Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Manufacturing and Related Processes
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 16th June 2005, 10:31 AM
Andrews Andrews is offline
Involved - Posts
Registration Date: Oct 2001
Karma Power: 39
Andrews has less than 100 Karma points so far.
Please Help! Overall equipment effectiveness - Computing OEE taking all machines taken together
We are computing OEE taking all machines that we have inhouse together. Setting time, breakdown hrs., etc are taken for all machines together and a single OEE is computed. Is this right? or should we compute for only the contsraint machine.
Sponsored Links
Old 23rd June 2005, 07:27 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Default
I would be looking at each machine. You may have a process where you have recognized a 'constraint' machine and bought a second one or something like that. I don't know how you could do a single OEE without having data on each machine/operation/etc.
Sponsored Links
Old 24th June 2005, 08:46 AM
peteroldfield1971 peteroldfield1971 is offline
Involved - Posts
Registration Date: Mar 2005
Karma Power: 24
peteroldfield1971 is appreciated, and has over 200 Karma points.peteroldfield1971 is appreciated, and has over 200 Karma points.peteroldfield1971 is appreciated, and has over 200 Karma points.
Default
You could measure this in 2 ways. First, calculate OEE for individual machines. Then use these figures to calculate plant efficiency. This would highlight individual machine concerns. You could have a plant efficiency at 75% but this would not show that 2 machines could be running at different levels of efficiency. So in effect one machine could be carrying the other. I guess its all down to the amount of time and effort you can put into it each week/month and what data is available.
I have attached an example of the difference in machine efficiency and plant efficiency for you to review.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
File Type: xls Overall Equipment Effectiveness Sample.xls (48.5 KB, 720 views)
Thanks to peteroldfield1971 for your informative Post and/or Attachment!
Old 24th June 2005, 11:00 AM
Randy Stewart's Avatar
Randy Stewart Randy Stewart is offline
VINI, VIDI, DORMIVI
Registration Date: Feb 2002
Thanks Given to Others: 20
Karma Power: 84
Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.
Default
If you are using OEE to establish throughput, you are making it more difficult to identify bottle necks by lumping all equipment together.
What I have found to be very beneficial in the past has been to do a Value Stream Map before applying the OEE calculations. It identifies restraints and then you can put actual numbers on how the restraints are detrimental to the process.
"What this country needs is more unemployed politicians." Edward Langley
Old 24th June 2005, 11:12 AM
Involved - Posts
Karma Power: 39
Default
Thanks everyone for the response.
Randy,
What does value stream map mean? Kindly explain.
Old 23rd August 2005, 07:12 AM
Howard Atkins's Avatar
Howard Atkins Howard Atkins is offline
Forum Administrator
Registration Date: Jul 1997
Thanks Given to Others: 100
Karma Power: 195
Howard Atkins is appreciated, and has over 1700 Karma points.
Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.Howard Atkins is appreciated, and has over 1700 Karma points.
Send a message via Skype™ to Howard Atkins
Default
For some reason there was no reply-
Try the folowing threads
Have any of you heard of a Value Stream Mapping
VSM (Value Stream Mapping) - Use constraints or leave 'wide open'?
You can’t fake quality any more than you can fake a good meal.
* William S. Burroughs
Old 23rd August 2005, 07:23 AM
Marc's Avatar
Karma Power: 605
I Say...
Howard - Thanks for noticing and helping out!
Also see: OEE - Overall Equipment Effectiveness - Initials and Definition
Old 23rd August 2005, 08:04 AM
wmarhel wmarhel is offline
Courtesy Access
Registration Date: Oct 2004
Thanks Given to Others: 109
Karma Power: 94
wmarhel is appreciated, and has over 1700 Karma points.
Default Worksheet
Here's another worksheet. Just enter the data in the yellow fields.
Wayne
Thanks to wmarhel for your informative Post and/or Attachment!
Reply
Bookmarks
Tags
overall equipment efficiency (oee)
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
OEE (Overall Equipment Effectiveness) Downtimes Calculation michu Manufacturing and Related Processes 8 18th May 2008 01:07 AM
OEE definition - Overall Equipment Effectiveness - Definition of A (Availability) DavidB Definitions, Acronyms, Abbreviations and Interpretations 5 10th December 2005 03:41 AM
OEE (Overall Equipment Effectiveness) and Run at Rate Hollerith ISO/TS 16949 - International Automotive Quality Systems Standard 5 6th February 2004 02:37 AM
OEE - Overall Equipment Effectiveness Andrews QS-9000 - American Automotive Manufacturers Standard 1 20th August 2003 10:41 AM
OEE - Overall Equipment Effectiveness - A Ford Requirement a-rostami Customer and Company Specific Requirements 7 18th October 2002 11:37 AM
The time now is 04:51 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
