The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > Metrology Topics - Measurement Devices, Calibration and Test Laboratories
Forum Username
Wooden Line
Temperature and Humidity requirements for a Calibration Laboratory
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
  Post Number #1
Old 1st June 2005, 02:15 PM
DuaneG
Please Help! Temperature and Humidity requirements for a Calibration Laboratory
What are the requirements for a calibration lab regarding temperature and humidity. Our room is so cold because they are worried about humidity. I want to give them numbers. Our average is 64 degrees and 28% humidity.
thanks
Sponsored Links
  Post Number #2
Old 1st June 2005, 02:54 PM
D.Scott's Avatar
D.Scott
Duane - your lab should function under controlled conditions suitable for performing the tests/calibrations on your scope. Check the specs. you are working to and see if there are specific requirements.
Dave
Sponsored Links
  Post Number #3
Old 1st June 2005, 04:12 PM
CarolX's Avatar
CarolX
Duane, I moved your thread to this board for better response to your question. I suggest you scroll to the bottom of the page for links to similar threads.
  Post Number #4
Old 2nd June 2005, 12:53 AM
Hershal's Avatar
Hershal
DuaneG,
The Recommended Practices (RPs) available from NCSLI (National Conference of Standards Laboratories - International) provide some guidance on lab environmants. http://www.ncsli.org
Generally the guidelines for dimensional: 20 C +/- 2 C, 30% to 40% RH.
Electrical/electronic: 23 C +/- 3 C, 40% to 50% RH.
Hope this helps.
Hershal
Thanks to Hershal for your informative Post and/or Attachment!
  Post Number #5
Old 2nd June 2005, 10:24 AM
JerryStem's Avatar
JerryStem
Our requirements were dictated by the equipment we use. They have specs like 10-100% humidity and 0-100 degrees Celsius. Basically, it didn't matter! (Mostly X-Ray Fluorescence and Beta Backscatter coating thickness instruments).
We set our specs at reasonable levels we could achieve by normal AC and heating, 60-80F and 20-80% RH. We have temp/humidity gauges that can be adjusted/calibrated by traceable standards but since we don't NEED it, we stopped having them certified. We mainly keep them to record the numbers on our certs because customers expect it.
Jerry
  Post Number #6
Old 10th June 2005, 02:11 AM
nitram
Hi Jerry,
Keep in mind that the humidity levels recommended is due to:
1. Corrosion risks increase above 55% RH .
2. Electrostatic discard (ESD) risks increase below 35%RH .
I hope that I'm not misinformed ;-).
Martin
  Post Number #7
Old 14th June 2005, 10:18 AM
W. de Jong's Avatar
W. de Jong
Weigh the influences
If the lab is not a controlled environment then you should examine the influence of the factors on your testresults. Take the factor into account in the uncertainty calculation. If the weight factor is very high you should take out the risk by controlling that factor. e.g. What we did for atmospheric pressure: measurements showed an atm. pressure of 1018 12 hPa in a timespan of a year. The actual influence of the pressure was not a big contribution to the uncertainty of our method of analyses.
Validated it with test results and there was/ is no problem. We don't have to control the atm. pressure. Same with ambient temperature, saved us the cost of an airco.
BR, Wouter
  Post Number #8
Old 15th June 2005, 12:18 PM
Giselle
Duane,
for dimensional measurements 20C (68F) is nominal, you need to evaluate what types of measurements you are making, Chrome/Steel (gage blocks) expand and contract at a rate of 6 microinches per inch of material per degree C. If your measurments aren't any better than 0.00001, then you should be fine at that temperature, but it does sound a little chilly.
Reply
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Calibration Laboratory Temperature/Humidity goes out of tolerance due to Power Loss Tammy C. Metrology Topics - Measurement Devices, Calibration and Test Laboratories 9 23rd March 2012 12:05 PM
Temperature Requirements for an In-House Calibration Laboratory fortyfour73 Metrology Topics - Measurement Devices, Calibration and Test Laboratories 8 15th September 2011 10:25 PM
Is Temperature & Humidity monitoring in a Metrology / Test Laboratory required? drikwah Metrology Topics - Measurement Devices, Calibration and Test Laboratories 28 9th January 2007 06:09 PM
Internal Calibration Laboratory Requirements - Ambient temperature, Humidity, Etc. lday38 Statistical Analysis Tools, Techniques and SPC 3 10th March 2003 09:39 PM
Laboratory Environmental Controls - Temperature and Humidity Ryan Wilde Metrology Topics - Measurement Devices, Calibration and Test Laboratories 5 13th July 2001 08:58 AM
The time now is 11:51 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
