Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 4th July 2005, 01:27 AM
hobbyxin hobbyxin is offline
Registered Visitor
Registration Date: Jul 2005
Karma Power: 18
hobbyxin has less than 100 Karma points so far.
Send a message via MSN to hobbyxin
Please Help! Spc Question - When the Cpk value is bigger than 2.0
Dear experts:
I have a question in implementing the process spc , When the Cpk value is biger than 2.0 , did the point must in control area? I have a sample that the Cpk is 2.26, but the Xbar chart has a appearance of noncotorl , why?
Sponsored Links
Old 4th July 2005, 02:17 AM
jperez25 jperez25 is offline
Getting Involved (6 to 9 Posts)
Registration Date: Mar 2005
Karma Power: 20
jperez25 has less than 100 Karma points so far.
Default
Hi! I take it that you calculated the Cpk and control limits after more than 25 subgroups and all of a sudden one day you took another sample, calculated Xbar and R, and the R value is out of the control limits.
If that's the case, then it simply means that the process where you took the sample from is different than the the one you always had (a.k.a. out of statistical control or special cause of variation)
You can have a very high Cpk value, but whenever a special cause of variation happens, your process will be different than the one you always had, and then the statistics will fall beyond the control limits.
cheers
Sponsored Links
Old 4th July 2005, 11:00 AM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
It is also important to remember the difference between control limits and specification limits. Cpk measures how well you meet customer requirements. If the customer has given fairly broad specs, then even a process that is out of control (with points falling outside the control limits) could give a good Cpk (points are all far from the spec limits). On the other hand, if the customer had fairly tight specs, then a process that is perfectly well in control could have a poor Cpk.
For example, suppose the specs say 100 +/- 5 and you are producing parts with X-bar-bar =100.5 and sigma = 0.5. Furthermore, the control chart shows you are in control. The CpK would be a respectable (105-100.5)/1.5 = 3. The control limits of the X-bar chart would be 100.5 +/- 1.5.
Now, suppose you get some new raw materials and you start getting X-bar-bar =99.5 and sigma = 0.5. You are still well within the spec limits of 100 +/- 5, but the control chart will quickly show points out of control.
Tim F
Old 6th July 2005, 12:16 AM
Registered Visitor
Karma Power: 18
Default
First , thanks a lot for your quickly reply . I like this site.
Attached is a sample , you could check , hope this is useful for you .
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Old 6th July 2005, 07:25 PM
Darius's Avatar
Darius Darius is offline
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.
Default
First, your process is out of control, the behabiur of the data look like is a continuos process (there is too much autocorrelation between data) so the control limits look smaller than they must be, the points 15 tru 18 look trully out of control (taken the difference between 2 consecutive data on the chart as a pattern) .
There are 2 ways to include autocorrelation to your data, one is more time between samples (making the sample bigger or more time between the elements of the sample) and the other is with an autocorrelation index, the question may be if the data must be in 6 elements samples?, if is a continuos process the best chart can be IX-MR.
Agree with Tim about capability (specification limits) and control charts, they are 2 different things. (even not talking about one specs ) , the problem with the calculation of an index in a out of control variable is that you don't know with value can be obtained next (is a wheel of the fortune).
Vits er thorf, theim vitha ratar; daelt er heima hvat; at augabragthi verthr, sá er ekki kann ok med snotrom sitr.
Old 6th July 2005, 09:54 PM
Karma Power: 20
Default
I am a bit doubtful about your measuring system (it may be just the excel file), but it looks like the minimum unit you can read from it is just 1/8th of the specification bandwith (USL-LSL: 17-9)... that may be another thing to look into.
Javier
Old 6th July 2005, 10:47 PM
Arvind Arvind is offline
E-Mails Invalid or Rejected
Registration Date: Oct 2004
Karma Power: 0
Arvind has less than 100 Karma points so far.
Default Capability concept is applicable on if process is in control
Purpose of capability is to predict future state of the process. If for some reason, your process control chart is showing out of control condition, which indicates presence of special cause, it does not make sense to talk of capability.
Always use capability index only when process variation is under common cause.
Old 8th July 2005, 12:17 AM
Registered Visitor
Karma Power: 18
Quid Pro Quo
Javier
May the measuring be the probable cause for this uncommon , on the other hand , the process out of control may be the another cause . We studied this further and found the GAP (key character)has a unstability variance due to the machine's shaking in process .
Thanks a lot for your directing.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Cp Cpk Pp and Ppk Definitions - I'm doing SPC and Capability Analysis Leigh Definitions, Acronyms, Abbreviations and Interpretations 7 11th June 2009 01:16 PM
Questions on use of SPC, Ppk, Cpk during PPAP narakorn Capability, Accuracy and Stability - Process, Machine, etc. 10 27th February 2009 06:32 PM
SPC Reaction Plans for Cpk of <1.33 during mass production timference SPC Monitoring and Statistical Analysis Techniques 15 19th December 2008 01:04 PM
A question about Cpk and Cmk - Can we use Cpk to replace Cmk? sunwen Capability, Accuracy and Stability - Process, Machine, etc. 1 11th April 2007 08:45 AM
Calculating Cpk/Ppk Simultaneously in SPC software statman78 Capability, Accuracy and Stability - Process, Machine, etc. 6 12th January 2006 01:45 PM
The time now is 01:29 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
