Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 19011 and ALL Auditing Discussions > Process Audits and Layered Process Audits
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 23rd June 2005, 05:21 PM
dbzman's Avatar
dbzman dbzman is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 1
Karma Power: 37
dbzman has less than 100 Karma points so far.
Question Layered Process Audits? Are they required by TS16949?
I wanted to ask the members of the best forum on the web about this one.
We had the corporate audit team in our facility this week and they told me something that I had not heard before. They said that 8.2.2 (specifically 8.2.2.1, 8.2.2.2, 8.2.2.3,) is calling for layered audits.
Is this true?
Opinions?
James M. Warner
"Workaholic"
Sponsored Links
Old 23rd June 2005, 05:29 PM
jmp4429 jmp4429 is offline
Involved in Discussions
Registration Date: Mar 2005
Karma Power: 39
jmp4429 is appreciated, and has over 700 Karma points.jmp4429 is appreciated, and has over 700 Karma points.jmp4429 is appreciated, and has over 700 Karma points.jmp4429 is appreciated, and has over 700 Karma points.jmp4429 is appreciated, and has over 700 Karma points.jmp4429 is appreciated, and has over 700 Karma points.jmp4429 is appreciated, and has over 700 Karma points.
Default
Suckup!
Is this true?
Opinions?
Well, 8.2.2.1 calls for auditing the QMS, 8.2.2.2 calls for manufacturing process audits, and 8.2.2.3 calls for product audits. Isn't that pretty much what layered auditing means?
Sponsored Links
Old 23rd June 2005, 06:02 PM
dbzman's Avatar
Courtesy Access
Karma Power: 37
Default Clarification
I was remiss when I tried to explain what they told me.
They siad that I would have to have different layers of the organization audit.
That the GM should audit,
That the Production Manager should audit.
That the employees in the different layers of the organization HAVE to audit their own layer.
While this is a good idea is it a requirement?
James M. Warner
"Workaholic"
Old 24th June 2005, 11:06 AM
Karma Power: 39
Default
I don't want to say "no" and be wrong about it. But I don't see in the standard where it says anything of the sort. Also, my company does not do this and nobody's taken away our certificate yet.
Maybe someone else could shed more light on it.
Old 24th June 2005, 11:19 AM
db's Avatar
db db is offline
Where's the shall?
Registration Date: Jul 2001
Thanks Given to Others: 208
Karma Power: 129
db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.
Default
The Layered Audit is not required by TS, however it is a CSR (Customer Specific Requirement) for various organizations. You need to look at your customer specifics to determine you are required.
Dave B (the other Dave)
Old 24th June 2005, 12:11 PM
dbzman's Avatar
Courtesy Access
Karma Power: 37
Default 2nd 3rd tier
We are 2nd or 3rd tier automotive. Our customers are the ones that deal directly with Ford, GM, etc.
The only requirement that we have had so far is to be TS 16949.
To me, our corporate people are asking for something (although it's a good thing to do) that is not required under TS.
Thanks for the input!
James M. Warner
"Workaholic"
Old 2nd July 2005, 05:13 AM
anandqgp anandqgp is offline
Involvement Access - Posts
Registration Date: Jul 2005
Karma Power: 18
anandqgp has less than 100 Karma points so far.
Let Me Help You layered audits
Dear dbzman
I think If I am right, layered audit refers to auditing the same process by different persons occupying positions in the different layers in management. One layer could be Marketing, the others could New Product Development, HRD and so on. Idea is to getting view of the same process from different angles.
Collecting data from different layers, the same needs be analysed and work out a way for improvement.
While the line you have mentioned about clauses 8.2.1, 8.2.2 etc serve the different process i.e., one is auditing the QMS, second is auditing the Product and third is auditing the Process. Hence, you see that there is nothing like layer sort of thing. All are auditing different perceptions in an organisation.
Please revert back if you feel differently
HS Anand
Old 2nd July 2005, 11:11 AM
Warranty_Guy Warranty_Guy is offline
Registered Visitor
Registration Date: Jun 2005
Karma Power: 19
Warranty_Guy has less than 100 Karma points so far.
Read This! Layered Audits
We had the same conversation in our organization and opted to not implement Layered audit and the Auditor was fine. In the case of a CSR DCX does require it for there PSO 5, Gm only requires it if you have QSB implemented. Ford does not have a requirement on this.
We have implemented QSB and with that Layered Audits.
Therefore it is not a required element in the TS.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Layered Process Audits - What are Layered Process Audits? andrewg Definitions, Acronyms, Abbreviations and Interpretations 12 1st October 2008 06:42 PM
The Difference between Process Audits and Layered Audits Mumus ISO 19011 and ALL Auditing Discussions 3 14th September 2007 10:55 AM
Layered Audits - Where to tie the layered audit process back to FMEA & Control Plan Ragnar FMEA and Control Plans 10 6th August 2007 11:44 AM
Layered Process Audits vs. Internal System Audits jkittle Process Audits and Layered Process Audits 17 9th March 2007 07:43 AM
Internal Process Auditing - Auditor Unhappy - Wants Layered Process Audits jkittle Process Audits and Layered Process Audits 13 11th November 2006 09:31 AM
The time now is 03:32 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
