Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 23rd July 2005, 12:04 PM
akiton akiton is offline
Involved in Discussions
Registration Date: Jan 2003
Karma Power: 28
akiton has less than 100 Karma points so far.
Let Me Help You What is the formula I need to calculate Pp and Ppk?
Due to this our customer requesting us to come up with Pp, Ppk figures.
With the data given below can anyone help to figure out the pp,ppk value?
Spec: 107 ± 3 microns
Code:
Sample               1      2      3      4     5      6
1) Part A    -      108    107    105    108    106    106
2) Part B    -      106    107    105    105    104    106
I need to know the formula (not with those code) but the numerical formula using the example above so that in future I can calculate myself.
Please advice. Thanks
Sponsored Links
Old 23rd July 2005, 01:36 PM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Courtesy Access
Registration Date: Jan 2005
Thanks Given to Others: 755
Karma Power: 611
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Default
Have a look here: http://www.isixsigma.com/library/content/c010806a.asp
Sponsored Links
Old 23rd July 2005, 11:17 PM
Karma Power: 28
Default
I've gone thru that site already and it doesn't have any numerical example shown there.
Anyone here please use the example posted to show me the formula. Thanks.
Old 23rd July 2005, 11:33 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
Attached is the results of a Minitab analysis of the data - numbers & graphs pasted into a word document. Hopefully that points you in the right direction. If you have questions about specific numbers, I should be able to provide a little guidance.
Tim F
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Old 23rd July 2005, 11:39 PM
Karma Power: 28
Default
Tim F
Thanks for your reply. I need to know the numerical formula to get the result.
Old 24th July 2005, 06:08 PM
Arvind Arvind is offline
E-Mails Invalid or Rejected
Registration Date: Oct 2004
Karma Power: 0
Arvind has less than 100 Karma points so far.
Default Capability calculations need 30 to 100 samples for acceptable confidence band
You can calculate capability using a scientific calculator.
1) Find mean and standard deviation from the data.
2) Multiply std dev by 6.
3) In your case, tolerance band is +/- 3 or total 6
4) Divide 3) by 2) to get Pp
5) Find smaller of the two absolute values (UCL-Mean) and (LCL-Mean). Use only smaller value.
6) Multiply std dev by 3
7) Ratio of 5) by 6) will give Ppk.
Confidence band using such low sample size is unacceptably wide therefore your calculated values may not mean anything useful in real life. Even with 30 samples, capabilities have tolerance value of +/- 25 %.
Old 24th July 2005, 06:30 PM
Marc's Avatar
Marc Marc is online now
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,892
Karma Power: 604
Default
Also see these related Cove threads:
Ppk vs Cpk - Good, clear explanation
Cpk vs. Ppk - Long Term vs. Short Term - Capability vs. Stability
Cp/Cpk vs Pp/Ppk (Short term using population sigma) - Formulas to use?
Some Process Capability visuals
Old 22nd March 2009, 04:19 PM
bobdoering's Avatar
bobdoering bobdoering is offline
Stop X-bar/R Madness
Registration Date: May 2002
Thanks Given to Others: 680
Karma Power: 150
bobdoering is appreciated, and has over 1700 Karma points.
bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.bobdoering is appreciated, and has over 1700 Karma points.
Send a message via Yahoo to bobdoering
Default Re: What is the formula I need to calculate Pp and Ppk?
Code:
Sample               1      2      3      4     5      6
There is not enough information here to calculate Pp or Ppk. What is the process. and what does the data represent? The capability analyses that have been provided from dumping this data into a number cruncher may only indicate that the variation you see is from measurement error and perhaps gage error (since a six micron tolerance should be measured with something with a resolution of 600 nanometers at a minimum - and more likely 100 nanometers - not 1 micron resolution), which tends to be normal, and tends to nicely mask the actual process variation. If this was a part from precision machining (the 6 micron tolerance makes me suspicious that it might be), and you both controlled and measured the part correctly, then the capability is (USL-LSL)/UCL-LCL) - not any of the citations listed previously.
See Statistical process control for precision machining for more information, if it applies.
Reply
Bookmarks
Tags
formula, ppk
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Cpk vs Ppk - Which should you use and How to Calculate Cpk and Ppk Nitin Sharma SPC Monitoring and Statistical Analysis Techniques 25 13th October 2008 07:44 PM
Destructive Gage R&R Spreadsheet - Old MSA formula (5.15s) vs New formula (6s) yepezyepez Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3 11th March 2008 01:59 PM
Excel formula for Ppk needed Aitch Excel .xls Spreadsheet Templates and Tools 44 1st July 2006 06:12 AM
Ppk sampling method - Does data for Ppk have to been continuous? darkafar Capability, Accuracy and Stability - Process, Machine, etc. 1 19th June 2006 09:03 AM
Ppk formula - Can some one please help me - I have attached the sheet. amna77 Capability, Accuracy and Stability - Process, Machine, etc. 9 15th March 2006 01:21 AM
The time now is 03:20 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
