Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
10th June 2005, 02:15 PM
E-Mails Invalid or Rejected by Recipient System
Registration Date: Oct 2004
Karma Power: 0 Karma: 65
The meaning of "Evaluation/Measurement Technique" & "Control Method" in Control Plan
What are the differences between "evaluation/measurement technique"and "control method" in a control plan?
Can somebody provide me with examples of the two items?
thank you
10th June 2005, 03:51 PM
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 460
Karma Power: 1124
In Reply to Parent Post by astudent
What are the differences between "evaluation/measurement technique"and "contron method" in a control plan?
thank you
I've been dealing with Control Plans for nearly 30 years. I am not familiar with the word or phrase "contron method." Perhaps there is a typo or something in the context of the source of this question which will help us help you. Can you either give us an online link to the text or copy it here, together with the author, title, edition, etc.?
Essentially, any control plan requires a method of making measurements on the output and determining from those measurements whether the process is in "control" (meaning that the output is consistent, not whether the output is conforming.) One technique is to create a Control Chart of the measurements. Another technique is to create a statistical "picture" of the process based on sampling (Statistical Process Control - SPC.)
In any event, once we understand the source of your question, we can proceed to help you with an explanation.
In all Control Plans, the essential point is how you deal with the data, not necessarily the technique you use to create or manipulate the data.
You've asked interesting questions in the past. I hope we can help you with this one.
10th June 2005, 04:02 PM
Registration Date: May 2003
Thanks Given to Others: 693
Karma Power: 234
Evaluation/Measurement Technique - This column identifies the measurement system being used. This could include gages, fixtures, tools, and or test equipment required to measure the part/process/manufacturing equipment.
Control Method - This column contains a brief description of how the operation will be controlled, including procedure numbers where applicable. Operations may be controlled by, but are not limited to, SPC, inspection, attribute data, mistake-proofing and sampling plans.
(paraphrased from the AIAG APQP Reference Manual)
First thing each morning, I try on my bathing suit. Then, nothing worse can happen the rest of the day.
13th June 2005, 09:02 PM
Registered Visitor
Registration Date: May 2005
Karma Power: 34 Karma: 77
Evaluation/Measurement Technique and Control Method Definitions
The 'Evaluation/Measurement Technique' is the measurement tool used to measure the process or product variable being controlled. As an example, the 'Evaluation/Measurement Technique' would be 'Visual' if you were comparing the contents of the paper work you received in shipping with the purchase order to make sure you received what you bought. In another case, the 'Evaluation/Measurement Technique' could be a micrometer if you were measuring the thickness of a component wall.
The 'Control Method' is the method you are going to use to analyze the data you obtain using the measurement tool identified in the 'Evaluation/Measurement Technique' column. In the first case above, your control method would be a 'Visual comparison with purchase order contents.' In the second case, you might plot the thickness on an SPC chart and thus the 'Control Method' could be 'X bar and R Chart'.
I hope this helps.
Rich Harpster
Harpco Systems, Inc.
Thanks to RAHarpster for your informative Post and/or Attachment!
20th June 2005, 03:35 AM
thank you everybody! It is clear now!
Maybe this question was not one of the more interesting I made, but the CP forms I've seen so far were not done properly from this point of view and this is the reason for my doubt.
For Wes Bucey, It was a mistake: I typed "contron" for "control" and then copied and pasted it on the title, so I made the same error twice!
Added in edit: OK. I fixed the typo in the title for you.-Wes Bucey
7th October 2009, 04:28 AM
Shy Poster (1 to 5 Posts)
Registration Date: Oct 2009
Thanks Given to Others: 1
Karma Power: 16 Karma: 15
Responsibility and Record
Hello sir,
Can some body tell whether RESPONSIBILITY & RECORD columns are required in Control Plan?
Is it a mendatory requirement???
7th October 2009, 10:58 AM
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,805
Karma Power: 1451
Re: Responsibility and Record
In Reply to Parent Post by satyenderdeswal
Hello sir,
In general, when referring to "control plan," we think of the AIAG form and requirements. There is no "Responsibility" or "Record" field on the most recent version of the AIAG form (in the APQP manual, 2nd edition).
Aside from the AIAG control plan, what your control plan must include is generally a matter of customer requirements, or the requirements of your own company.
Everyone has a plan until they get punched in the face (Mike Tyson)
17th May 2011, 08:17 AM
Involved in Discussions
Thanks Given to Others: 16
Karma Power: 57 Karma: 161
Re: The meaning of "evaluation/measurement technique" & "control method" in Control P
What are some examples of "Control Methods" and "Evaluation/Measurement Techniques"
Everyone would have some specific to their plant / industry, but, I would think, there would be some universal ones as well?
Forum Posting Settings
