? CNC machine producing a max of 50 pieces per job pradeepm SPC Monitoring and Statistical Analysis Techniques 4 4th November 2005 10:52 AM
The time now is 04:50 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
