Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - Calibration, Measurement Gages and Test Laboratories > Measurement Uncertainty (MU)
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 19th July 2005, 07:01 PM
luluthecat luluthecat is offline
Shy Poster (1 to 5 Posts)
Registration Date: Jun 2005
Karma Power: 18
luluthecat has less than 100 Karma points so far.
Please Help! % Uncertainty Budgets - Auditor wants to see my uncertainty budget represented as a %
Hi everyone,
I have an assesor (for 17025 accreditation) coming out and he wants to see my uncertainty budget represented as percentages.
Does anyone have an idea how I would convert this into a percentage?
All my contacts at other cal labs have never heard of this.
The assesor said that my calculations are correct, but he wants to see them as percentages. Does ISO even require the budget to be represented as percentages?
Any suggestions would be very much appreciated!
Sponsored Links
Old 19th July 2005, 10:18 PM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Registration Date: Mar 2004
Thanks Given to Others: 1
Karma Power: 186
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Default
Without knowing the parameter(s), it is difficult to say whether your scope is typically expressed in percentages.
Some scopes have parameters that are in fact typically expressed in percentages. As an example, force-compression can and often is expressed as a percentage, but can also have specific numbers for the uncertainty.
Hope this helps a bit.
Hershal
Sponsored Links
Old 20th July 2005, 04:51 AM
W. de Jong's Avatar
W. de Jong W. de Jong is offline
Getting Involved (6 to 9 Posts)
Karma Power: 19
W. de Jong has less than 100 Karma points so far.
Default % uncertainty budget
Your assesor may be asking this for his own convenience. We use the document EA-4/02 "expression of uncertainty..~" and it says in 4.9 that table 4.1 is an example. This table contains a contribution to the standard uncertainty but is absolute. For your own convenience you might want to convert that into relative percentages to instantly get an insight on the biggest contributor. But not just to please your assesor.
Btw this might be different for non-european countries, maybe find a equivalent to such a document. But i'm quite sure the ISO17025 says nothing about percentages.
Hope this may be of any help.
BR.
EA-4/02 [270 Kb]: http://www.european-accreditation.or...-4-02rev01.pdf
Old 20th July 2005, 09:55 AM
JerryStem's Avatar
JerryStem JerryStem is offline
Involved - Posts
Registration Date: Apr 2001
Karma Power: 41
JerryStem has less than 100 Karma points so far.
Default
ISO doesn't require it to be expressed in any certain form, to my knowledge. It depends on what you're measuring and how typically it can be expressed.
I hapen to have mine expressed as a percentage for convenience. I don't need a very detailed, minute uncertainty budget. Most of our customers have never heard of MU and the ones that have only need it because QS9K says they do.
I express my MU as a % of the marked value of the thickness standard for coating/plating thickness measurement instruments. I factor in the master standard's tolerance (+/-5%), working std (same), and a few small variables.
I get a fairly large % (8.8%) but it makes sense, A2LA is FINALLY happy (even had a special 1.5 day free visit from an assessor to check us out). and our customers still don't care.
Jerry
Old 20th July 2005, 02:43 PM
Hershal's Avatar
Metrologist-Auditor
Karma Power: 186
Default
The best advice for scopes is to obtain the ILAC document , available at no cost on the ILAC website. It does not specify percent or number, but does give good guidance on scopes.
http://www.ilac.org
Hershal
Old 20th July 2005, 07:19 PM
Karma Power: 18
Default
Thank you everyone for all your help!
I just think I might make it through this A2LA audit!!!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Uncertainty Budget - Gage Blocks Daniel Walker Measurement Uncertainty (MU) 7 12th June 2008 11:33 AM
ISO 17025 MU Requirements - Construction Material Testing Lab Uncertainty Budgets Backscatter Measurement Uncertainty (MU) 9 27th October 2007 02:47 PM
Measurement Uncertainty (MU) Budget for a 0-1 inch Micrometer rich.dittmanjr Measurement Uncertainty (MU) 3 10th May 2005 08:23 AM
Mercury in Glass Thermometer Uncertainty Budget Silverhill Measurement Uncertainty (MU) 1 11th November 2004 05:11 PM
The time now is 11:52 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
