Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 12th July 1999, 08:45 AM
Joe_1
Unregistered Guest
Posts: n/a
Please Help! Acceptance Criteria for Attribute Data Sampling Plans shall be Zero Defects
Well, there is a statement in under 4.10.1 called Acceptance Criteria for Attribute Characteristics. The actual section is 4.10.1.1 it states "Acceptance criteria for attribute data sampling plans shall be zero defects. Appropriate acceptance criteria for all other situations (e.g. visual standards) shall be documented by the supplier and approved by the customer.
How can I go about meeting this? Where do I mention this in my Quality Manual and Procedures? This little statement is driving me crazy. Please help!!! We are having an audit in about 5 weeks!!! Help!
Joe
Sponsored Links
Old 12th July 1999, 10:43 AM
Jada
Unregistered Guest
Posts: n/a
Lightbulb
Here's a simple suggestion that should work and hopefully make life worth living again.
Simply cross reference all of your Visual standards into the Control Plan. Have your Control Plan authorised by the customer and you've met the requirement. Most times this works, but the key is to have you customer sign off the Control Plan and also to run this scenario by your registrar PRIOR to the audit - remember, you do not want any surprises during the audit. Good luck with the audit.
Sponsored Links
Old 16th July 1999, 11:38 AM
Joe_1
Unregistered Guest
Posts: n/a
Hehehe...
Need more clarity!!!
Old 16th July 1999, 02:16 PM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,892
Karma Power: 604
Yin Yang
Well, on the quality manual, I can only say I advise clients to take the text file of the standard (here QS9000) and 'tailor' it (which is mostly taking things like '...the supplier shall...' and rephrasing it to say '...Company X ...'. No details, only a reference to the level 2. Then yu only have a couple of issues.
For attribute data you you use 0 defects as accept criteria in accordance with a Zero Defects plan.
Your visuals should be cited in your control plan.
Then have your customer sign a copy of the control plan as proof of their 'approval' of your control plan (and the contents, obviously). I guess I can't state it any clearer than Jada. Maybe someone else can phrase this better.
Old 7th January 2008, 03:08 PM
pinpin's Avatar
pinpin pinpin is offline
Involved in Discussions
Registration Date: Aug 2007
Thanks Given to Others: 236
Karma Power: 13
pinpin has less than 100 Karma points so far.
Default Re: Acceptance criteria for attribute data sampling plans shall be zero defects
Dear Marc,
Does attribute data sampling (TS 7.1.2) refer to Mil-std 105E or ANSI/ASQC Z 1.4?
Old 7th January 2008, 03:36 PM
CarolX's Avatar
CarolX CarolX is offline
Registration Date: Jun 2000
Thanks Given to Others: 419
Karma Power: 176
CarolX is appreciated, and has over 1700 Karma points.
CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.CarolX is appreciated, and has over 1700 Karma points.
Originally Posted by pinpin View Post
Dear Marc,
MIL-STD-105E has been superseded by ANSI/ASQC Z 1.4. Both covered Sampling procedures for inspection by attribute.
CarolX
Theater is life, film is art, and television is furniture.
Old 7th January 2008, 06:14 PM
CliffK CliffK is offline
Registration Date: Feb 2007
Thanks Given to Others: 180
Karma Power: 46
CliffK is appreciated, and has over 1300 Karma points.CliffK is appreciated, and has over 1300 Karma points.CliffK is appreciated, and has over 1300 Karma points.CliffK is appreciated, and has over 1300 Karma points.CliffK is appreciated, and has over 1300 Karma points.CliffK is appreciated, and has over 1300 Karma points.CliffK is appreciated, and has over 1300 Karma points.CliffK is appreciated, and has over 1300 Karma points.CliffK is appreciated, and has over 1300 Karma points.CliffK is appreciated, and has over 1300 Karma points.
Do you have a handle on this concept?
Most of the answers you've gotten so far seem to assume that you do, and you're just looking for a way to get it into your documentation.
Old 7th January 2008, 10:03 PM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
It's an 8.5-year-old post. I hope he's not still looking.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Acceptance criteria for visual defects of electronic components rameshs_10377 Inspection and Test, Sampling and Related Topics 4 28th February 2009 10:46 PM
Sampling Plans for Critical Defects ivkcz Inspection and Test, Sampling and Related Topics 1 22nd December 2008 05:27 PM
Design of Lot Acceptance Sampling Plan - Zero Acceptance Number Sampling Plans Karen Whitehead Inspection and Test, Sampling and Related Topics 27 14th November 2008 08:46 PM
Attribute Gage R&R: Acceptance criteria for CrossTab Method? larry hopperrath Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1 13th October 2004 02:06 PM
Zero Acceptance number procedure for Attribute Sampling Unregistered Inspection and Test, Sampling and Related Topics 1 16th December 2003 03:05 PM
The time now is 03:20 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
