Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Six Sigma
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 7th July 2005, 12:33 PM
jackylpt's Avatar
jackylpt jackylpt is offline
Involved - Posts
Registration Date: Aug 2004
Karma Power: 22
jackylpt has less than 100 Karma points so far.
Let Me Help You How to calculate the sigma level of a process - Which one is right
I am confuse the how to calculate the sgima level of process, please tell me below which one is right and which is wrong clearly.
We have 1,000,000 productions, find defect is 8,000. defect opportunity is 1.
Then case 1
DPMO is 8,000 according to the ASQ six sigmal primer appendix, the sigmal level is 2.9 sigma(with 1.5 shift)
case2
DPU is 0.008 DPMO=0.008
Y= RTY= e-DPU=0.992
Probablity of defect is P(d)=1-Y = 1-0.992=0.008
then use Z value table is 2.41
and add 1.5 shift, then the sigma level is 2.41+1.5=3.9 sigmal
Case3.
using formula sigmal level= 0.8406+ SQRT(29.37-(2.221*ln(PPM)))
then 0.846+SQRT(29.37-(2.221*ln8000))=3.9 sigmal
question 1:
the resuult of case 2 and 3 are different with case1 which one is right?
question2:
if we want to know the cpk of this process, is 8,000/1,000,000=0.8% just P value(because it is attribute data), that is right?
thanks
Michael
Sponsored Links
Old 7th July 2005, 01:29 PM
cyberspider's Avatar
cyberspider cyberspider is offline
Involved - Posts
Registration Date: Jun 2005
Thanks Given to Others: 10
Karma Power: 18
cyberspider has less than 100 Karma points so far.
Default Good to have doubt.....It's a way to gain knowledge
I have been using the Case-2 i.e. taking help of Z table - a De Facto standard.
Thanks,,
Sponsored Links
Old 7th July 2005, 06:26 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
There is an online calculator at
http://www.isixsigma.com/sixsigma/si...asp?m=advanced
It agrees with the second two calculations (i.e. 3.9 sigma). I have to assume the table you used in Case 1 is wrong. Perhaps it was for a shift of 0.5 instead of 1.5. Perhaps it was simply mis-typed.
Tim F
Old 24th July 2005, 06:26 PM
Arvind Arvind is offline
E-Mails Invalid or Rejected
Registration Date: Oct 2004
Karma Power: 0
Arvind has less than 100 Karma points so far.
Default Six sigma always refers to short term capability
Due to higher sources of variation, long term capability is alway lower than short term capability.
Six sigma always refers to short term capability. A factor of 1.5 sigma is applied to account for common cause meanshift which can happen both in favorable or unfavorable directions.
Six sigma capability in Short term is expected to reduce upto 6-1.5= 4.5 sigma in Long term. When you divide sigma by 3, you get capability. This means that short term six sigma or capability of 2.0 is expected to reduce to 4.5 sigma or capability of 1.50.
In your case, if you are interested in short term, sigma value is 3.9 which can reduce to 2.4 in long term.
Hope this clarifies.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Confusion DPU, PPM & DPMO vs. Sigma Level - ASQ Six Sigma Black Belt hand book Stephane Dubreuil Six Sigma 8 19th June 2009 01:57 PM
Sigma Level and Capability - What are Ppu, Ppl, Sigma Level, Sigma Capability fed-up Capability, Accuracy and Stability - Process, Machine, etc. 6 6th May 2009 08:24 AM
How to correctly calculate sigma level for production processes Przemek Six Sigma 2 24th April 2009 07:23 PM
How to calculate the sigma level of a process and Relationship of DPMO jackylpt Six Sigma 7 1st August 2008 06:27 PM
How do I calculate sigma for attribute data of process - Coating spoliation jackylpt Six Sigma 5 25th October 2005 06:26 AM
The time now is 03:49 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
