Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Excel .xls Spreadsheet Templates and Tools
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 28th July 2005, 12:14 PM
Indul Indul is offline
Registration Date: Jul 2005
Karma Power: 18
Indul has less than 100 Karma points so far.
Let Me Help You How to add a vertical reference line in my excel .xls bar graph
I want to add a vertical reference line in my excel bar graph. does anyone know how to do that. I am attaching the excel graph.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
File Type: xls histogram data for vertical reference line.xls (331.0 KB, 198 views)
Sponsored Links
Old 28th July 2005, 12:18 PM
qualeety's Avatar
qualeety qualeety is offline
Involved - Posts
Registration Date: Feb 2005
Thanks Given to Others: 8
Karma Power: 27
qualeety is appreciated, and has over 200 Karma points.qualeety is appreciated, and has over 200 Karma points.qualeety is appreciated, and has over 200 Karma points.
Send a message via MSN to qualeety
Default how to add a line in the excel graph
the easiest way is to add a line is to click the following:
INSERT -> PICTURE -> AUTOSHAPES -> LINE
click on the line icon and draw a line on the graph.
Hope that helps.
Sponsored Links
Old 28th July 2005, 01:21 PM
Tim Folkerts's Avatar
Tim Folkerts Tim Folkerts is offline
Registration Date: Sep 2003
Thanks Given to Others: 27
Karma Power: 123
Tim Folkerts is appreciated, and has over 1700 Karma points.
Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.Tim Folkerts is appreciated, and has over 1700 Karma points.
Default
If you want Excel to actually put a vertical line at a specific location on the graph (e.g. 3.2 kg) for you, then you may have to redo the graph a bit.
Bar graphs don't treat the x-axis as actual numbers, so you can't tell it to plot someting extra at a specific value. If you change to an X-Y (scatter) plot, then there are ways to add extra lines using an extra data series. However, then you get individual points for the date, rather than the more distinct bars.
A couple other quick comments.
* A lognormal fit seems a bit closer to the data you have: a sharp tail at the lower end and a broad tail at the upper end.
* You clearly have two peaks in the data - one near 1.5 and one near 3.0. You might try fitting two normal curves (or two lognormal curves) to better match what is actually happening.
* I think there may be a minor error in the equation you used to draw the fit line. I could describe it here - or in a private message if you prefer.
Tim F
Old 29th July 2005, 05:22 AM
Barbara B's Avatar
Barbara B Barbara B is offline
Involved - Posts
Registration Date: May 2005
Karma Power: 19
Barbara B has less than 100 Karma points so far.
Default
Additionally to Tim's subsequent posting: I suggest three peaks in your values, one at 1.16, one at 1.43 and one at 2.89. Your values couldn't be approximated with a normal curve (see attached pics).
Before fitting any curve, you could think about differences in the data. Maybe your data comes out of three different samples or were produced with different machines or something like that.
That's not what you've asked , but perhaps it will be helpful.
Barbara
Old 29th July 2005, 03:08 PM
Karma Power: 123
Default
Like Barbara, I tried to create a fit to the curve (I used Excel). I didn't try 3 peaks, mostly because the scatter in the data seemed large enough to swamp the need for a third peak. And fitting one more peak would make the process more difficult to do semi-manually!
Even with just two peak, you can get a pretty good fit. The curve is in the attached file.
Tim F
Old 29th July 2005, 03:34 PM
Barbara B's Avatar
Involved - Posts
Karma Power: 19
Exclamation
Tim,
of course it is easier to approximate the values with two curves, but it could mask sometimes the underlying special causes which leads to the three peaks.
So my suggestion is to look for those special causes first and then try to approximate the values with an appropriate number of curves.
If the data is not normally distributed, the use of xbar-R-charts is not a good tool to track the process output (directly without any transformation).
Regards,
Barbara
Old 29th July 2005, 04:42 PM
Karma Power: 123
Default
Barbara,
Interesting! It is sort of like the chicken and the egg question. Which should come first - the theory that predicts the behavior of the curves, or the analysis of actual data without any preconceived notions of what to expect. Both are viable approaches.
In this case, since I had no a priori reason to believe that there are 3 peaks, I settled for two. And just by eye it gave a pretty good fit. (Actually I used a least-squares approach to get the best fit). Looking at the residuals might give a good idea whether 2 peaks is enough.
At this point, though, if Indul doesn't come back and give some feedback, I think I'll mostly let this thread hibernate. We are probably giving him more than he wanted!
Tim F
Old 30th July 2005, 08:38 AM
Barbara B's Avatar
Involved - Posts
Karma Power: 19
Listen To Me!
Tim,
poor Indul He ask a simple excel question and we start to discuss about curve approximations... Sorry for hijacking your thread Indul, perhaps you'll although find some useful hints in our postings.
For me the decision between two or more curves is not an chicken/egg-thing. From Indul's spreadsheet you could see, that his intention is to draw a Xbar-R-chart. For this charts the assumption of normally distributed data had to be true to get valid results.
So if you're trying to track a process with Xbar-R-charts (or any other tools with the assumption of normality), you have to check this assumption first. Indul's values are not normally distributed, so what could he do?
1. He could use a transformtion of the data or the distribution (lognormal or something like that), but there are no hard rules to get the "right" solution here out of the data without additional informations. Maybe he'll get something normally distributed at the end, but he'll throw away a lot of valuable information.
2. He could use two curves to get a good fit of the data. But what does that mean for his process? How could he decide whether a new value like 2.2 belongs to the first or second distribution without informations about the cause for the two distributions?
3. He could use sample-subgroups. If the expected mean and variance of the process are stable, he'll get normally distributed values (Central Limit Theorem). But he had no information about the causes for the peaks in the original data.
4. He could go back to the process and search the cause(s) for the peaks (different materials, machines, suppliers,...) And then he could split the data into useful subgroups with (approximate) normally distributed data and draw Xbar-R-charts (e. g. one for each supplier).
Taking that way he has used the whole information of the data and is able to make stable predictions about the behaviour of the process in future. IMO that is the appropriate use of statistical tools.
Regards,
Barbara
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Excellent Reference for MS Excel .xls files Ashok GS Excel .xls Spreadsheet Templates and Tools 3 8th July 2009 09:03 AM
Excel .xls spreadsheet for Line Balancing (Time and Motion Study) needed umarenp Excel .xls Spreadsheet Templates and Tools 1 17th June 2008 04:06 AM
Creating a Graph with 2 different Value axis in Excel .xls try2makeit Excel .xls Spreadsheet Templates and Tools 2 27th May 2008 11:59 AM
SPC XL 2000 add-in for Excel.xls - Password vivamh Excel .xls Spreadsheet Templates and Tools 6 30th April 2007 02:38 AM
X bar s chart template / form for Excel .xls randymhl Excel .xls Spreadsheet Templates and Tools 2 14th March 2006 11:19 PM
The time now is 03:56 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
