Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Six Sigma
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 8th June 2005, 12:41 PM
jackylpt's Avatar
jackylpt jackylpt is offline
Involved - Posts
Registration Date: Aug 2004
Karma Power: 22
jackylpt has less than 100 Karma points so far.
Default Does anybody can give me a help about the calcuation about no defect on 6 sigma level
Quote the part of an article:
1. "Approximately 2700 parts per million parts/steps will fall outside the normal variation of +/- 3 Sigma. This, by itself, does not appear disconcerting. However, when we build a product containing 1200 parts/steps, we can expect 3.24 defects per unit (1200 x .0027), on average. This would result in a rolled yield of less than 4%, which means fewer than 4 units out of every 100 would go through the entire manufacturing process without a defect."
Question 1,
how to calculate the 4%, and how to calcuate only 4 units of every 100 would go through the entire process without a defect.
2. "In the same case of a product containing 1200 parts/steps, we would now expect only 0.0041 defects per unit (1200 x 0.0000034). This would mean that 996 units out of 1000 would go through the entire manufacturing process without a defect. To quantify this, Capability Index (Cp) is used."
Queation 2,
how to calculate the 996 unit from 1000 would go through entire process without defect?
Is it (1-0.0041)*1000=996? if like this , how to calcuate above the 3 sigma no defect level, is it (1-0.04)*100? that should be 96 product without defect through whole process, not 4 ?
thanks
Michael
Sponsored Links
Old 8th June 2005, 01:31 PM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Default
Just wanted to point out that the question is based on erroneous reasoning; just because .27% of the population may be expected to fall outside the +/- 3-sigma limits doesn't mean that any of those will be defective. Also, the .27% is included in "normal variation"--that's the whole idea. Where the limits are overlaid on the curve is a matter of choice. There's a very good chance that a point outside the limits is due to assignable cause, but it ain't necessarily so.
Sponsored Links
Old 8th June 2005, 02:35 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
First of all, I agree with JSW05 that the article is poorly worded, in that outside 3 sigma is not necesarily defective.
If we assume that 0.27% (2700 ppm) are indeed defective, then with 1200 opportunities, the odds of no defects would be (1-0.0027)^1200 = 0.039 = 3.9%. You could also use the binomial distribution function - =BINOMDIST(0,1200,0.0027,TRUE) in Excel
With only 3.4 ppm, the probability of no defects becomes (1-0.0000034)^1200 = 0.996 = 99.6%
Does that get you on the right track?
Tim F
Old 12th June 2005, 02:46 PM
jackylpt's Avatar
Involved - Posts
Karma Power: 22
Default
Tim F
thanks Tim
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Confusion DPU, PPM & DPMO vs. Sigma Level - ASQ Six Sigma Black Belt hand book Stephane Dubreuil Six Sigma 8 19th June 2009 01:57 PM
Sigma Level and Capability - What are Ppu, Ppl, Sigma Level, Sigma Capability fed-up Capability, Accuracy and Stability - Process, Machine, etc. 6 6th May 2009 08:24 AM
Typical defect ppm level for barrel surface coating process? lebelg Supplier Quality Assurance and other Supplier Issues 1 28th November 2008 06:01 AM
The Improvement in Sigma Level (from Let's fix six sigma) rajeevk82 Six Sigma 4 13th August 2008 06:09 PM
What is the difference between opportunity and defect in Six Sigma? john_johnson Six Sigma 1 22nd July 2005 01:25 AM
The time now is 02:18 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
