Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Manufacturing and Related Processes
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
Old 30th June 2005, 08:09 AM
p1stonbroke's Avatar
p1stonbroke p1stonbroke is offline
Registration Date: Nov 2004
Karma Power: 21
p1stonbroke has less than 100 Karma points so far.
Please Help! Thread Quality in Aluminium - Problems with the threads stripping out
Hi, I have a heat sink plate that is attached to a PWB using 6 x M2.5 x 6 screws. We are having problems with the threads stripping out, despite using considerably less force than might normally be expected (0.4 NM), inspection of the holes prior to thread insertion shows some variance, on one hole the threads might be fairly well defined (clear rigdes and troughs) whereas on another, they might be more rounded.
I am looking for a suggestion on how to determine what is actually acceptable and what is not. My company does not have spare funds to buy expensive visual measuring equipment, nor do we have the facilities to microsection to measure - I'd like a method that can be used by our goods inwards guys to say 'No' or 'Go' to each batch of heatsink plates as they come in.
Any suggestions?
Pistonbroke
Quality and Security
Sponsored Links
Old 30th June 2005, 10:05 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is online now
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Default
Any suggestions?
Under what conditions are the threads stripping? Are you sure that assemblers aren't cross-threading the holes? This is a common problem with threads in soft materials. You have to try and isolate the problem in order to find a solution. Here are some questions that might help lead you in the right direction:
  • How are you inspecting the holes now? If you're using thread plug gages, try to find out if the thread condition you've visually identified is detectable with a thread gage (i.e., those with visually questionable threads might be looser or tighter on the gage). Mark some parts and see if they strip in production.
  • Can the problems be associated with a single operator? I used to work in a job where teflon fittings with pipe threads were used. The fittings weren't cheap, and we kept getting rejections from the line with the cause being "bad threads." It turned out that one assembler was too aggressive in installing the fittings and kept cross-threading them, which was very easy to do with the soft material.
  • Is thread class specified on your drawing? If the drawing just says M2.5x6, the tolerance class defaults to "medium" for metric threads. Have a look here for more information: Tolerancing of Screw Threads
  • Unless something simple presents itself, you might have to do some cutting (sectioning of parts in order to measure the threads directly). I know you say you don't have the facilities to do it, but that just means that you might have to send some parts out to be measured. If there's a disagreement with the supplier, it's to your advantage to have ammunition from an independent source.
  • Have you discussed this with the supplier? Is he aware of the problem?
Sponsored Links
Old 30th June 2005, 01:30 PM
Bill Ryan's Avatar
Bill Ryan Bill Ryan is offline
Dogs rule
Registration Date: Jul 2002
Thanks Given to Others: 15
Karma Power: 69
Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.
Default
Welcome to the posting side of the Cove
In addition to JSW's questions:
  • Are the heat sinks a die casting?
  • If so, how many cavities are cast in the mold?
  • Also if so - Are the holes formed by a core in the mold or are they machined?
  • Are these self tapping screws?
There is no psychiatrist in the world like a puppy licking your face. - Ben Williams
Old 30th June 2005, 08:18 PM
Wes Bucey's Avatar
Wes Bucey Wes Bucey is offline
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 182
Karma Power: 397
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Default
Bill asks pertinent questions, as does JSW.
When you say
Any suggestions?
I have a few comments. Even something as simple and inexpensive as a jeweler's loupe with the proper light source will tell you almost everything YOU need to know about the female thread.
Depending on how the female threads are formed, you have several options.
If the alloy is too soft and the female threads easily deform from the screws, change to a harder alloy (hardly any difference in heat sink value.)
Are you sure the screws are consistent? sometimes the manufacturing process for screws can produce an out-of-round condition that turns the screw into a thread cutter. Not likely, but it is a remote possibility.
Do installers REALLY know how to install screws without stripping? (this is an insulting question, but must be asked.)
When you mention budget, you may not be aware many low tech, low cost intruments and tools for checking threads exist. Usually, the situation you describe does not need machine sectioning of the female threads to examine the thread condition. Accurate, inexpensive go/no go male thread gages are available which can be used in incoming inspection to confirm the female threads meet specs. This should be done by the supplier already. Do you get his inspection sheets?
Have you bothered to ask the supplier of the female threads to help you track the problem cause? Often this is the fastest and least expensive solution.
Old 30th July 2005, 02:50 PM
RWest RWest is offline
Registration Date: Jul 2005
Karma Power: 18
RWest has less than 100 Karma points so far.
Default Minor thing can be a big deal...
The only thing I think that wasn't mentioned is the minor diameter. You must determine the proper minor diameter and check (using a gage pin) that it is within spec. for the thread in question. The thread can pass with the plug go/not go gage and still have OOT minor diameter. The plug gage only checks the pitch diameter which is measured across the actual thread angle. I could go on but I think this is the most likley culpret barring the other things already mentioned.
Cheers,
R West
Old 4th April 2008, 04:05 PM
MysterHK's Avatar
MysterHK MysterHK is offline
The Think Tank
Registration Date: Mar 2008
Thanks Given to Others: 152
Karma Power: 8
MysterHK has less than 100 Karma points so far.
Send a message via AIM to MysterHK Send a message via Yahoo to MysterHK
Default Re: Thread Quality in Aluminium - Problems with the threads stripping out
Any suggestions?
p1stonbroke:
I am just throwing out an idea, but I was wondering if that aluminum part could be made with pressure-applied, self-clinching fasteners instead of threaded holes?
There's another idea I remembered back from my Navy days. Stripped holes would be tapped out and helicoils would be inserted. I don't know if there is a manufacturing equivalent to do this efficiently.
Si quisquam can facile sumo is, is eram nunquam mei ut suscipio per.
Last edited by MysterHK; 4th April 2008 at 04:17 PM. Reason: adding another option, rephrase
Old 4th April 2008, 04:22 PM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 1,316
Karma Power: 377
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Any suggestions?
Originally Posted by MysterHK View Post
p1stonbroke:
There's another idea I remembered back from my Navy days. Stripped holes would be tapped out and helicoils would be inserted. I don't know if there is a manufacturing equivalent to do this in large quantities.
You are responding to an old post (30th June 2005, 07:09 AM) and I wonder if the Original Poster (OP) is still around...
However, for our Fellow Covers who are still interested in this issue, I found these...
Stijloor.
Thanks to Stijloor for your informative Post and/or Attachment!
Old 4th April 2008, 04:47 PM
MysterHK's Avatar
The Think Tank
Karma Power: 8
That is an awesome product, Stiljoor! Truly amazing!
I'm definitely going show this to my production manager tonight and maybe he can bring this up at the next engineering meeting.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Discussion Threads - 'Subscribing' to a THREAD so you will be notified of New Posts Marc Instructions --> How to use the Forum Software 3 3rd February 2008 07:15 AM
Weld Nut Thread Quality - Thread chaser for a M8-1.25 internal thread? larry hopperrath Manufacturing and Related Processes 3 3rd November 2005 05:32 PM
MJ vs. M Thread Designation - All About Fastener Threads bobhall ISO 17025 - Calibration, Measurement Gages and Test Laboratories 6 5th May 2003 01:12 PM
The time now is 12:59 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
