9th July 2005, 11:40 PM
Involved - Posts
Registration Date: Aug 2004
Karma Power: 22 Karma: 10
Help with Mintab concepts:
Expected "overall" performance vs. Observed performance
In mintab, I confued some concepts, want to get help
Expected "overall" performance: The expected "overall" performance values quantitatively represent the actual process performance. The expected values are calculated using the overall sample variance.
Observed performance: The observed performance section tells you the actual number of parts per million located beyond the specification limits.
what is difference between these two things? I think both of them are actual value which was found of out of specification? thanks
11th July 2005, 02:30 PM
Registration Date: Jan 2004
Thanks Given to Others: 964
Karma Power: 360
Does anyone have advice for Jacky?
Stealth quality versus no quality
11th July 2005, 02:49 PM
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 612
See if this document from Minitab helps.
11th July 2005, 04:53 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
I started two threads in our new 'Definitions and Acronyms' forum. Hopefully we'll get some feedback there as well. See: Performance - Expected "overall" performance - From Minitab
12th July 2005, 02:10 AM
Involved - Posts
Hi JSQ05 and Marc,
Thank you so much. I do appreciate that.
Michael
12th July 2005, 03:19 PM
Registration Date: Sep 2002
Karma Power: 31 Karma: 71
"Observed perfromance is based on the actual results used for the analysis.
"Expected performance statistics are predictions of the proportions that will fail the specification limits in the long term. They are based on the normal statistical model (if that is the distribution you selected) rather than the actual data.
"Two different sets of are produced, one based on the short term performance (within) and one on the long term (overall)."
This per the book Six Sigma and Minitab by QSB Consulting.
